ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Ολο το home cinema σας σε ενα ζευγαρι γυαλια
(κι αν το χρησιμοποιησετε περισσοτερο απο την πρωτη φορα που θα το βαλετε, να μου γραψετε)
Features
* The sleek ergonomically designed glasses are comfortable and light weight, there size makes them ideal for portable use and they mobile.
* The LCOS 310K QVGA resolution micro display delivers a crisp vivid-color image enhancing your viewing experience
* Simulates the viewing experience of a 50” large screen monitor from a distant of 2m ideal for watching movies, viewing photos, listening music, and playing games
* Connections allow the device to be connected to a TV receiver, allowing you to enjoy your favorite television programs in private.
* The glasses allow you to enjoy your JPEG photos using an automatic or slide function mode
* Supports e-book .TXT file, allowing you to enjoy reading your favorite books anywhere, anytime
* A pair of phone jacks allow the use of high quality earphones
* Built-in Mini SD slot
* User-replaceable, rechargeable Lithium battery
* IR remote control, allows more convenient operation
* User-friendly U/I backlit control, use of controls even in dark environments
* USB interface allows easy loading of digital files to the device.
http://www.yellomosquito.com/Products/GP300.htm
