Ανανεωμένο player από την Meridian: Signature Reference 808.2
Κώστας Φ.
Meridian has completely redone its Signature Reference 808 CD player, now the 808.2 ($14,995). "We've changed its drive, drive navigation software, power supply, DSP, and clocking and buffering. I'd like to say that the only thing we've retained is the case, but we've improved that, too," said Bob Stuart.
Meridian's proprietary Resolution Enhancement system upsamples 44.1/16-bit CD data to 176.4/24-bit with 48-bit internal precision, and applies a newly refined delta-sigma digital-to-analog converter system of reference accuracy. Stuart says that allows the 808.2 "to extract from the finest CD recordings a degree of transparency, detail, and musical life that simply must be heard to be appreciated."
The Meridian Signature Reference 808.2 comes in two flavors: standard and 808.2i. The difference? The standard Meridian 808.2 provides digital audio outputs in two formats, including an upsampled 88.2 kHz output that exploits Meridian's proprietary MHR resolution-enhancement system when connected via a compatible Meridian DSP Loudspeaker or surround processor. It also has two sets of analog audio outputs, which can be either fixed- or variable-level. The 808.2i ($15,995) adds analog and digital audio inputs, so it can function as a basic preamplifier in a simple two-channel system in conjunction with a power amplifier or active Loudspeakers.
blog.stereophile.com
  • loggeo
wendigo
