Επειδή τα έχω πάρει...Xtreamer ή EGreat???
Πάνω που αποφάσισα να μπω και εγω στον κόσμο αυτών των μηχανακίων και κατεληξα στο wd hd live δεν υπάρχει πουθενα διαθέσιμο και με πάνε απο βδομάδα σε βδομάδα ...δεν αντέχω άλλο και αυριο πρέπει να ψωνίσω κάτι...
λοιπόν τι λέτε Xtreamer ή EgreatM34A???
thnx anyway
Το Xtreamer με το νέο firmware 2.0 έχει πλέον περισσότερες δυνατότητες.
New features:
1. BD ISO playback support.
- Can’t supports menu navigation.
2. Change from SD UI to HD UI.
3. DTS HD Master Audio down-mixing and pass-through.
- Pass-through(5.1ch )
4. Dolby TrueHD down-mixing.
- Pass-through(5.1 PCM format)
- Direct pass-through (5.1ch) will be prepared soon.
5. Internet Radio.
A. “Internet Radio” menu added in main OSD.
B. *MyRadio* link to MyRadio folder in internal HDD first partition root directory.
C. .plsx extension detection support for internet radio.
D. Same file format for .pls and .plsx
E. User can use internet radio files residing in their internal or external HDD.
6. Photo thumbnail display.(in “Photo” menu)
A. Preview button toggles between “Preview off/Preview on/Photo Thumbnail” in “Photo” menu if there is any photo file in that folder.
7. Network virtual Remote Control.
A. URL http://xxx.xxx.xxx.xxx/rc for mobile device.
B. URL http://xxx.xxx.xxx.xxx/rc2.
C. Multilanguage support from keybord to search, rename etc.
D. Usable from PC/IPhone/mobile hand phone(including web browser)
8. Hostname Change Support
A. Web setup->DDNS/Hostname
B. \\hostname (to access Samba share), http://hostname:portnumber (to access web service).
9. UI effect sound.
- Setup->System->Effect Sound.
10. Video playback window size decreased in internet menu.
- Press zoom button to switch to middle size, full screen, small Screen.
11. Zoom and navigation support for Weather map in internet -> weather menu.
12. Home menu UI can support multi language.
Improvements:
13. Improve HDMI compatibility.
14. Audio volume normalize.(except AAC, WMA pro).
15. Network playback streaming speed up.
16. Change Music Jukebox UI.
17. Change weather UI.
18. Change video playback information window.
19. Change wireless Network UI.
20. Increase subtitle window size
21. Changed loading image for internet menu.
22. Changed keyboard UI for internet menu.
23. Reduced changing time between wireless and wired network.
24. Language added (Arabic, Estonia, Hungarian, Slovenia, Vietnam) in web interface.
25. Internet Video preview displays current time/total time and progress bar with buffering bar.
26. Fan speed manual setting from 0 ~ 200.
27. UTF8/UTF16 auto detection when no selection of Unicode in SUB-T/ID3TAG .
28. After pressing “Enter” button on video file, direct playback while preview is on.
29. Detection of external ODD improved.
A. If can’t detect, go to “Home” and press “Eject”. It will retry to detect.
B. To eject DVD go to “Home” menu and press “Eject” button(when DVD is detected).
30. Fast forward from 0.8x to 2.0x displays subtitle also.
31. Delete function added to remote control “Delete” (3) button.
32. Change folder/file list in alphabetically order.
- A, A1, C4, a2, b3 -> A, A1, a2, b3, C4.
Bugs fixed:
33. 24p cinema mode
34. FLAC file playback including id3tag.
35. Support MKV internal idx+sub subtitle.
36. Movie including FLAC audio codec playback support.
37. Sometime crashes when displaying Folder JPG in preview window.
38. Max 16 character input in keyboard changed to Max 128 character
39. Direct numbers input from remote control to keyboard.
40. DEL/SP key problem fixed for Chinese keyboard.
41. After returning from NAS Mode, photo crash problem fixed.
42. Audio file play problem solved from UPnP client.
43. Play/Pause both works for Internet Video playback.
44. Rumania code page changed.
A. ISO-8859-2 -> ISO-8859-16
45. Chinese missing character support.
46. Samba Share of windows 7 can’t be seen.
47. Center alignment of Arabic subtitle.
48. No subtitle displayed while playing video if 1080P 24Hz set from setup menu.
49. WPA key 64 characters not display.
L
LLLEFTERIS
Απάντηση: Επειδή τα έχω πάρει...Xtreamer ή EGreat???
Το Extremer μονο στο Multirama και στο Πλαισιο υπαρχει?
Αν δεν κανω λαθος περνει 2.5 δισκο μεσα. Εξωτερικο μπορει να δει και 2 TB?
(Θελω να παρω ενα για την γυναικα μου για την κρεβατοκαμαρα γιατι εχω πολλες ταινιες σε mkv και οταν καθομαστε στο σαλονι να τις δουμε με το LG BD390 την περνει ο υπνος και που να την κουβαλαω μετα μεσα στην κρεβατοκαμαρα εγκυο γυναικα!) :116:
Re: Απάντηση: Επειδή τα έχω πάρει...Xtreamer ή EGreat???
Στις προδιαγραφές αναφέρει τα 1,5 TB, ίσως όμως να βλέπει και των 2 ΤΒ.
Σορρυ για την παρεμβαση το popcorn σε σχεση με αυτα που υστερει?
lakiss51
Ωραιος ο Λευτερακης! Δε λεει οτι θελει την ησυχια του:135:
Εχω την αποψη οτι Popcorn καλυπτει απολυτα τις αναγκες μας - δεν το εχω αλλα με Egreatια και WD επαιξα και δεν...
Μήπως εννοείς το καινούριο Popcornhour C-200;
Γιατί το παλιό (το Α-110) τις ίδιες δυνατότητες έχει με το Egreat.
lakiss51
Απάντηση: Re: Απάντηση: Επειδή τα έχω πάρει...Xtreamer ή EGreat???
Το νεο ειναι...ασυμφορο (κοιταω προς Dune), εννοω το 110 που διαφερει απο το 31Β (που το εχω!)
Re: Απάντηση: Re: Απάντηση: Επειδή τα έχω πάρει...Xtreamer ή EGreat???
Σε δυνατότητες τα ίδια είναι, αφού έχουν το ίδιο firmware, απλά το Μ31Β έχει επιπλέον θύρα e-sata και διακόπτη για να κλείνει, δυνατότητες που στερείται το Α-110.
Σ' αυτό το thread, όμως αναφέρονται στο Μ34Α, λόγω της χαμηλότερης τιμής του (από δυνατότητες αναπαραγωγής κι αυτό τις ίδιες έχει).
εγώ πάντως το Σάββατο το τσίμπησα το xtreamer και όλα καλά!
το μόνο που θα του πάρω είναι η ψύκτρα που κυκλοφορει στο εξωτερικο για να βγάλω off το ανεμιστηράκι που μου την σπάει λίγο....!!!
Καλή είναι και η ψύκτρα, αλλά και το ανεμιστηράκι, αν το βάλεις στο "χαμηλό" δεν ακούγεται πλέον.
Άσε που με το καινούριο firmware μπορείς να επιλέξεις μόνος σου τις στροφές.
Για την ιστορία και μόνο, το Α-110 έχει διακόπτη για να κλείνει και ποιοτικότερα κυκλώματα αποδεδειγμένα και όχι προσωπική μου άποψη.
Μια χαρά το Εgreat αλλά εγω λέω αν βρείς Πάρε το WD HD Live τελικά,όλο και κάποιο μαγαζί θα το έχει,το είχανε πολλά δεν γίνεται χαθήκανε όλα αέρα ! ?
Υπογραφή ...
Προς Ρωμαίους 10/ι/9
"εάν ομολογήσεις διά του στόματος σου τον Κύριον Ιησούν, και πιστεύσης εν τη καρδία σου ότι ο Θεός ανέστησεν αυτόν εκ νεκρών θέλεις σωθεί."
papaevagelouv
