gkontoletas
trouble in my brain
Αποστολή πρωτη SIM2 Grand Cinema C3X
C3X: Technical Features
Light Engine
DLP Type: 3 Chip DMDs HD2+ DC3
Resolution: 1280x720 pixels
Lens: High Quality, high resolution improved optics for higher contrast and better black level with both motorised zoom and focus adj.
Brightness: 2500 Ansi Lumens
Lamp power consumption: 250W
Installation
Throw ratio: 2,0-3,0:1 (standard lens - type T2) or 1,5-2,0:1 (type T1 on request)
Lens shift: half up picture =+50%
Digital keystone adjustment
Picture size (inches diagonal): 50-300
Aspect ratio: 4:3, 16:9 Anamorphic, LetterBox, panoramic, pixel to pixel + 3 custom-user adjustments
Electronics
Horizontal & vertical scan freq.: 15-80kHz/48-100Hz
SDTV: PAL (B,G,H,I,M,N,60); SECAM; NTSC 3,58; NTSC 4,43 automatically selected
HDTV: ATSC (480p, 720p, 1080i, 1080p); 576p + 1080i 50Hz
PC graphic standard: VGA, SVGA, XGA, SXGA, UXGA @ 65Hz
On Board Video Processing
Contrast ratio (Full ON/ Full OFF): 6500:1- typical
Inputs/Outputs
1 x S-Video (mini DIN 4 pins)
1 x Composite Video (RCA)
1 x RGBS-YCrCb (4 RCA)
1 x RGBHV (D-Sub 15 pin)
1 x HDMI-HDCP compliant
1 x OUT Digital Audio (Toslink)
1 x USB connector
1 x RS232 (D-Sub 9 pin)
2 x 12 V 100 mA (via jack)
1 x Input External IR sensor
General Specifications
Software control: upgradable via RS232 serial interface and USB
Weight: 11 Kg.
Dimensions (WxHxD): 435x190x430 mm
Supplied Accessories
Installation and User Manual
AC power cords (2m)
Backlit remote control and batteries HDMI cable (2m)
Standard Cabinet Colour: Gun Metal and Silver Gray
Optional Cabinet Colours: Coming soon
Light Engine
Installation
Electronics
Inputs/Outputs
1 x USB connector
Weight: 11 Kg.
AC power cords (2m)
