Απο την CEDIA...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Ακολουθει ενας συνδεσμος απο το Αμερικανικο φορουμ με νεα προιοντα
(κυριως βιντεοπροβολεις και συναφη) καθως αυτα ερχονται με ανταποκριση
στους αναγνωστες τους
http://www.avsforum.com/avs-vb/showthread.php?t=1063274
Μην μεινετε μονο σε μια παρακολουθηση διοτι τα εκθεματα αυξανονται συνεχως...
Τα νεα της Stewart :
Stewart Filmscreen Introduces Window Treatment Product that Controls Home Cinema Noise.
Stewart Filmscreen Introduces Black Out Shade Window Treatment System.
- Stewart Black Out Shade is a custom roller shading system for controlling sunlight in commercial and residential applications.
Stewart Filmscreen Announces Contemporary Cabaret Screen For Media Room Installations.
- Sleek and attractive screen housing wall mounts and integrates into existing interior designs for a simple retro-fit screen solution
- Versatile and removable aluminum valance allows for customized choice of color and fabrics
- Features installer friendly options including choice of motors and easy set up adjustments from the screen housing’s front.
Stewart Filmscreen Announces The Oasis, a New Weather Resistant Screen For Outdoor Installations.
- The Oasis screen is electronically controlled and can be retracted when not in use
- Screen is resistant to corrosion and other outdoor elements
- Caters to the fast growing trend in outdoor entertainment
Stewart Filmscreen Introduces Stewart Media Décor, a New System to Display Art in Media- Centric Rooms.
- Stewart partners with Media Décor to provide a motorized art deployment system to decorate residential entertainment centers
- Customized artwork can conceal Stewart projection screens or flat panel TVs when not in use
- Choose from your own or the Stewart Media Décor collection for custom artwork selection
NEW THX PROJECTION SCREEN TESTING DELIVERS SUPERIOR BLACK LEVELS FOR GRAY SCREENS.
Stewart Grayhawk RS G3 is the First Gray Reference Screen to Pass THX Contrast Enhancing Tests.
The new GrayHawk G3 material uses an ultra-fine optical coating that is designed and optimized specifically for 1080p source material. Additionally, the G3 optical coating improves uniformity for consistent brightness across the entire screen. This unique feature, combined with the neutral density gray base, dramatically increases black levels, shadow detailing and overall color saturation, providing the viewer with maximum resolution and superb image quality. For the ultimate in acoustic transparency, a GrayHawk G3 screen can take advantage of Stewart's Microperf X2 technology, which was the first projection screen with acoustically transparent (AT) material to achieve THX certification.
DAMBO
