Listening to the Wilson WAMM Master Chronosonic
Mr Spock
demokratischer - sektor
I have to admit that the Master Chronosonic/WAMM Subsonic system's bass performance was a surprise. I expected power, impact, articulation...you name it. But nothing could have prepared me for the organ's output at 16Hz. To think: I had wondered whether the room would support true low bass, and, if so, whether that bass response would be spectacularly uneven. The answers were Yes and No, respectively, and I'm still not sure how that trick was pulled off.
In his own report, Jason Victor Serinus noted that production of the Master Chronosonic would be limited to 70 sets, so I feel very fortunate to have had an opportunity to spend time listening to a system built around one of those—in Carmen Red finish, no less!—and doubly so in that I was able to do so in a normal-sized room. I'll admit that I'd been skeptical about the Master Chronosonics' ability to work very well in such a space. Yet song by song, and hour by hour, my questions were answered, my doubts put to rest: The Wilsons worked very, very well. I heard nothing to suggest their performance had been compromised to accommodate the room's size, or anything that suggested their performance was being degraded by the room itself. They displayed all the virtues I associate with Wilson speakers, and at a level commensurate with the role they fill at the top of the company's line.
https://www.stereophile.com/content/listening-wilson-wamm-master-chronosonic
Technical Specs
The following specifications are preliminary and are subject to change.
Drivers
Forward Firing Tweeter
Size
1 inch (2.54 cm)
Dome Material
Doped Silk Fabric (Mk5)
Enclosure Type
Forward Firing (Sealed)
Enclosure Material
X-Material
Rear Firing Tweeter
Size
1 inch (2.54 cm)
Dome Material
Enclosure Type
Rear Firing (Sealed)
Enclosure Material
X-Material with S-Material Baffle
Upper Mid-Ranges
Sizes
4 inches (10.16 cm)
Cone Material
Paper Pulp Composite
Enclosure Type
Forward Firing (Bottom Vent)
Enclosure Material
Lower Mid-Ranges
Sizes
7 inches (17.78 cm)
Cone Material
Doped Paper Pulp
Enclosure Type
Enclosure Material
Woofer
Size
10.5 inches (26.67 cm)
Cone Material
Hard Paper Pulp
Enclosure Type
Woofer (Front or Rear Ported)
Enclosure Material
Material: X-Material
Woofer
Size
12.5 inches (31.75 cm)
Cone Material
Hard Paper Pulp
Enclosure Type
Enclosure Material
Measurements
Nominal Impedance
3 ohms / minimum 1.77 ohms @ 310 Hz
Sensitivity
90 dB @ 1W @ 1m @ 315Hz
Frequency Response
20 Hz – 33 kHz +/- 2 dB
Minimum Amplified Power
100 watts/channel
Dimensions
Height
84 3/8 inches (214.29 cm) w/o spikes
Width
21 inches (53.34 cm)
Depth
37 3/8 inches (94.87 cm)
https://www.wilsonaudio.com/products/wamm
https://www.wilsonaudio.com/pdf/press-releases/wamm-press-release.pdf
Και γιατί είναι αριστούργημα;
Διότι έχει μια εξαιρετική διάταξη μεγαφώνων για άριστο λοβό στη θέση ακρόασης, διότι έχει μια φανταστική καμπίνα, και διότι έχει σοβαρά μεγάφωνα για να βγάλουν πλήρες φάσμα και ασυμπιεστα δυναμικά.
Ως μετατροπέας ηλεκτρικής ενέργειας σε ηχητική, δεν έχει σοβαρά ελαττώματα, πλην της έλλειψης ενεργούς πολυενισχυσης και διόρθωσης απόκρισης με κάποιο dsp, αλλά στο κοινό που απευθύνεται, αυτά είναι του σατανά, χαλάνε τις χροιές.
Φυσικά η τιμολόγηση είναι για μήνυση...
Akis_G
Το εν λογω καταπληκτικο ηχειο, σχεδιαστηκε για να δωσει απαντηση, σε δυο πραγματικα ρεαλιστικες ανάγκες των απαιτητικών μουσικόφιλων του καιρου μας:
Σεναριο 1ο:
Εισαι πολυεκατομμυριούχος και στηνεις ένα νο κομπρομάιζ ηχοσυστημα.
Εντελως απροσδόκητα όμως, ο ιδιοκτητης της γκαρσονιέρας που νοικιάζεις, σε πεταει στο δρομο γιατι δεν πληρωνες τα κοινόχρηστα.
Αναγκαζεσαι να μετακομίσεις σε ένα χαμηλοταβανο ημιυπογειο, με εντελως διαφορετικη διαρρύθμιση.
Τι κανεις? Πετας τα ηχεια?
Όχι κυριε.
Είναι ρυθμιζόμενα.
Βζζτ, βζζζτ, αλλαζεις λιγο τις γωνίες αναμεσα στα μινττουίτερ και τσουπ, τέλειος παλι ο λοβος στη θεση ακροασης.
Σενάριο 2ο:
Εισαι και πολύ γνώστης οντιοφιλ και εχεις παντρευτεί πολυεκατομμυριουχο συζυγο.
Σου λεει, παρε αντρα μου οποια ηχεια γουστάρεις, δωρο για την επετειο μας.
Εχει όμως η παλαβη, φαει πετριά με την εσωτερικη διακοσμηση και αλλαζει τη διαρρυθμιση του σπιτιου κάθε τρεις και λιγο.
Μπαινεις σπιτι και δεν ξερεις που θα βρεις τη θεση ακροασης.
Σου'χει κανει το τριγωνο ακροασης, σκαληνο αμβλυγώνιο.
Τι κανεις?
Παιρνεις τα Βαμμ. Ρυθμιζόμενα. Προμπλεμ σολβντ.
Εγω παντως δε θα τα επαιρνα, γιατι με τοσο λεφτα, θα επρεπε η ρυθμιση να γινεται από το κινητο, μεσω αππ, που θα ελεγχει μικροσερβοκινητηρες πανω στην καμπινα, όχι να τρεχω με τον καβουρα στο χερι να τα σφιξω.
:hi: μεν, :headbang: δε.
Πάρτε ενεργά λεμε !!!
Παλιό εταιρεία και αυτή .
Χώρια που έχει έρθει ο ίδιος ο ιδιοκτήτης της εταιρείας καιέχει στήσει ηχεία κατασκευής του Αθήνα πριν 2-3 χρόνια .
Απατεώνας παιδί μου ...
$685,000/pair
Ε, λίγο τσιμπημενο το λες δε το λες.
Τι; Κλέφτες να γίνουν οι άνθρωποι;
Πάντως μπράβο τους αν πουλήσουν 70 τεμάχια σε αυτή την τιμή.
2 ηχεία στην τιμή 10 αυτοκινήτων της Μερτσέντες ή ακόμα και πόρσε.:p
10 πόρσε ή 2 ηχεία,
10 πόρσε ή 2 ηχεία,
Δε ξέρω δε ξέρω
Είμαι ... αναποφάσιστος.:D
Δηλαδή από 70 ηχεία περιμένουν να πάρουν...
50 μύρια Αμέρικαν νταλαρς.:o
Α σταδιαλα, σε τι κόζμο φέρνουμε τα παιδγιά μας...
Katerinanota
