Άλλη μια εταιρία σπ' την Κίνα στο CarAudio: BETA
ΒΕΤΑ said:
Profile
Beta Enterprise, as the manufacturer of Car Audio Accessories in China, specializes in the export of power distribution block with various specification, fuse, fuse holder, battery terminal, power cable, speaker cable, RCA cable and adapter, power capacitor, speakers, and cigar lighter, crimping tool, steering wheel adapter etc.
Since the founding of Beta Enterprise in 1997, we, on the basis of specialty, opening and innovation, have steadfastly developed our enterprise in an international quality standard, and with the help of low-cost manufacturing at home we are making full use of "Made in China" so as to make our products be more competitive in the international market.
We aim at bringing forth qualified products and building up our customers' confidence and consummating our after-sale service. As an enterprise, we firmly believe that the vigor of a manufacturer springs from its innovation, and excellent service is a guarantee of the mutual development for both sides.
We always attach great importance to the development of new products. With the help of our professional designing, we update our products all the time to meet the demands of our customers.
Hopefully, we, together with you and immersed in the globalizing economic environment, head for a brighter future.
Και με μεγάλη ποικιλία προιόντων............Όπως......
Fuse Holder
FOR 4GA or 8GA/ WATER PROOF
USE AGU FUSE
USE AGU FUSE
2GA/4GA x1 or 3 IN/8GA x 2 OUT
USE AGU FUSE
2GA/4GA x 3 IN / 8GA x 2 OUT
USE AGU FUSE
0GAx1 + 4GAx2 IN / 8GAx4 OUT
USE MAXI FUSE
USE AGU FUSE
FOR 0GA or 2GA
USE ANL FUSE
FOR 0GA or 2GA
USE ANL FUSE
FOR 0GA or 2GA
USE ANL FUSE
0GA/2GA x 1 IN / 4GA x 2 OUT
USE ANL FUSE
Power / Ground Cable
- Super Oxygen free copper(OFC); Tinned OFC.
- Soft PVC insulation (Transparent).
- Various sizes: 10 / 8 / 4 / 2 / 0 Gauge
(6 / 10 / 20 / 35 / 50 mm2)
- Various colors insulation: red/blue/black/purple/yellow/clear...
- Custom designs are available.
Speaker Cable
- Various sizes: 22 / 18 / 16 / 12 / 10 Gauge
(0.75 / 1.5 / 2.5 / 4.0 / 6.0 mm2)
- Various colors insulation: red/blue/violet/yellow/clear...
RCA Interconnect
- Single Shield, Double Shield, Triple Shield with remote cable are available.
. Double Shield: Al maylar + Braiding shield
. Triple Shield: Al maylar + Braiding shield + Al maylar
- Various diameters are available.
- Various insulation/jacket colors are available.
- Various metal/plastic connectors are available.
Amplifier Wiring Kits
- 2GA Kit, 4GA Kit, 8GA Kit, 10GA Kit
- Color: Various colors/transparent are available.
- Packaging: color box, blister card
Speakers
■ 4" 2 Way ■ 4" Injection Cone Woofer With Rubber Edge And 30mm Mylar Tweeter ■ 8 OZ Ferrite Magnet3/4" Aluminum Voice Coil ■ 13 Watts Rms 80 Watts Max. Power
■ 5" 2 Way ■ 5" Injection Cone Woofer With Rubber Edge And 30mm Mylar Tweeter ■ 10 OZ Ferrite Magnet ■ 3/4" Aluminum Voice Coil ■ 15 Watts Rms 90 Watts Max. Power
■ 6.5" 2 Way ■ 6.5" Injection Cone Woofer With Rubber Edge And 30mm Mylar Tweeter ■ 10 OZ Ferrite Magnet ■ 1" Aluminum Voice Coil ■ 20 Watts Rms 120 Watts Max. Power
■ 6"x9" 3 Way ■ 6"x9"Injection Cone Woofer With Rubber Edge And 30mm Mylar Tweeter ■ 25 OZ Ferrite Magnet ■ 1" Aluminum Voice Coil ■ 30 Watts Rms 180 Watts Max. Power
Τους χρειάζεται και κάποιο διαιρούμενο σετ (mid-bass & tweeter & x-over)
Re: ΆƒΙƒΙƒΕ ƒΚƒΗƒΏ ƒΓƒΡƒΏƒΗƒΟίƒΏ ƒΠƒΞ' ƒΡƒΕƒΛ ƒ¨ίƒΛƒΏ ƒΠƒΡƒΝ CarAudio: BETA
Speakers/Sub Woofers
?‘ WOOFER 10" 12"
?‘ DUAL-4 Ohm IMPEDANCE
?‘ 4-LAYERS KAPTON VOICE COIL 2"
?‘ MAX POWER 300-750 W
?‘ FERRITE MAGNET(OZ) 2X50 OZ 2X50 OZ
?‘ WOOFER 10" 12" 15"
?‘ IMPEDANCE 4(Ohm)
?‘ WATTS MAX.POWER 500W 700W ?‘ 4-LAYERS ALUMINUM VOICE COIL 2" 2.5"
?‘ FERRITE MAGNET (0Z) 2X40 2X60 OZ
Boom Box
?‘ WOOFER 6.5" 8" 10" 12"
Εκτός κι αν οι μεγάλες καταφέρουν να αγοράσουν κάποιες από αυτές τις εταιρίες.......
Ή απλά γίνουν μέτοχοι (για να φέρουν στα ίσα τις απώλειες......)
Οπτικά πάντως, τα προιόντα της ΒΕΤΑ φαίνονται καλά.
Και αν οι τιμές είναι πολύ καλές (λογικά....) δεν βλέπω τον λόγο κάποιος να μην τα προτιμήσει.......... :roll: :wink:
ztv
