Με το BatteryBar θα έχετε πρόσβαση σε πληροφορίες για την κατάσταση της μπαταρίας σας. Μετά την εγκατάσταση του εμφανίζεται ως εικονίδιο στην taskbar των Windows από όπου μπορείτε να δείτε τόσο τον εναπομείναντα χρόνο λειτουργίας, όσο και το ρυθμό αποφόρτισης ή φόρτισής της. Ακόμα μπορείτε εύκολα να δείτε και το ποσοστό φθοράς της μπαταρίας αλλά και τη χωρητικότητά της σε mWh.
Discharging
When you're running on battery, BatteryBar shows the percentage bar in green, yellow, or red, depending on how much battery power is remaining. The bar displays the time left on your battery in Hours:Minutes
Charging
When charging, the percentage bar is shown in blue to indicate charging, and the estimated time to full charge is shown. The bar turns black and shows "On A/C" when fully charged.
Πηγές :Other Features
Vista style - The toolbar is using the same look and feel as the Vista taskbar buttons
Statistical time prediction - BatteryBar monitors your battery and keeps a history of how long it takes for your battery to charge and discharges. That information is used to more accurately predict the life of your battery
Translations - BatteryBar fully or partially supports 13 languages. Anyone may volunteer to translate BatteryBar to additional languages
Detailed Battery Info - BatteryBar is now capable of collecting detailed information about your battery, including max capacity (mW), current capacity (mW), charge rate (mW), discharge rate (mW), and more.
Automatic Update - BatteryBar will check for new versions at startup and automatically download the new version
Features in the Pro version
Low battery and critical battery notifications and audio alerts
Customize 20 settings, including changing the font, low battery warning levels, and more.
New features in future versions that will only be available in the Pro version
laptopblog.gr
osirisdevelopment.com
Download :
BatteryBar v3.0
