Πωλούνται λόγω μετακόμισης τα παρακάτω. Όλα σε άριστη κατάσταση. τηλ. 6974310046
B&W 604 S2 – 720€ (Μαύρα)
Frequency Response at 3dB 39Hz - 22kHz
Amplifier Power Range 25W - 200W
Dimensions (HxWxD) in mm 994x236x398
Finish Black, Sorrento & Calvados
Nominal Impedance 8 ohms
B&W 602 S2 – 320€ (Μαύρα)
Type: 2 way, 2 driver loudspeaker system
Frequency Response: 43Hz to 30kHz
Recommended Amplifier: 25 to 120W
Crossover Frequency: 3000Hz
Impedance: 8Ω
Sensitivity: 90dB
Midbass: 1 x 180mm Kevlar cone
Tweeter: 1 x 26mm metal dome
Enclosure: bass reflex
Grille: black cloth
Finish: black ash
Dimensions: 490 x 236 x 306mm
Weight: 9.8kg
B&W CDM7 – 380€ (RealWood)
3-way 4th-order vented-box system
1 x 25mm (1in) alloy dome - high
1 x 165mm (6.5in) kevlar® - b a s s / m i d r a n g e
1 x 165mm (6.5in) Cobex bass
40Hz - 20kHz ± 3dB on re ference axis
90dB spl (2.83V 1m)
8 ohms (minimum 4 ohms)
30 - 150W into 8 ohms on unclipped programme
Height: 950mm Width: 220mm Depth: 290mm
1 8 . 5 k g
Κεντρικά ηχεία:
B&W CDM CNT 260€ (Μαύρο)
2-way vented-box system with magneticshielding
1 x 25mm alloy dome high-frequency
1 x 165mm woven Kevlar® cone bass/midrange
50Hz – 20kHz ± 3dB on reference axis
91dB spl (2.83V, 1m)
50W - 120W into 8 ohm on unclipped programme
Height: 300mm Width: 460mm Depth: 290mm
ROGERS C33 (Μαύρο) 100€, 100 watts, 3 μεγαφώνων (2 woofer 110mm polyme doped paper, 19mm tweeter polymer done), μαύρο χρώμα, απόκριση συχνότητας 80Hz-20Khz +-3db, 8 ohms, 88db. Διαστάσεις 500 x 165 x 183mm, 5,5 Kg.
Περιφερειακά ηχεία, Crystal Audio System6 -260€ (Rosewood)
Impedance: 8Ω
Sensitivity: 90dB
Grille: black cloth
Finish: black ash
Weight: 9.8kg
90dB spl (2.83V 1m)
1 8 . 5 k g
Κεντρικά ηχεία:
107,8 KB Προβολές: 0
136 KB Προβολές: 0
79,9 KB Προβολές: 0
112,9 KB Προβολές: 0
