Εχω αυτα Tannoy Sensys 1
Ειναι αστρωτα τα ειχα στο δευτερο σαλονι και δεν λειτουργησαν ποτε ,αγρατζουνιστα αστρωτα σε μαυρο χρωμα στα 150 ευρω
Bass port? Rear reflex
Biwireable? Yes
Connections 4mm banana plug/Binding posts
Crossover frequency (kHz) 2.7
Drivers LF: 175mm (7") multi fibre paper pulp cone HF: 25mm (1") 25-micron titanium dome, neodymium magnet
Extra Wideband frequency response - ideally matched to conventional hifi and home cinema and the latest DVD-Audio and SACD sources. 15mm particle board cabinet, internally cross-braced with 15mm baffle
Finish Maple
Frequency response (Hz) 49 - 51,000
Magnetically shielded? Yes
Nominal impedance (ohms) 8
Power handling (watts) 75 RMS continuous power handling, 225 peak power handling
Recommended amp power (watts) 20 - 100 RMS
Sensitivity (dB) 88
Supplied accessories Removable front grilles
W x H x D (mm) 210 x 350 x 292
Weight (kg) 7
