ΗΧΕΙΑ PROAC Response D25
Πωλούνται ηχεία ProAc Response D25 YEW , αγορασμένα το 2004 σε άριστη κατάσταση.
Τιμή: € 3300
Specification
Nominal Impedance 8 ohms
Recommended Amplifiers 10 to 200 watts
Frequency Response 20hz to 30Khz
Sensitivity 88db linear for 1 watt at 1 metre
Bass/Midrange Driver 61⁄2” (165mm) ProAc unit with coated polypropylene cone on die-cast chassis
Tweeter ProAc 1” (25mm) soft dome with special surround and inner damping
Crossover HQC crossover using dedicated components wired throughout with multistrand
oxygen-free cable. Split for optional bi-wiring and bi-amping.
Dimensions 42” (1066mm) high on plinths with conical feet
83⁄4” (222mm) wide
10” (254mm) deep
Weight 57 lbs (26kg) /cabinet
Mode Floorstanding
Grille Acoustically transparent crimplene
Finish Available in the following real wood veneers: Black Ash, Maple, Mahogany,
Cherry, Yew, Ebony, Bird’s Eye Maple and other finishes to special order
Gianni Tab
