Φτηνος στα πιτουρα κι ακριβος στ' αλευρι...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Γιατι ο τιτλος?
Ριξτε μια ματια στα μηχανηματα που εχει ο τυπος(κορυφαια)
αλλα και τι επελεξε για επεξεργαστη(τελευταια συσκευη)
1 Stewart Custom Curve Vertical Masking Screenwall CV168SFHG3WX
1 Digital Projection 3-chip DLP projector, ISF Specified TITAN Reference 1080p
1 Digital Projection Anamorphic Lens for projector Anamorphic Sled
1m Kaleidescape 1U Server KServer-1500
1 Kaleidescape 1080p Player KPlayer-6000
4 Kaleidescape 1 TB Disk Cartridge KDISK-1000-L-N
1 Marantz Blu-Ray DVD Player BD8003
1 HD Cable BoxCustomer Supplied
1 Karaoke DVD & CD+G Karaoke Player, w/mics ML517
1 Apple TV music and video player, w/hardrive AppleTV
1 JBL Synthesis Atlas Theatre Package System SYN-ATLAS
1 Middle Atlantic 43 Space Equipment Rack 5-43
1 Middle Atlantic Skirted Wheelbase for slim 5 CBS-5
1 Middle Atlantic Rack Light w/8 oulet surge/spike PDLT-815RV
1 Middle Atlantic Ultra Quiet Fan Panel w/speed UQFP-4
4 Middle Atlantic Black Textured Custom Rackshelf RSH-4S
8 Middle Atlantic 1 space (1 3/4”) vent panel VTF1
1 Middle Atlantic 4 Space Rack Drawer TD4
1 APC S Type AV Power Conditioner with Battery S10
1 Crestron Isys i/O 8.4” WiFi Control Package AV2-TPMC-PAK
2 Crestron Isys 5.7” color wall mount touchpanel TPS-6L
3 Crestron iLux Integrated Lighting System, 6 Zones CLS-C6
1 Crestron Heating and Cooling Thermostat, White CHV-TSTATW
1 Crestron Remote Temperature Sensor CHV-RTS;
LOBBY: 1 LG 50” HDTV Plasma 50PG60
1 IC universal wall mount fixed bracket ICLPFM1T02
1 Leon LCR all-in-one display matching speaker HZ-414-LCR
2 Niles 7” Surround Effects Loudspeaker CM750FX
1 Niles 9” Passive Subwoofer, Ceiling Mounted CM960SUB
1 Niles 2 channel high power amplifier SI2125
1 Marantz Dolby Digital Surround Receiver SR5002
http://www.electronichouse.com/article/red_carpet_treatment_the_only_way_to_go
Ε τι να κάνει εκεί τον τσίμπησε ο κάβουρας....
Καλύτερα πάντως από ακριβός στα πίτουρα και φθηνός στ΄αλεύρι γιατί φαντάσου να του έπεφτε το φωτιστικό στο κεφάλι εκεί μέσα...
Απάντηση: Φτηνος στα πιτουρα κι ακριβος στ' αλευρι...
Και πολυ του ειναι του βλαχουλα.
Πείνα καταραμένη....
Εγκεφαλική πείνα θα έλεγα....:136::136::136:
Νεόπλουτοι....
Ρε παιδιά, όλοι αυτοί οι νεόπλουτοι Αμερικάνοι, που φτιάχνουν χώρους σαν κι αυτόν, μάλλον δεν έχουν ιδέα από το χόμπυ - εννοώ την καρδιά του χόμπυ - που είναι ο συνδυασμός μηχανημάτων, περιεχομένου και χώρου.
Απλά βλέπουν κάποιον που έχει κάτι παρόμοιο, το ζηλεύουν, τους πιάνει και λίγο η μεγαλομανία, απευθύνονται σε κανένα από αυτούς που λέγονται Specialized Installers και τους φτιάχνει ένα χώρο, που μέσα του βάζει ότι του κατέβει, ήτοι ότι έχει σε στοκ ή ότι μπορεί να πασάρει με μεγαλύτερη ευκολία. Σάμπως ο διοκτήτης θα καταλάβει καμιά διαφορά;
Καλημέρα.
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Όπως τα βλέπω κι εγώ αυτά τα υπερβολικά κατασκευάσματα, μου δίνεται η εντύπωση ότι το όλο πρότζεκτ το αναλαμβάνει ένας διακοσμητής και όχι ένας εγκαταστάτης Home cinema - καλιμπρέϊτορ.
Βάζουμε μέσα όλο φρουφρού κι αρώματα, σχέδια, χρώματα, κρυφούς φωτισμοί και στο τέλος παίρνουμε κι ένα σετ ακριβών μηχανημάτων.
Με την λογικά ότι αφού είναι ακριβά θα παίζουν και καλά.
Το ίδιο δεν κάνει εκεί και ο δικός μας ο Καλομοιράκης;
Εμένα μου αρέσει και ειλικρινά έχει άποψη κάτι που δεν έχει πολλών επικριτών ο χώρος.
Αν μπορούσα θα έκανα κάτι τέτοιο μόνο και μόνο για να ακούω σχόλια κι επικρίσεις από τους άλους!:137:
Κι αν με ρωτούσαν γιατί ξόδεψα τόσο λεφτά θα έλεγα : "Because I can!"
albie
