Διακοπτης on of Για τελικο
Απάντηση: Διακοπτης on of Για τελικο
Alchemist HiFi Archive
Forum :: Range :: Updates :: Downloads :: Home
Home
About
Downloads
Designers
Contacts
Links
Forum
1st range
AA
ADM
Axiom
Forseti
Kraken
Maxim
Nemesis
Nexus
Product 8
"The"
TSD
Forseti Range Navigation
Alchemist Forseti APD20A Power Amplifier
Specifications | Images | Downloads | Design | Servicing | 2nd Hand Market
S P E C I F I C A T I O N S
Input Sensitivity (RCA): 1V
Input Sensitivity (XLR): 2.2V
Output @ 1kHz into 8 ohms: > 153 Watts RMS
Output @ 1kHz into 4 ohms: > 256 Watts RMS
Bridged Output @ 1 kHz into 8 ohms: > 409 Watts RMS
Frequency Response @ 3V o/p: -3dB @ 155kHz
Distortion @ 15v o/p, 1Khz: < 0.05% THD
Distortion @ 15v o/p, 10Khz <0.1% THD
Residual Noise: Typically 70 microV
Input Impedance: 8k ohms unbalanced, 25k ohms balanced
Dimensions (W x H x D): 464mm x 140mm x 400mm
Weight, Gross: 21kg
Pre/power combi
Front view
Input stage
Internal view
Internal view
Internal view
Inside top view
Output stage
Rear panel
Downloads:
Forseti Mk2 brochure (4.4MB) | Forseti Power Amplifier instruction sheet (1.88MB) | 8 page APD20a Mk II instruction manual | What Hi*Fi? review | HiFi World review | Forseti Bridging setup guide | Early Forseti brochure (6.13MB)
Design:
Twin mono design, class AB. Can be bridged mono to deliver over 400 watts RMS.
Servicing:
DO NOT ATTEMPT ANY WORK YOURSELF UNLESS YOU ARE COMFORTABLE WITH ELECTRONICS AND KNOW WHAT YOU ARE DOING
2nd Hand Market:
Sought after on its own by those with an existing Forseti Power Amplifier to allow their use in bridged mode or when paired with the Forseti Integrated Amplifier for bi-amping. Most commonly spotted second hand with the matching Forseti Pre-Amplifier though.
Original selling price: $2450-2499 (approx.)
Have you something to contribute to this page? Please contact the site administrator.
Information on this site is provided for information only. The use of the name "Alchemist" is in reference to Alchemist Products who ceased trading in 2001 and is not related in any way to audio products sold new today which bear the Alchemist name.
© 2003 - 2007. Site design/build by Joel Goodman
Κατα προτιμιση κατι σε ALPS .Υ.Γ Θα με βωηθουσε να μου λεγαται σηγκεκριμενο μοντελο ......
Καλημέρα. Το θέμα σου έχει ειδωθεί 60 φορές κι όμως, δεν έχεις πάρει ακόμα καμία απάντηση. Σκέφτηκες για ποιο λόγο συμβαίνει αυτό; Θα βοηθούσε πάντως αν ξεκαθάριζες τι ακριβώς θέλεις/ζητάς αντί να γράφεις προτάσεις και να παραθέτεις τεχνικά χαρακτηριστικά από sites.
Υ.Γ.: Η ορθογραφία σου βγάζει μάτια, πρόσεχε λίγο...
Ημίθεος
Χρειάζεσαι περιστροφικό, σαν αυτόν, για να ταιριάζει και το knob.
Ναι Ευχαριστω ,πως μπορω να τον παραγγιλω.
Μηπως μπορης να με βωηθισης να τον παραγγιλω γιατη δεν μπορω να βρω ακρη Ευχαριστω...
Nikos67
