ΑLPINE PXE-H650, OEM Audio Processor
Κατ' αρχήν υπομονή μέχρι τον Αύγουστο του 2006!!!
Kάντε την εργοστασιακή πηγή στο αυτοκίνητό σας να παίζει όπως τα καλύτερα ALPINE!!!! 8) 8) 8)
Want your stock radio to sound like an Alpine? The PXE-H650 can do this for you – make factory radio sound like a high-quality Alpine unit. This audio processor lets you upgrade from your mediocre factory sound system. The PXE-H650 allows advanced sound tuning of factory equipment by correcting the acoustical problems in any vehicle. It’s equipped with AntEQ™, to remove the factory equalization, and Audyssey SoundEQ XT™, to optimize the sound quality of the system.
Once sound levels are balanced, and the system is tuned for optimum performance, Alpine amplifiers, speakers, and subwoofers can be added for a simple upgrade of your factory system, or go that extra mile and upgrade to a more complex system with complete multi-channel set-up! It's easy to upgrade from factory to Alpine!
fr3q_
