Επιστροφή της Systemdek..
Κώστας Φ.
...με τον υιό του Peter Dunlop "στο τιμόνι".
Ιδού και το Systemdek IIID:
Περισσότερα στο τελευταίο Stereophile.
Επιτέλους θα μπορώ να βάλω original ιμάντα στο δικό μου (να πάρουν τα πάνω τους οι χροιές).. :136:
Απάντηση: Επιστροφή της Systemdek..
άμα είναι έτσι και όντως παίρνουν τα πάνω τους οι χροιές με αυτόν τον ιμάντα, να πάρεις και για μένα έναν ιμάντα να τον ρίξω πάνω στο σκληρό μου δίσκο...:137:
Απάντηση: Re: Επιστροφή της Systemdek..
Ναι ρε τι σε λέω; Τσεκαρισμένο!
:612:
Iomega Corporation has recently introduced an amazing ultra portable Hard Drive, the Iomega eGo BlackBelt Portable Hard Drive with superb features that lets you transfer high volumes of data at stunning high speeds.Iomega eGo Black Belt Portable Hard Drive overviewThis Portable Hard Drive comes with the Iomega Drop Guard Xtreme features, which provides an unchallenged durability and protection. The most amazing part of the Drop Guard Xtreme is that it protects the Hard Disk from a 7-inch fall!
The Iomega eGo BlackBelt Portable Hard Drives are available from capacities ranging between 160 GB to 2TeraBytes. With such high volumes of data storage, you have a lot of space for your memorable photos, favorite videos, music and much more.
The additional plus point of the Hard Disk is that it does not require any kind of any external power for its running so no more hazels of power wires and power cuts! The package of Hard Disk features a free EMC® Retrospect® and MozyHome™ Online backup software for additional measure to prevent any loss of data (up to 2GB of data backup).
The Iomega egos Portable Hard Drive is available in a stylish black colored compact design with a Power Grip back, which can easily fit in a black briefcase. Following are the accessories availed on purchase of the Hard Disk
* USB 2.0 power cable for rapid data transfers
* Quick installation guide and user manual for guidance to installation features
* Backup software license, the software can be downloaded via computer
* McAfee 30 days Free Trial Version
* Sleek dimensions measuring .75" x 3.5" x 5.25" (L x W x H) and weights only 0.48 lbs
* Rapid data transfer at speed of 480 Mbits/s
The Iomega eGo BlackBelt Portable Hard Drive comes with a 3 years of warranty, which can be extended by paying certain amount. For more Information and to know where to buy this wonderful Hard Disk
x x x BLOODBATH x x x
