Stereophile Recommended Components
Mr Spock
demokratischer - sektor
Class A
Best attainable sound for a component of its kind, almost without practical considerations; "the least musical compromise." A Class A system is one for which you don't have to make a leap of faith to believe that you're hearing the real thing. With Super Audio CD, DVD-Audio, and Hi-Rez PCM and DSD files now available, we have created a new Class, A+, for the best performance in those digital categories. Class A now represents the best that can be obtained from the conventional 16/44.1 CD medium. We also created Class A+ categories for turntables and phono preamps.
Class B
The next best thing to the very best sound reproduction; Class B components generally cost less than those in Class A, but most Class B components are still quite expensive.
Class C
Somewhat lower-fi sound, but far more musically natural than average home-component high fidelity; products in this class are of high quality but still affordable.
Class D
Satisfying musical sound, but these components are either of significantly lower fidelity than the best available, or exhibit major compromises in performance-limited dynamic range, for example. Bear in mind that appearance in Class D still means that we recommend this product-it's possible to put together a musically satisfying system exclusively from Class D components.
Class E
Applying to "Loudspeakers," these are entry-level products.
Class K
"Keep your eye on this product." Class K is for components that we have not reviewed (or have not finished testing), but that we have reason to believe may be excellent performers. We are not actually recommending these components, only suggesting you give them a listen. Though the report has yet to be published in certain cases, the reviewer and editor sometimes feel confident enough that the reviewer's opinion is sufficiently well formed to include what otherwise would be an entry in one of the other classes, marked (NR).
Και το δια ταύτα είναι ότι με 4000 παίρνεις τα Bel Canto Design e.One REF600M monoblock στην κατηγορία class A με Hypex Ncore modules και 600Watt 4Ω και ξεμπερδεύεις, αντί να δώσεις καμιά 100.000 για κάτι πάλι στην κατηγορία Class A που ακούγεται το ίδιο (??).
Συλλογή από ακριβά μηχανήματα έχουν στις λίστες.
ε, αυτή είναι η δουλειά τους.
Εριξα μια γρηγορη ματια στους ολοκληρωμενους (μονο εκει ετσι) και εχει και προσιτες συσκευες.......αυτον το ps audio sprout 100 τον ζαχαρωνω,απλα τα 600 δολλαρια, οταν περασει τον Ατλαντικο, γινονται 750 ευρω και τον ριχνουν σε αλλη κατηγορια ανταγωνισμου.
Ναι, σε όλες τις κατηγορίες έχει 1-2 φτηνές επιλογές, υποθέτω αυτές είναι φλέγον θέμα πλειστηριασμού.
Καλό και ΄΄άγιο΄΄ το Stereophile,αλλά ωραίος ήχος κατηγορίας Α μπορεί πλέον να προκύψει με setup που θα κόστιζαν πολύ λιγότερο απ'όσο αφήνουν να εννοηθεί.
Και δια του λόγου το ασφαλές,ας φέρουμε ένα παράδειγμα έτσι όπως έρχεται προχείρως στο μυαλό :
Dynaudio Core Sub ζεύγος
Dynaudio Core 59 ή ADAM S3 κύρια ηχεία
ή Genelec ομοαξονικά μοντέλα με ομόσταυλες μονάδες sub
Dac-pre Mytek,Benchmark,Metric,Soekris - για τους οπαδούς του...αισθησιασμού το τελευταίο - κ.ο.κ. σε δικαναλική αρχιτεκτονική setup και τα γνωστά πολυκαναλικά περί των οποίων άλλοι είναι ειδήμονες
Στοιχειώδης παθητική ακουστική φροντίδα χώρου καθώς και λογισμικό Dirac.
Για δικαναλικό setup ο λογαριασμός δεν ξεπερνά τα 20Κ χονδρικώς...
Και πάντα για ηχητική απόδοση κατηγορίας Α όπως τέλος πάντων την εννοούν η οποία θα βαράει στο ΄΄δόξα πατρί΄΄ οποιαδήποτε παραδοσιακή δικαναλική χαϊεντιά κυκλοφορεί.Στο λογαριασμό δεν συμπεριλαμβάνονται ο διαμετακομιστής της αρεσκείας μας ή το βινυλιοσύστημα,αφού ως έμπειροι και...μερακλήδες οφείλουμε να έχουμε διευθετήσει εξ ολοκλήρου τέτοιες ανάγκες προτού να περάσουμε στις...μεταξωτές κορδέλες της Α κατηγορίας.
Σταύρος Λαγκαδιανός
Το αγοράκι με τα σπίρτα
Στην Κατηγορία Α των "Music Surround Components"
είδα μια πολύ ενδιαφέρουσα πρόταση: miniDSP DIO8 USBStreamer: $299 inc. cable $$$
Και το Ντιράκ στα κάγκελα, μπαρδόν! στον σέρβερ, όπως ο Κάλμαν
Πλας ένα ντακ, νάτο το 7.1 :cool::wink:
Dolby-DTS και Auro upmixing γιόκ όμως :tongue:
Ούτε immersive μπορείς.
Μόνο pcm
Και δεν βλέπω Dirac ενσωματωμένο.
Όπως έχω ξαναγράψει δεν υπάρχει καλή λύση που να μην έχει ήδη προταθεί, μην ψάχνετε άδικα :gotcha:
Για το απμίξ ένα σόνυ απ' τον Εάρ :laugh:
Θα τα κάνεις σαλάτα, πολλές συσκευές, δεν θα έχεις προοπτική για ηχεία οροφής, αντί να πάρεις ένα αρκαμ με 4000 για να γλιτώσεις ένα χιλιάρικο.
Καντο να γελάμε :gotcha:
Σταύρος Λαγκαδιανός
Όχι ακόμα. :smile: Δεν είναι μόνο ο παρών προϋπολογισμός μου που δεν επιτρέπει. Είναι νωρίς, προβλέπω εξελίξεις ραγδαίες. Αν κοιτάξω πίσω 2,5 χρόνια που άρχισα πάλι να κοιτάζω τα χάι φάι, μοιάζει να έχει περάσει 10ετία. Άλλο τόσο και θα έχουμε αλλάξει αιώνα.
Παραδοσιακά οι μηχανικοί του χάι φάι, πλην ελαχίστων εξαιρέσεων, ήταν οι πλέον παρακατιανοί σε γνώσεις δεξιότητες, ταλέντο. Λογικό, καθώς οι πιο καλοί έβρισκαν καλύτερα μεροκάματα αλλού. Στις μέρες μας αυτό αλλάζει. Νέοι κολοσσοί μπαίνουν στο παιχνίδι, το διασυνδέουν και το εντάσσουν σε ευρύτερες πλατφόρμες και συστήματα, νομίζω πως βρισκόμαστε στην αρχή ενός μπουμ.
l.koustimpis@visualacoust
