Για τον zoglair...
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Οχι, οχι, δεν γιορταζει σημερα.
Αλλα τοσα μας προσφερει αυτος ο ανθρωπος, να μην του κανουμε και εμεις ενα δωρακι?
Και επειδη γνωριζω πως τιποτα δεν τον συγκινει οσο ενα καλο review απο το projectorcentral του εχω την...δοση του
Οριστε, ο Sony VPL-VW60 αναλυτικα και οχι σαν τα δικα μας τα σαχλοτεστ:
http://www.projectorcentral.com/sony_vw60_home_theater_projector.htm
Διαβαστε εκει στο τελος τι λεει ο ανθρωπος:
So for now we can conclude by saying that if you buy the Sony VPL-VW60, odds are you will love it. However, the same can be said for pretty much all of the new 1080p models you have to choose from.
Πω,πω, εχω μεινει...
Το πραγματικό δώρο για τον Νικόλα είναι αυτή η παράγραφος που έκανες πως δεν την είδες ..:happy_9: :happy_9: :happy_9:
"A third 1080p competitor worthy of note is the Sanyo PLV-Z2000. The Z2000 is an LCD projector that has just begun to ship at prices under $2,500, or a whopping $2,000 below the VW60. Despite its much lower price, the Z2000 does a remarkable job going head to head with the VW60. We were able to calibrate the Z2000 such that it looks virtually identical to the VW60 in terms of color saturation, black level, and contrast. It is rare to find two different projectors (with two different display technologies) delivering almost identical images, but that is what we were seeing in this shootout. We just received the Z2000, and will have more to say about it once we've had more stick time with it. But it is not too early to say that the Sanyo Z2000 is offering a phenomenal value for the money. "
MaxHeadroom
Απάντηση: Για τον zoglair...
"Color balance out of the box using precalibrated operating modes is poor. In particular, the Cinema mode on our test unit was decidedly biased toward green and yellow/green. Even with color saturation set to zero, or with only the luminance cable in the component trio connected, what should have appeared to be neutral gray had a pronounced greenish hue."
Πάντως οφείλουμε να παραδεχτούμε ότι η Sony έχει σταθερή ποιότητα παραγωγής. :happy_9:
Kesus
