Η 4θυρη Aston Martin Rapide βγαίνει στην παραγωγή!!!
The Aston Martin Rapide concept is a four-door, high performance coupe of remarkable grace and poise. It stands for stylistic excellence, market innovation and flexible manufacturing. The Rapide is the epitome of Aston Martin’s low-volume, high-technology approach, the synergy of modern methods and materials with traditional skills to create a new form of craftsmanship for the 21st century.
In early February, it was reported that the Aston Martin Rapide Concept was nearing approval for production. Later that month, supplier sources told a U.S. magazine that the car had been approved, and 3,000 units per year would be built. The ones who don’t have enough money to buy this beauty start saving as it will be launched in 2008 leaving you enough time.
The design ethos is distinctive and elegant. Sitting low to the ground, just four centimeters higher than a DB9, the interior is an exquisite leather-swathed package, with custom-embossed shagreen hide specially sourced for the Rapide. With bodywork that is taut, poised and muscular this one is quite a catch! This 4-door coupe is a car that will complement your style and every journey in an Aston Martin is an occasion, proving that the most enjoyable way of getting between two points isn't always a straight line.
Άκη, λες μαζί με την Aston να δίνουν και την κυρία δώρο??
Αν και δεν μου φαίνεται για Αγγλίδα!!!!!!!! :lol: :lol: :lol: :lol: :lol:
Λέτε ο νέος James Bond να έχει και παιδιά?? Και χρειάζεται οπωσδήποτε 4θυρο αμάξι??? :lol: :lol: :lol: :lol:
ΑΑΑΑΑΑΑΑΑΑΑΑαααααααααααααααααααααχχχχχχχχχχχχχχχχ....
Και δεν πάω στο Goodwood φέτος να τα δω, όπως φαίνεται...:(:(:(:(:(:(:(:(:(:(
Μπορεί να ανοίξω ένα θέμα για αυτό, με φώτος που έχω πάρει από το παρελθόν... :cry: :cry: :cry: :cry:
http://www.goodwood.co.uk/fos/intro/supercars.htm
Χ...καμε για την κυρία (με το συμπάθειο)
Αν έχεις την Aston, γκόμενες 10 φορές σαν κι' αυτή θα πηδάνε μέσα από τα παράθυρα. (και οτιδήποτε άλλο)
Τώρα βέβαια αν θέλουμε τέτοιες γκόμενες, που πηδάνε πάνω σε όποιον λεφτά βρουν, γούστα είναι αυτά.;) Εγώ ας πούμε θα ήθελα να είχα μια AMV8 ή μια Vanquish και να την οδηγούσα σε έρημους φιδωτούς δρόμους πάνω σε κανα βουνό. Αλλά τεσπά...:D
Μιας και είδα μια DB9 σήμερα στην Κηφισίας, τιμής ένεκεν, πάρτε μια φώτο...
Άκη, πάρε το 1ο τεύχος του (Ελληνικού) TOP GEAR που έχει δώρο ένα DVD με εκπομπές του γνωστού (και κορυφαίου) τηλεοπτικού περιοδικού TOP GEAR Αγγλίας (με τον πασίγνωστο, θεόμουρλο Jeremy)
Έχει μέσα κάτι που θα σου αρέσει πολύ!!!! :D
Επειδή βλέπω ανελλιπώς τις εκπομπές Top Gear στο BBC εδώ και χρόνια, ακόμα και τώρα που είμαι στην Ελλάδα, έχει τίποτα παραπάνω;
teamwork
