mac users, mac computers & media players...
Απάντηση: mac users, mac computers & media players...
SMBup για streaming με smb από mac με 10.7 σε συσκευές media players (Dune,Mede8er,Popcorn Hour κλπ)
WHAT'S NEW
Version 1.3.1.0.0:
Improved configuration settings UI for shares and globals
Added basic support for authenticated shares
Added basic user management (create, delete). Delete and re-add to change password.
Added basic support for HOME shares, pointing to users's home directories
Added safeguard to protest existing installations of MacPorts when uninstalling
Added checks to ensure process is not started until a valid config file is in place
Added basic update notification
Modified default config settings to better suit Mac OS X's needs
Added a global 5-minute timeout authentication timer (Mac OS X Padlock)
Added menu shortcuts for more functions
Fixed various bugfixes related to start/stop of Mac OS X native services.
It's seriously recommended that you re-set the configuration and re-add your shared folders after every version, if at all possible. This will be the first suggestion made in almost all support requests, as the tweaking of the default global settings is an ongoing process.
Donation Window not reset upon update of new versions, so if you've checked the donation checkbox it'll keep believing so. Still, if you feel the program warrants further donations don't let this stop you :) (Update incorrectly stated 1.3.0 instead of 1.3.1. This has been fixed)
REQUIREMENTS
Intel, Mac OS X 10.7 or later
Καλό Πάσχα από καρδιάς κατ'αρχήν στους φίλους της κατηγορίας!
Ελπίζω να περάσατε καλά με την οικογενειά σας και τα αγαπημένα σας πρόσωπα!
Εχουμε update για το mkvtoolnix
WHAT'S NEW
Version 5.5.0_2012-04-14-38ac:
Build system: Boost's "lexical_cast" and "type traits" libraries are now required.
mmg: new feature: Added GUI controls for mkvmerge's "file concatenation" feature as "additional file parts". The user can chose which individual files are treated as if they were a single huge source file.
mkvmerge: bug fix: The handling of the "do not read other files" options (e.g. "=file.vob" and "( file.vob )") was broken for MPEG program stream files.
Makemkv σε νέα έκδοση,δεν χρειάζεται να πω περισσότερα και να φλυαρήσω,όσοι το δουλευετε ξέρετε και τι κάνει!:126:
WHAT'S NEW
Version 1.7.4:
Added support for AACS v31
Improved handling for DVD/Blu-ray discs with mastering errors
Conversion profile improvements in expert mode
Bug fixes:
On some discs 3D MVC video was not recognized
Subtitle tracks were not available on HD-DVD discs after 1.7.0 update
REQUIREMENTS
Intel, Mac OS X 10.5 or later
SMBup update!
Για streaming με smb από mac με 10.7 σε συσκευές media players (Dune,Mede8er,Popcorn Hour κλπ)
WHAT'S NEW
Version 1.4.0:
Added additional situations where system could fail to come out of a loop when starting the service
Re-set System images to use PNG instead of TIFF in 10.7.4 (thanks for the heads-up, Apple! -NOT-)
Hence: 10.7.4 compatibility
Mac OS X Lion Server compatibility confirmed
Converted some mandatory fields into optional, as per Samba spec. Should avert some "key not found" errors
Fixed several interface bugs and text copy
Decided against adding nagscreens for donations or changing the app to crippled shareware.
Added a big "Thank you!" note to the donation checkbox. Donors should feel better for it
REQUIREMENTS
http://www.macupdate.com/app/mac/41541/smbup
MakeMKV 1.7.5 για να ριπάρουμε τα blu ray δισκάκια μας σε ασυμπίεστη ματρόσκα.
WHAT'S NEW
Version 1.7.5:
Miscellaneous stability and improvements
Expert mode - support for DTS-HD decoding/transcoding
Link
HubFlow (was WDFlow)
Για όσους έχουν τα Western Digital media players!
WHAT'S NEW
Version 1.34:
New function: You can now choose the poster that you prefer for a movie rather than the default option that is proposed. Just click on the magnifier and use the slider to browse the posters
Code cleaning and bugs correction
New movie search engine
New User guide
Εδώ
SMBUp 1.4.1
Απαραίτητη αναβάθμιση σε όσους έχουν 10.7.X και media players.Για streaming από το mac στο media player με smb (samba)
WHAT'S NEW
Version 1.4.1:
Fixed some localization errors that made critical info appear in spanish only
Changed installation wording to make it clear native network browsing functionality is lost when Samba is installed
Miscellaneous UI fixes
REQUIREMENTS
Εδώ
Απάντηση: Αναβαθμίσεις Mac OS και προγραμμάτων της Apple!
Σχετικά με το Mountain Lion και για streaming από το mac προς το media player:
Για nfs share αναβαθμίζουμε απαραίτητα το NFS Manager στην έκδοση 3.7 αλλιώς το πρόγραμμα δεν ανοίγει σε 10.8
NFS Manager Version History
Release 3.7 (Build 120711)
This version adds support for the operating system OS X 10.8 Mountain Lion. As usual, there are critical issues when using the first immature versions of the OS. Please read the Release Notes of NFS Manager before planning to use this operating system.
Added support for one-click registration.
Added full support for current operating system features like Resume and high-resolution displays.
By user request, the reference manual now contains additional tips for sharing files for media players.
The column to display the mount point path was reinstated in the table of automount entries. Users of previous application versions may have to readjust position and width of the new column.
The tables to display automount and share configuration now have an additional status display showing the number of entries.
User errors in the definition of share entries are now handled more gracefully when shared folders have been renamed or deleted.
In addition to storing all NFS configuration aspects to archive files, the application now supports exporting all data to neutral files in CSV format (comma-separated values). The exported files can be used for documentation purposes in database, spreadsheet, or other applications.
A new DNS check was implemented to detect typical configuration errors in the domain name setup of the local network which could prevent NFS components of the operating system not to work correctly.
Corrects a problem where automount options of the NFS client to create an automatic mount point could change unexpectantly after archiving and reloading configuraton settings.
Important: Due to changes imposed by Apple's “Gatekeeper” feature, the security component of the application works slightly different. If you are using two or more of our following system utilities, you should update them all in parallel in order to avoid mutual conflicts: NFS Manager, Sync Checker, TinkerTool System Release 2. For detailed information, please see the chapter Release Notes in the reference manual.
Καλό είναι επίσης να έχουμε την τελευταία έκδοση του SMBup για καλύτερη συμβατότητα με smb share
Plex Media Server 0.9.6.6
Version 0.9.6.6:
New:
Added (advanced) preference for specifying location of Aperture/iPhone XML paths. The preference is ApertureLibraryXmlPath for Aperture and iPhotoLibraryXmlPath for iPhoto. Yes, we’re going to have an easy way to get at these advanced preferences soon.
(Linux) Allow syslog logging via environment variable PLEX_MEDIA_SERVER_USE_SYSLOG. This has been requested for ages.
(API) Massive performance improvement for players that ask for paged data (e.g. for Roku). If you have large library sections, you’ll notice a big change; with 1000 items, the page requests are 6 times faster.
(API) Added /library/sections/X/{sorts|filters} endpoints for advanced filtering.
Fixed:
Sidecar (e.g. SRT) subtitle files work again. Sorry, that was a bad regression.
(Windows) Upload speeds from the server were artificially slow in some cases. We’d gotten sporadic reports over the months that upload speeds seemed limited, and we finally managed to track down the issue. The upload speed will now max out your connection, and will take much less CPU as well.
A crash when scanning for plug-ins when permissions are wrong.
(Mac) Fix some Aperture photos not displaying properly.
Library timeline could generate blank items occasionally.
Web interface didn’t show added and deleted items properly when scanning.
Don’t pass back bogus blank content ratings.
(Linux) DLNA icon and server name were missing on some platforms.
When overwriting plug-ins, files that don’t exist anymore are deleted.
Handle 302 as well as 301 redirects in the image transcoder.
When scanning files that had already been scanned, they didn’t end up with thumbnails.
Certain image formats (TIFF, BMP, PCX) didn’t get thumb nailed.
Fixed sleep prevention, OS X (and possibly Linux) should sleep now.
(Windows) Fixed a crash on start.
(Synology) DLNA to PS3 wasn’t working.
(DLNA) Memory leak in DLNA server process.
(DLNA) Fixed PS3 audio dropouts by transcoding to stereo for now in the profile.
(DLNA) Fixed evaluation of limitations.
(DLNA) Fixed AAC audio not playing to PS3.
(DLNA) Build-in profile now supports Samsung SmartTVs (thanks, holzi!)
http://www.macupdate.com/app/mac/42311/plex-media-server
MakeMKV 1.7.7 εδώ
WHAT'S NEW
Version 1.7.7:
MakeMKV now prevents computer going to sleep mode during copy
Miscellaneous stability improvements
Max OS X changes:
BDMV folder bundles can be selected on Mountain Lion
Switched from GROWL to Mountain Lion notifications
Expert mode:
MakeMKV now includes ffmpeg executable with 24-bit FLAC encoder
New FLAC profile
Bug fixes:
On some DVDs MakeMKV could go into endless loop when opening disc in CellWalk mode
MakeMKV could hang (endless ASSERT) on titles with seamless branching and LPCM tracks
Forced subtitles were extracted incompletely on certain blu-ray discs
Aspect ratio was sometimes incorrect for H.264 SD content
Occasionally makemkvcon executable could stay running in background even after application window was closed
REQUIREMENTS
Αυτό ήταν παιδιά!
Σε αυτό το νήμα ξεκίνησα και σε αυτό θα είναι και το φινάλε!
Καλά ήταν όσο κράτησε και το φχαριστήθηκα!Να είστε όλοι καλά και σας ευχαριστώ από καρδιάς!
Συγγνώμη αλλά δεν μπορώ να συνεχίσω άλλο,θα είναι όχι μόνο αστείο και γελοίο,αλλά και αναξιοπρεπές από την πλευρά μου.
Προσπάθησα,αλλά δεν μπόρεσα και λυπάμαι ειλικρινά!
Δεν ξέρω κατά πόσον είμαι γραφικός ή <<γραφικός>> ή συμπαθής,σίγουρα όμως δεν κάνω καμιά ζημιά στο φόρουμ.Τουλάχιστον όχι μεγαλύτερη από την ανοχή στους οπαδούς των ναζί.
Βέβαια μίσος για τους φασίστες και τους ναζί,αλλά και όσους τους ανέχονται έχω και είναι και άσβεστο μάλιστα!Οχι επικίνδυνο όμως,απλά στην θεωρία!
Καταλαβαίνετε όμως ότι δεν μπορώ να συμμετέχω πλέον και να γίνομαι συνένοχος αθελά μου!
Θα ξαναβρεθούμε και θα τα ξαναπούμε!
We will be around!:605:
Ν'αντέξουμε (αντέξετε) πάνω απ'όλα!:126:
PS:
Οσον αφορά τους νεοναζί και τους ρατσιστές,δε θα περάσουν,θα τους συντρίψουμε και θα τους στείλουμε και πάλι στο 0.26% dont worry!!:615:
Γεια χαρά και ευχαριστώ πολύ.Ηταν τιμή μου!:446:
Δεν ξέρω τι έγινε και γιατί αποχωρείς (αν κατάλαβα καλά από το φόρουμ και όχι μόνο από το νήμα).
Πάντως εγώ σου οφείλω ένα πολύ μεγάλο ευχαριστώ, γιατί δεν είχα το χρόνο να ψάξω να βρω και να δοκιμάσω όλα όσα είχα ανάγκη και τα οποία τα πρότεινες εσύ σε τούτο εδώ το νήμα, διευκολύνοντάς με τα μάλα. Ελπίζω να μη χαθούμε!
Ειλικρινά Λεωνίδα δεν μπορώ να κατανοήσω την απόφασή σου. Προφανώς και δεν έχει να κάνει με το νήμα των mac ή των media players.
Παρ' όλα αυτά την σέβομαι, και ελπίζω κάποια στιγμή που θα δεις τα πράγματα με μεγαλύτερη ηρεμία και νηφαλιότητα, να επανέλθεις.
simplygades
