Η Sony ετοιμάζεται για laser projectors
gkontoletas
trouble in my brain
Sumitomo Electric Industries, Ltd. (“Sumitomo Electric”) and Sony Corporation (“Sony”) have successfully developed the world’s first*1 semiconductor laser diode with an optical output power of over 100 mW in the true green region at a wavelength of 530 nm. This laser diode can be mounted on laser projectors and many other display devices. The new laser diode features twice the luminosity*2 compared with conventional gallium nitride (GaN) green laser diodes, and a color gamut broadened by 182% based on the NTSC standard (CIE 1976 color gamut)*3. As a result, these significantly improve the performance of laser projectors and other display devices to reproduce vibrant video and images.
Red and blue laser diodes have been commercially available among the primary red-green-blue (RGB) colors, but there has been greater need for high output green laser diodes towards the development of high performance laser projectors and display devices. Currently, green lasers are generated by converting the wavelength of infrared laser light from a light source using optical materials, but the light source is large and expensive. In addition, conventional GaN-based green lasers have difficulties achieving sufficient luminosity as their performance is limited to an output power of several tens of milliwatt at a wavelength of 520 nm or less.
To overcome these challenges, Sumitomo Electric and Sony collaborated in the development of a true green semiconductor laser for practical use, drawing on Sumitomo Electric’s semi-polar GaN substrate, crystal growth, and wafer processing technologies, as well as Sony’s GaN-based laser technology, acquired through the Blu-ray development. By introducing new techniques and improving the entire semiconductor laser production process, including structural design, crystal growth, wafer processing, and electrode configuration, Sumitomo Electric and Sony were able to successfully develop true green semiconductor laser with an optical output power of more than 100 mW at a wavelength of 530 nm. This true green semiconductor laser diode is highly reliable as it realizes wall-plug efficiency of over 8%.
The development of true green semiconductor laser diode completes the three basic colors of the RGB laser light sources. Sumitomo Electric and Sony anticipate a wide variety of applications for this technology such as incorporation into advanced laser projectors with high luminosity and broad color gamut, as well as compact, light, energy-efficient laser projectors.
Sumitomo Electric and Sony will continue to jointly develop true green semiconductor laser diode to achieve even higher output power, efficiency, and laser quality.
http://www.sony.net/SonyInfo/News/Press/201206/12-0621E/index.html
Απάντηση: Η Sony ετοιμάζεται για laser projectors
Άντε να δούμε.
ναι , μπας και πεσει αρκετα το λεντ..................
Μα που είναι ο Κεφάλας;
ψαχνει αν δει αν θα εχουν χρωμοδιαφορες τα λειζερ .........
παρε και εσυ μια.......
:618:
και αλλη μια γιατι θα αντιμιλησεις...:618:
γιατρεια για την πτωση της φωτεινοτητας σαχνει ?
η ο καντιλισμος καλα θα κρατει .................
:618:
πουσαι αμα δεν ξοδευοσουνα σε ντοματες θα ειχες ξεφυγει απο την μαστιγα των χρωμοδιαφορων.........
αλλα εσυ εκει ......
σιγα να μην ασχοληθω με hdmi
αν θελω υπαρχουν και ασυρματες λυσεις....:410:
αλλα εγω δεν το κουναω...
και πολυ καλα κανεις
αντε και σε σκαρτ και 14σαρα ασπρομαυρη.......................
gkontoletas
trouble in my brain
που είναι ο Καφάτοςbook να σχολιάσει;
MAD
Σιαρτάκιας
Ίσως να μην έχω μάτι εξπέρ, αλλά παίζοντας τώρα δυο εβδομάδες με τον HD-20, και αναγκαστικά με component, λόγω του ότι η HDMI έχει πάει για το 3D στην τηλεόραση, δεν μπορώ να δω διαφορά
στην εικόνα, αντίθετα (και μην γελάσει κανείς) νομίζω ότι έγινε οξύτερη η εικόνα!
gkontoletas
trouble in my brain
χάρηκες Κωστάκη; :138:
gvts
