Η G70 είναι γεγονός (7800 Gtx)!!!!
Οι προδιαγραφές για τον νέο επεξεργαστή της Nvidia είναι γεγονός.Η νέα κάρτα που θα κυκλοφόρήσει θα ονομάζεται Geforce 7800 GTX και αναμένεται να κάνει την εμφάνισή της στις 22 Ιουνίου.
Nvidia 7800 GTX
Core Speed
430 Mhz
Memory Speed
1.4 Ghz
Memory
256MB / 512MB
Memory Bandwidth
38.4 Gb/s
Pixel Pipelines
24
Fabrication Process
0.11
Και το άρθρο από το pureoverclock.com
I’ve just been told from a very, very reliable source that the G70, Nvidia’s next generation card will officially be called the 7800 (we all new that, didn’t we?). It will initially be available in three versions , the 7800 GTX, 7800 GT and 7800 and they will be launched on the 22nd of June. I've just been told the new GTX moniker will NOT replace the Ultra. An overclocked GTX will come some time after launch and this will be known as the 7800 Ultra. The Ultra may possibly be Nvidia's first 90nm part.There was speculation that the G70 would be a 90nm part but it appears- at least at launch - that it will be built on their 110nm fabrication. I’ve also been told that SLI will only be possible with the GTX model and above. There's a neat little rumour going round that the 7800 got its name entirely down to the 3D mark 2005 score it is capable of. Take that one with a pinch of salt though.
Power supply demands have stayed the same as far as I can tell, with a single GTX warranting 400 watts and 24 amps on the +12v rail and two GTX’s in SLI needing a 500 watt PSU and 34 amps on the +12v rail. It’s not yet clear if 512MB cards will actually be ready for launch. There is currently no word on pricing either
Ορίστε και μια φωτογραφία από την προτώτυπη κάρτα της NVidia :
Καθώς και η νέα ψηφιακή κοπέλα της Nvidia
Η καρτα δεν παιζεται αλλα η τιμη ειναι τσουχτερη 600 δολλαρια περιπου,βεβαια αυτη η τιμη θα πεσει.Το σημαντικο ειναι οτι NVidia εχει στραφει σε ακριβες υλοποιησεις και αυτο δεν ειναι οτι καλυτερο για το ευρυ κοινο.Απο την αλλη ολα αυτα και καινουρια καλουδια ειναι τοσο δελεαστικα που μονο αδιαφορο δεν σε αφηνει. :D :D :D
Φίλε babilon
Η τιμή της στην Ελλάδα (ναι έχει κυκλοφορήσει και εδώ, σχεδόν παγκόσμια) είναι για καινούργιο προιόν στα 550 ευρώ (από όσο θυμάμαι οι πρώτες κάρτες της σειράς 6 της Nvidia είχαν 600 ευρώ και πάνω!) και είναι πολύ καλή (παρολλά αυτά τσουχτερή για κάρτα γραφικών) για πρώτη τιμή παρουσίασης.Οπότε αυτό είναι θετικό στο να πέσουν και πιο γρήγορα οι τιμές (50+ ευρώ διαφορά δεν είναι και λίγα) των ακριβών μοντέλων και οι low end κάρτες της σειράς 7 να έχουν πιο χαμηλές τιμές.
Με μια γρήγορη ματια στα ελληνικά e-shop βρήκα την 7800 στο Multirama στα 550 ευρώ
VGA POINT-OF-VIEW PCX GEFORCE 7800GTX 256MB TDH GDD3 SLI
Η νέα κάρτα γραφικών της Point Of View με το τελευταίο chipset από την NVIDIA Ge Force 7800GTX , ενσωματώνει όλα τα πλεονεκτήματα της τεχνολογίας PCX αλλά πλέον έχει το χαρακτηριστικό σύνδεσης SLI.
To SLI επιτρέπει την γεφύρωση δύο ίδιων καρτών διπλαδιάζοντας έτσι της επιδόσεις στο σύστημα γραφικών του υπολογιστή.
Συνοδεύεται από 5 παιχνίδια :
Splinter Cell Chaos Theory
Far Cry
Thief 3
Shellshock
Pacific Fighters
Γιαννη επειδη ενδιαφερομαι για την συγκεκριμενη καρτουλα πηρα ενα τηλεφωνο στα Multirama και μου ειπαν κατοπιν παραγγελιας και μετα απο 10 μερες.
Να πουμε οτι η καρτα πεταει. Που να βγει και καμια Ultra εκει να δεις πανηγηρια.
Αν και απο οτι ακουσα η απλη7800 δεν εχει τρελη διαφορα ταχυτητας με μια 6800 Ultra.
Να πουμε και για το SLI δυο πραγματα:καταρχην δεν ειναι κατι το καινουριο το χρησιμοποιουσαν και παλιοτερα αλλα δεν "επιασε" τοτε(αν δεν κανω λαθος το ειχε λανσαρει η Voodoo) ,τωρα με την προωθηση που κανει η nVidia κατι παει να γινει.
Δευτερον και σημαντικοτερο ειναι οτι διπλασιαζει τις επιδοσεις θεωρητικα! δηλαδη δεν προκειται να παρεις τα διπλασια FPS με τιποτα.Στην ουσια ειναι σαν να εχεις αλλη μιση καρτα το πολυ! συνηθως παιρνεις λιγο πανω απο το 1/3.
Και τριτον δεν νομιζω να αξιζει να δωσεις μια μικρη περιουσια οταν σε 4-5 μηνες θα βγει ενα καινουριο μοντελακι που θα σκιζει ολα τα προηγουμενα.
Babilion
πλάκα έχει που δεν το γράφει (μια ζωή αυτά τα sites όλο ελλείψεις...).Τουλάχιστον στο e-shop γράφει ότι είναι εξαντλημένο το προιόν.Τι να πεις!
Επίσης στo παρακάτω link μπορείς να δεις επιδόσεις από τον νέο επεξεργαστή της Nvidia
vr-zone NVIDIA GeForce 7800 GTX Review
Επίσης ακούγεται ότι δεν θ ακυκλοφορήσει έκδοση AGP με αυτό τον επεξεργαστή :(
Babilion
Φιλε Γιαννη εχεις απολυτο δικιο το ειδα και εγω και κουφαθηκα.
Δυστυχος φαινεται οτι το AGP παει για αποσυρση :( αν και το PCE δεν εχει δειξει ακομα τιποτα το φοβερο.Θα δουμε το μελλον μας επιφυλασει πολλα ακομα :D
gkontoletas
trouble in my brain
Σπύρος Μπλάτσιος @ 21st September 2005 said:
2 πυρήνες στην cpu , 2 gpu, 2 τροφοδοτικά για να δουλεύουν όλα αυτα κλπ κλπ
που πάμε ρε παιδια???
Το μόνο που μπορώ να προσθέσω είναι ότι δύο εταιρίες παρουσίασαν τροφοδοτικά με ονομαστική ισχύς 1KVA (Enermax και η PC Power & Cooling)
Να δωσεις ομως τοσα λεφτα....
Για ποιο λογο? Για παιχνιδια?
Μην τα λες αυτά Γιώργο...κάποιοι είπαν κάποτε ότι δεν χρειάζονται πάνω από 5 computers...και ότι ποτέ κανείς δεν θα χρειαστεί πάνω από 640kb μνήμη (Gates)...
http://ifaq.wap.org/computers/famousquotes.html
Technological progress is relentless....
Zeppelsound
