Ανοίγoντας ένα Intel-based MacMini
From this vantage point, the Mac mini hasn’t changed much from its previous version. However, there’s one gigantic change that may not be apparent from this angle: the easily-accessible RAM slot on the left side (A) is gone. Or to be more accurate, they’ve been turned on their side and hidden from view. (More on this in a moment.)
On the far side of the case you can see the new infrared receiver (B) right at the end of the optical-drive slot.
The Mac mini’s Bluetooth (C) and AirPort (D) antennae are still in place, although these versions seem a bit more robust than the we-just-taped-it-together feel of the previous model. There’s one other change that’s a bit hard to see from this photo, but it’s just beneath and behind the AirPort antenna (E): the Mac mini’s Bluetooth card, relocated to the top of the drive cage.
Next, we remove the drive cage (four screws, just like the previous model) and gingerly lift up, removing the interconnect card from its slot and disconnecting another cable carefully. Folding the drive cage back, we reveal the inside…
Things are a bit different under here. We’ve got two large heat sinks (F) (one for processor, one presumably for video circuitry). There’s a little perch (G) at the back for the new “penthouse” on port row, belonging to the audio-in and -out ports. Just below the interconnect slot (H) is the built-in AirPort Extreme card (J) (you can see the antenna snake off to the right). At the front left you can make out the two RAM slots (K), one on top of the other. SODIMMs slide right into here, laying on their side. It’s a tight squeeze, but SODIMMS like to snuggle, so it’s okay.
On the flip side, here’s the bottom of the drive cage. The 2.5-inch hard drive (L) is still here, although now it’s of the Serial ATA, rather than parallel ATA, variety. To the right resides our old friend the fan (M).
And that’s your lightning-quick, shotgun tour of the new Mac mini.
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
ουσιαστικά είναι σαν να πήρες ένα Centrino notebook και να το βάλαν να χωρέσει μέσα στο κουτί του MacMini...
Ά, ρε Apple... Από τα McIntosh στα McIntel...
Κ.Κωνσταντίνος
