Για τους xboxάκηδες και όχι μόνο!!
Τί θα λέγατε για κάτι τέτοιο??
..και πως θα το πετύχετε??
Matrox TripleHead2Go Digital Edition
Experience Surround Graphics™
TripleHead2Go Digital Edition delivers the ultimate surround graphics experience for professionals and gaming enthusiasts alike. This versatile new product enables users looking to add three digital monitors to their workstation, desktop computer or notebook with a maximum resolution of up to 3840x10241 (triple 1280x1024).
The latest in Matrox's series of Graphics eXpansion Modules (GXM), TripleHead2Go Digital Edition is an external multi-display upgrade device that connects via the dual-link DVI or analog output of your system and can support both analog and digital monitors. Dramatically increasing Office Productivity for business professionals, providing an incredible Surround Design environment to high-end workstation users and delivering the most immersive Surround Gaming™ experience to gamers, the TripleHead2Go Digital Edition is the ideal solution for individuals looking for a truly digital-to-digital experience. Key features•Features a dual-link digital input for high-end workstations and DVI monitors. •Brings digital monitor support to systems with an analog (VGA) output.•Flexible device supports both dual-monitor configurations at a maximum resolution of up to 3840 x 1200 (2x 1920x1200)1 and triple-monitor configurations with a maximum resolution of up to 3840 x 1024 (3x 1280x1024)1 with digital or analog monitors.•Harness your existing graphics hardware's full capabilities for 2D, 3D and video.•Experience Surround Gaming by expanding supported 3D games across three displays; achieve a much wider in-game field of view.•Experience Surround Graphics and execute your workload faster by expanding your desktop across three displays.•Includes Matrox Monitor Bezel Management software feature for an enhanced gaming experience2.
1System dependent. See compatibility list.
2Available under Windows only.
Multi-display configurations
Use built-in display of notebook to achieve a quad display configuration.
Upgrade notebook to three external displays.
Upgrade integrated-graphics based desktop to three external displays.
Benefits of Monitor Bezel Management: Real life simulation
Matrox TripleHead2Go's Monitor Bezel Management technology is an exclusive software feature with the TripleHead2Go Digital Edition that effectively "hides" part of the image behind the bezel of your monitor, and creates the effect of a continuous image-bringing a new realism to gaming in particular to simulation-type video games. By selecting this option through the Matrox PowerDesk SE3 interface, race simmers for example, can see the race track with the race track lines fully aligned from the base leg without the monitor bezels hindering their view, and allowing them to have a "real-life" racing experience.
3For Windows only.
Without Monitor Bezel Management
With Monitor Bezel Management
Supported resolutions
DualHead display modes4
Resolution
Refresh Rates
2048 x 768
60Hz
2560 x 1024
60Hz
2720 x 768
60Hz
2880 x 900
60Hz
3200 x 1200
60Hz
3360 x 1050
60Hz
3840 x 12005
58Hz
TripleHead display modes
Resolution
Refresh Rates
1920 x 480
60Hz
2400 x 600
60Hz
3072 x 768
60Hz
3840 x 7204
60Hz
3840 x 7684
60Hz
3840 x 8004
60Hz
3840 x 9604
60Hz
3840 x 1024
60Hz​
4Resolutions available only under Windows operating system.
5Resolution available only with compatible digital panels.
Portability and installation
Light-weight and ultra-compact, you can easily take TripleHead2Go Digital Edition with you and experience all the benefits of a surround desktop at the office, at interactive customer design reviews or at LAN parties.
Unlike installing a new graphics card, TripleHead2Go doesn't require opening your computer, inserting parts into it, or replacing any hardware or software.
Setup is as easy as 1, 2, 3. Once the software is installed, it's basically just a matter of connecting your monitors.
For Windows users all mode setting is available through
Display Properties
-> Settings
Compatibility
TripleHead2Go Digital Edition is compatible with many professional and enthusiast class desktops and notebooks. A complete list of known compatible systems is available and will be regularly updated to reflect new system support.
Minimum system requirements•Dual-link DVI or single VGA output connector, on a compatible system•Microsoft® Windows® XP, Windows 2000, Windows XP x64bit, Windows Vista™ and Mac® OS X v10.4•Display driver supporting 1920 x 480, 2400 x 600, 3072 x 768 or 3840 x 1024 resolution•Powered USB connector*Under Windows 2000, when TripleHead2Go is connected to a notebook only the 3 external displays will be active - the LCD screen will be disabled.
Product informationDimensions:10 cm x 14 cm x 3.2 cm Weight:280 gramsConnectors:1x HD-15 (analog) for input, 1x DVI-I (digital) for input, 3x DVI-I (digital) for output, 1x USB for powerWarranty:2-year limited warrantyPart number:T2G-D3D-IF
Hardware included
•TripleHead2Go box
•One HD15-HD15 2' VGA cable•One DVI-DVI 2' cable•One USB cable•Quickstart paper and CD, which includes the following software:
- Install package
- PowerDesk SE (includes Image quality adjustment, center popup, window
management, Matrox Monitor Bezel Management feature, etc.)
- Electronic Product Manual
Availability
TripleHead2Go Digital Edition will be available in Q2 2007 for purchase. To register to receive an update on product availability by email, please visit our TripleHead2Go Digital Edition Availability Notification form.
Η πρώτη φώτο είναι απλά σοκαριστική...Σε αφήνει με τα μάτια στο πάτωμα και τα υπογλώσια στα χέρια...
ΥΓ.Θα προτιμούσα βέβαια αντί για race game να έδειχνε την Shattrath City αλλά τέλος πάντων...Διορθώνεται :p
δηλαδη τωρα πρεπει να ψαχνουμε για 3 ματσαρισμενους projectors
Συγνώμη , που είδατε ότι είναι για xbox ;
Κυρίως αναφέρεται στην πρώτη φώτο, αλλά δεν βρίσκω λόγο να μην μπορεί να συνδεθεί κάτι τέτοιο και με το xbox360!!:cool_4:
Γιατί απλούστατα οι κονσόλες βγαίνουν σε fix αναλύσεις ...
μόνο για PC και MAC είναι αυτά τα πράγματα , επειδή έτυχε να υπάρχει ένα xbox δεν σημαίνει ότι είναι και από αυτό ...
Οντως στην φώτο το xbox φαίνεται ανοιχτό ...
To video προέρχεται από την παρουσίαση του Forza Motorsport 2 για ΧΒΟΧ 360 στο Τόκιο.
Το βιντεο ειναι μονταζ σιγουρα.
Σε καποια φαση περασε ενας μπροστα απο την καμερα και δεν τον εδειρε κανενας...:happy_8:
Έτσι κι αλλιώς το ΧΒΟΧ360, όταν συνδεθεί με vga καλώδιο, διαλέγεις ανάλυση όπως ακριβώς σε pc και δεν είναι fixed!!
Υπάρχει και κάτι καλύτερο, το Virtual Racer X:
Έρχεται σε πλήρες σετ που περιλαμβάνει:
4 Xbox 360 Elites (while quantity's last)
4 Copy's Forza Motorsport2
Xbox 360 HD DVD player
Xbox 360 camera
Xbox 360 wireless headset
Microsoft Zune
Microsoft Force Feedback Steering wheel.
3 Sharp Aquos 37" LC-D62U 1080p HD LCD displays
Adjustable rear view Power Acoustik (PTM 750) 7" LCD display.
Bose Acoustimass 10 series surround sound system.
Harmon Kardon AVR-144 Surround Sound receiver
1500 Watt Tactile Vibration Feedback System.
1900 watt tactile power amplifier.
1" CNC machined polished aluminunm foot assembly that connects to the front of the VRX
Universal triple screen aluminium mounting bracket that excepts LCD displays from 20" to 40"​
Adjustable aluminium and tinted acrylic component shelves​
On board power bar and unique wire way system conceals cables.​
Polished chrome chassis with powder coated wheel mount, pedal mount and seat wings.
Front and rear non-slip aluminium vibration dampeners.
3M automotive chrome trim concealed edges.
Italian Sparco Monza racing seat (choice of Red/Black or Black/Silver)
Sparco automotive seat slider.
Suspension seat base.
3/D epoxy coated graphics.
Velcro and machined rubber grip blocks "prevents wheel and pedal movement".
10" diagonal and 8" horizontal wheel adjustments.
Polished Aluminium Speaker Mounts.
LED Lighting effects.
Beverage Holder
Προσωπικά μου άρεσε η οθόνη/καθρέφτης... Ε, ρε τρέλα!
Το 360 για να δείξει το panoramic view του Forza Motorsport, όπως είναι φυσικό θέλει 3 xbox360 σε δίκτυο 3 κόπιες forza και 3 hdtv's και να ενεργοποιηθεί η αντίστοιχη επιλογή από το menu του παιχνιδιού. Το κάθε Xbox κάνει output αυτά που του λέει η πρώτη κονσόλα (η Master) στην τηλεόραση του και έτσι δουλεύει το όλο συστηματάκι. Τώρα στο πάνω bundle γιατί λέει 4 xboxes που είναι άγνωστο. Μάλλον πρόκειται για λάθος.
H καρέκλα μου αρέσει περισσότερο , όσο για τα υπόλοιπα προτιμώ το σύστημα της matrox σε PC ...
ΥΓ 3 xbox ή 4 xbox ... Ελεος δλδ ...
Mε τα λεφτά αυτά δεν αγοράζω ένα Evo IX να το ευχαριστηθώ.....
Αλλο που μετά θα καταλήξω εγώ σε κανά νοσοκομείο και αυτό για πέταμα.
Γιατί όπως λέει και ο σοφός λαός μας " Τα μεταξωτά βρακιά θέλουν και επιδέξιους κ@λους"
Atoll
