Το παραθέτω αυτούσιο...
Pelican Air Flow Cooler for PlayStation 3
A preview of the first cooling solution for the PS3.
showUSloc=(checkLocale('uk')||checkLocale('au'));document.writeln(showUSloc ? 'US, ' : '');
April 20, 2007 - As all technology fans are aware, pouring the voltage required by today's modern processors into increasingly tiny, yet increasingly complex chips generates heat, and lots of it. The issue is only exacerbated when masses of such hardware is crammed into a sleek and sexy housing designed to please the eye, not the thermally sensitive components inside.
While PC-gamers can add massive cooling fans, or even water cooling systems to their hearts' content, console gamers have fewer options for chilling their beloved hardware. Though it would be ideal if manufacturers could be trusted to make perfectly functioning hardware, the first years of all console generations have always been rocky when it comes to hardware reliability. Early PlayStation 1 hardware suffered from warped CD drive-mounts due to heat, as did first-gen Xboxs. More recently, the widely publicized proclivity of the Xbox 360 to perish with the 'Red Eye of Death' proved to gamers that the new generation of consoles are the most fragile yet.
Though the PlayStation 3 has apparently not suffered quite as few full on hardware deaths as the Xbox 360, the console is not without its heat issues. Particularly in Blu-ray playback, we've personally been greeted with the 'Your PlayStation 3 is too hot. Please shut down.' warning on many occasions. No one enjoys being jilted out of a movie or game while in progress, and while the Xbox 360 has a number of cooling solutions available, like Nyko's Intercooler 360 (review)http://gear.ign.com/articles/703/703791p1.html and Pelican's Air Flo 360 (preview)http://gear.ign.com/articles/762/762625p1.html and The Cooler (review)http://gear.ign.com/articles/763/763900p1.html, the PlayStation 3 has yet to be graced with a strap-on cooling solution.
That's about to change when Pelican releases the upcoming Air Flo Cooler for PS3. The unit will seat on top of the PS3's uppermost cooling vents and will add five additional cooling fans to augment the console's internal cooling. The unit draws power from its own AC-adapter, and Pelican claims the Air Flo Cooler is capable of lowering the PS3's operating temperature by up to 15-degrees (Fahrenheit, we assume), which would seem to be enough to avert overheated shut-downs. The unit also makes use of 'Auto Thermo Sensing Technology' to automatically regulate fan speeds according to the load on the console.
Pelican is well aware that the PS3 is a sexy console and doesn't want to detract from its good looks with the Air Flo. Included with each unit are swappable accent highlights in black and chrome to match either of the two PS3 versions. The unit will launch in the coming weeks with a SRP of $29.95. IGN Gear has one of the very first samples and will be preparing a review over the weekend. Stay tuned for the full review.
