Γκούχου, γκούχου, πάλι την κοπάνησαν ερωτικά κανάλια...
Μήπως πρέπει να πανε στο ΔΝΤ, γιατι για πτώχευση τους βλέπω...
Again disappeared erotic channels Theme-X
4 July 2010 again and again without any notice excludes the entire package of eight erotic Theme-X. This applies tp. 14 satellite Hot Bird 8 (13.0°E) on the frequency 11.470 GHz, pol. V, SR: 27500, FEC: 5/6. Again, nothing is known, what is the actual reason for the lack of communication channels Theme-X - is trying to determine the sender of the package. Probably it is a failure, but for the moment no confirmation of this information.
Unfortunately this is not the first time in recent years the problem for cardholders Theme-X. Recently it happened 15 June 2010, when for several hours excludes all channels Theme-X. In December 2009 without any major announcement channels Theme-X to replace the existing offer Sex View. This resulted in break week in the transmission and reduce the number of channels from 12 to 8, but at the same time increasing the number of openings and thereby reducing the number of repetitions on the other, by the way a bit by improving their quality. In February 2010 the frequency was changed, by the way by including another break - 10 days and in the same month two more times after three days due to problems on the broadcasting station. In late March, the frequency was changed again, this time without a break in the issue, but no announcement, so looking up you had to cope alone.
These breaks do not affect the best interest of journals Theme-X. Informally talk about the possibility of replacing the package Theme-X channels with better quality. It's also possible that the package once again change the frequency on 13E.
The Theme-X package included:
- Theme-X SOS 1 Hardcore,
- Theme-X SOS 2 Groups,
- Theme-X SOS 3 Fetish,
- Theme-X SOS 4 18,
- Theme-X Peep,
- Theme-X Bizarre,
- Theme-X Inter,
- Theme-X TransX.
Theme-X channels are offered in two packages of channels - card 4 channels and card 8 channels.
Αρχική πηγή δεν έχω, αλλά όντως την κοπάνησαν, το τσέκαρα το μεσημέρι...
Απάντηση: Γκούχου, γκούχου, πάλι την κοπάνησαν ερωτικά κανάλια...
Απο την σελιδα τους :
ThemeX Channels are not transmitting. Theme X have assured us that they are working to rectify the issue a.s.a.p. Apologies for any inconveniences.
Και τα Red Hot Sex την...κοπανάνε μεθαύριο 15, αλλά λένε ότι απλά θα αλλάξουν συχνότητα! Να τους πιστέψουμε άραγε;
Red Hot Sex TV on 15 July will change frequency
15 July will change the frequency of transmission channels of the Red Hot Adult Sex TV. 10:00 message will be carried out with tp. 115 (10.815 GHz, pol. H, SR: 27500, FEC: 5/6), which also means that probably will end this message with the frequency package Al Jazeera Sport channels Al Jazeera Sports HD 1, Al Jazeera Sports 3D, NBA TV and a few others.
No information, whether the issue will be pursued for some time from the old frequency, but it can be assumed that, therefore, cardholders must get ready for reprogramming of the receivers.
Technical parameters:
Hot Bird 6 (13.0°E)
tp. 115
Frequency: 10815 GHz
Polarization: H (horizontal)
SR: 27500
FEC: 5/6 (note - now package Al Jazeera broadcasting from FEC 3/4 - this parameter will change on 15 July)
DVB-S/QPSK
The transmission will be started only on July 15 at 10:00 am, with the result that search should be carried out later. Now, the Red Hot channels Sex TV are not yet available from the new location.
βασικα για εμενα αυτα τα καναλια πρεπει να φτιαξουν λιγο την ποιοτητα εικονας τους θα μου πεις τωρα τι ζητας αλλα πρεπει να το πουμε κι αυτο :137:
Δες το Fantasy στις 9*Ε.
Αλλη πανδαισια απο εκει.....
Παντως τα Theme X δεν τα βλέπω να επανέρχονται και...μαλλον φέσωσαν και τον Eutelsat μη πληρώνοντας το ενοικιο του πομπού....
Package of eight channels of erotic theme-X, which was available from the HOT BIRD 8 (13E), has been permanently disabled 1 July 2010. According to the latest information obtained by SAT Kurier magazine editors, the owner TYR Ltd has serious financial trouble and decided to close the deal. SatLink Communications, operating the transponder, once again did not receive timely payment for the use of satellite capacity and has decided to exclude a package of channels Theme-X.
Theme Pack channels erotic-X was available for the following parameters:
HOT BIRD 8 (13E)
11.470 GHz, pol. V, SR: 27500, FEC: 5 / 6, DVB-S/QPSK
It should be noted that customers have the opportunity to exchange cards Theme-X Card SCT (Satisfaction Channel TV). For this purpose, please contact the retailer where the card was purchased.
Subscribers to the package of 8 channels Theme-X will receive a subscription to eight channels of SCT.
Subscribers to the package of four channels-X Theme (SOS) will receive a subscription to five channels of SCT.
In any case, the customer will receive a free subscription time, what remained for him to pay Theme-X, and for additional time will be required to pay a surcharge. Detailed conditions for the exchange to be established with vendors.
info: satkurier.pl
Το FANTASY που βρίσκω εγώ (11938Η) είναι μόνο διαφήμιση. Ξέρετε κάτι που δε ξέρω?
Πσσσστ, φιλαράκι,
ξέρω κάτι αλλά ντρέπομαι να στο πω δημοσίως...:120:
:138::135::204:
Aργα το βραδυ ξεκιναει αλλα μην το βαλεις καλυτερα.
Θα μετανιωσεις.
Καλυτερο το Hustler TV 5*E, Dorcel TV 13*E k' Penthouse HD 19*E.
papaevagelouv
