Y
Yiannis_B
Απάντηση: Re: Mola - Mola! (...από τα κορίτσια της Hypex)
Αν και έχει μία βάση ο συλλογισμός, διατηρώ τις επιφυλάξεις μου για το unity gain.
http://mola-mola.nl/index.php/blogTake one preamp of which you want to know what it does to the sound. Call that the “device under test”. Carefully set the volume control of the DUT to unity gain. Then, use a second preamplifier (the “monitor pre”) that you’ll use as a selector and volume control. Using a Y split cable, feed the source into the DUT and into one input of the monitor pre. Feed the output of the pre under test into another input of the monitor pre.
Set the volume of the second pre to a comfortable level, put on some music and do a comparative listening test just like you’d ordinarily do. But instead of comparing which you like most, concentrate on how similar or different the two are. The smaller the difference, the more accurate the pre under test.
