Αγορα Δεκτη για Nova
Tι μου προτεινετε για αγορα δεκτη για χρηση πιο πολυ Nova;Τον θελω για δευτερη χρηση στο εξοχικο.:107:
panosop
Συστημικός
Απάντηση: Αγορα Δεκτη για Nova
DREAMBOX DM 100
αυτος με κόστος 130 ευρώ... :109:
1 Reader + ethernet + usb
MPEG-2 hardware decoding
2 x LED - status
1 x Smartcard-Reader
1 x Scart
1 x S-Video
10/100Mbit compatible Ethernet Interface
USB-B
S/PDIF Interface for digital bit stream out (AC-3)
unlimited channel lists for TV/Radio
channel-change time < 1 second
full automatic service scan
directly bouquet-lists
EPG (electronic program guide)
own videotext and subtitle
multiple LNB-Switching control (DiSEqC)
fully adaptable OSD in many languages
Picture in Picture (PIP) and Picture in graphics (PIG)
Zoom function
DreamBox DM100 technical data DBS-Tuner:
Frequency Range 950 …. 2150 MHz
Signal Level - 65 dBm …. - 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK
FEC Viterbi and Reed-Solomon
Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8
Roll-off Factor 35 %
Demultiplexing according ISO 13818-1
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB
USB:
USB 1.22:
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
LNB Power and polarisation:
LNB Current 500mA max. ; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
LNB shut-off at Standby-Mode
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 10W / 12V
Input voltage:
DC12V +/- 15%
Extern power supply:
Input: 110-240V AC / 50-60Hz / 0,6A
Output: 12V = / 1A or 2A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 195 mm x 130 mm x 30 mm
Weight: 540 g
Απο τι ειδα μου φαινεται πιο καλυτερος ο EDISION Trojan,εχει καλυτερα χαρακτηριστικα και γινεται και PVR.Λεει οτι εχει εξοδο HDMI αρα μπορω με ανταπτορα να το συνδεσω στην οθονη του Η/Υ που εχει εισοδο DVI-D;
panosop
Συστημικός
ναι μπορείς...
βεβαια ο Trojan δεν εχει Ethernet.
mgm
