Εργαστηριακή συμπεριφορά του Tripath
http://www.stereophile.com/solidpoweramps/1006sonic/index4.html
"Peculiarly, the Super T is more linear at low frequencies into low impedances than it is into high ones (fig.5). Above 1kHz, however, the amplifier clearly has trouble maintaining its linearity into all loads. Looking at the distortion content without the low-pass filter engaged, what appears to be subjectively innocuous third-harmonic content is overlaid with spikes that coincide with the signal's zero-crossing points (fig.6). Switching in the low-pass filter smooths these spikes over (fig.7) but doesn't eliminate them, confirming that they are characteristic of the Sonic Impact, not the result of any unwanted interaction between the ultrasonic noise in the amplifier's output and my Audio Precision test set.
What was interesting was that these spikes are not present with the Super T passing low frequencies. Fig.8, for example, shows a spectral analysis taken with the low-pass filter of the amplifier's output while it drove a 50Hz sinewave at relatively high power into 4 ohms. The second harmonic is the highest in level, at an excellent –83dB (0.007%), with the third and fifth harmonics lying at –90dB (0.003%). (These odd-order harmonics disappear if the load impedance is increased to 8 ohms, leaving just the benign second harmonic as the primary spurious component.) But with a 1kHz sinewave at the same power into the same load, again with the 30kHz low-pass filter in front of the analyzer's input (fig.9), the third is now the highest-level harmonic, at –66dB (0.05%), and some high-order components can be seen, correlating with the spikes seen in the waveform graph.
Λάθος τίτλος! Το όνομα "Tripath" προς το παρών εκπροσωπεί μια ολόκληρη τάξη λειτουργίας ενισχυτών, την τάξη Τ.
Καλύτερα θα ήταν με τον εξής τίτλο: "Εργαστηριακή συμπεριφορά του Super T".
Φαντάσου ανάλογα, τον εξής πχ τίτλο:"Εργαστηριακή συμπεριφορά ενισχυτών τάξης ΑΒ", και να είχες σε λινκ ένα "σαμιαμίδι" 4βατ, μια άθλια υλοποίηση, με κάκιστα υλικά και δείγμα τροφοδοσίας, ανάξια να χαρακτηρίζει προφανώς την τάξη αυτή λειτουργίας ενισχυτών...
Όχι ότι μου καίγεται καρφί βέβαια, αλλά λέμε τώρα..... :lol: :lol: :lol:
"ατόφιο το τσιπ της Tripath" το χρησιμοποιούνε όλοι εκτός από μένα (σπάω το καπάκι και κάνω αλλαγές και εκεί μέσα).
Αλλά σκέτο το τσιπ δε κάνει τίποτα, οδηγεί εξωτερικά φετ, και το evaluation board ακόμα και στα μεγάλα κομάτια είναι με χάλια υλικά.
Έλα και μια καλή ιδέα, γιατί σε συμπάθησα 8) 8) 8)
Πόσο κοστίζει ένα καλό τροφοδοτικό για αυτά τα μικρά τσιπάκια της tripath? Μπορεί να χρησιμοποιηθεί με μπαταρίες? Ποιές μπαταρίες? Τι μπορούμε να κάνουμε καλύτερο από τις 4 ΑΑΑ που έχουν κάποια ενισχυτάκια ενσωματωμένες?
Η λύση είναι ένα φτηνό UPS, αλλά όχι με την τυπική του χρήση.
Ακολουθήστε βήμα βήμα:
1.Δίνεις 80-100 ευρώ και αγοράζεις ένα ωραιότατο UPS των 800 ή και παραπάνω βατ (με 100 αγόρασα ένα στα 1200 VA).
2. Παίρνεις δυό καλώδια ηχείων ικανής διατομής (φτηνά αλλά χοντρά) και με καλό ανθεκτικό στις καταπονήσεις πλαστικό περίβλημα, και τα κολλάς (από την μια άκρη :lol: :lol:) σε ένα βύσμα, σαν αυτό που θέλει ο ενισχυτής σου στην είσοδό του για τροφοδοσία συνεχούς ρεύματος 8-13,8V).
3.Παίρνεις ένα κατσαβίδι.
4. Ανοίγεις το UPS (τα γράφω πολύ αναλυτικά, για να καταλάβεις... :lol: :lol:)
5. Περνάς προσεκτικά από τις γρύλιες του UPS (από έξω προς τα μέσα) τα ελεύθερα άκρα των καλωδίων που κόλλησες πριν το βύσμα. Αφήνεις το βύσμα απ'έξω (κατάλαβες ή να το ξαναπώ? :lol: :lol: :lol:)
6. Βλέπεις τη μπαταρία και πιάνεις ένα καλώδιο στον θετικό πόλο της κι ένα στον αρνητικό. Σφιχτές - καλές επαφές. Ικανής διατομής αγωγός. Προσοχή για βραχυκύκλωμα, είναι πολλά τα αμπέρ άρη.... Στον θετικό αγωγό πιάνεις το καλώδιο που θα δώσει τη θετική τάση στον ενισχυτή σου, και πρέπει να βρεις ποιό είναι αυτό. Το αναφέρει το μάνιουαλ του ενισχυτή. ( συνήθως είναι ο εσωτερικός αγωγός του βύσματος τροφοδοσίας)
7. Ξαναπιάνεις το κατσαβίδι και βιδώνεις το καπάκι του UPS.
8.Τέλειωσες.
Όποτε θες να φορτίσει η μπαταρία, βγάζεις το αυτοσχέδιο βύσμα από τον ενισχυτή και βάζεις το UPS στην μπρίζα.
Όποτε θες να ακούσεις μουσική, βγάζεις το UPS από την μπρίζα, το κλείνεις το UPS (να μη σφυρίζει και να μη παράγει εναλασσόμενη τάση 220V στην έξοδό του), μετά το συνδέεις με τον ενισχυτή και ακούς μουσική.
ΠΟΤΕ δεν συνδέεις τον ενισχυτή με το UPS όταν αυτό είναι στην μπρίζα ή όταν είναι αναμμένο για να έχει 220V στην έξοδό του.
Η μπαταρία αντέχει για αιώνες ακροάσεων έτσι.....τουλάχιστον σε σχέση με τις ΑΑΑ δεν υπάρχει ...σχέση!
Το κόστος είναι μικρότερο της κατασκευής ενός απλά έντιμου τροφοδοτικού.
Τζετ σετ δηλαδή!
Kostas Ear, άμα καταφέρεις να τον κάνεις κάρβουνο, κερνάω τα μετά. :lol: :lol: :lol:
platon
Μπραβο Κωστα, καλη σκεψη, θα το δοκιμασω.
Εσυ το εχεις δοκιμασει ή στο ειπανε? Γιατι δε νομιζω, στους τελικους σου να εχεις συνδεσει μπαταριες!!!!! :lol: :lol: Ποσα βατ εχεις ειπαμε?????? :) :D
Αντωνης Σοφιανοπουλος - Ροδος
g.Kar: δύσκολο να καρβουνιάσεις Tripath, θέλει πολύ επιμονή, μεράκι και ....επιδεξιότητα! Έχουν πολλές ασφάλειες τα άτιμα!
Platon: Ούτε το δοκίμασα, ούτε μου το είπανε! Έχουμε και δημιουργική φαντασία που λένε,.... :lol: :lol: :lol: :lol:
Είχα μια σκέψη βέβαια να παίξω και τους δικούς μου με μπαταρία, αλλά δύσκολο να μαζέψεις 100 βολτ με μπαταρίες!
opanamas
