Θόρυβος - Σύμμαχος ή εχθρός;
Αντιγράφω από το τελευταίο WIRED:
Britney Spears ringtones, junk email, electromagnetic fuzz – unwanted signals assault us from all sides these days. But in his new book, Noise, Bart Kosko argues that even the most annoying racket can be beneficial. The USC professor draws on his degrees in electrical engineering, law, mathematics, economics, and philosophy to connect the finer points of calculus, game theory, and court precedent to all kinds of random, unpredictable energy. Wired asked Kosko to separate the signal from the noise.
– Bob Parks
WIRED: Scientists sometimes describe noise -patterns as colors. What does brown sound like? And is it the new black?
KOSKO: This whole business of putting color to noise comes from physicists who want to show that the frequency spectrum is not flat. They developed a color-coded scheme based on the exponent of the inverse of the frequency. Brown is represented by 1/f2. It’s common in nature. Temperature fluctuations in a city can look like brown noise over time. It sounds softer than white or pink noise. Pink has an octave quality, and the ear hears it as white.
You suggest that adding the right amount of random signal can actually enhance reception.
Adding small amounts of electrical noise helps a nanotube antenna detect faint binary signals. And noise can help digital photographers, too – injecting a little bit of random pixel noise can allow you to see hidden details in an overexposed image.
Can background music make you smarter?
The more you can concentrate with background noise, the more it strengthens the brain. Isaac Asimov used to set his typewriter up in stores and other loud places to work. His claim was that you get really good at writing when you’re in a crowd. You want to be energized by that background noise, rather than distracted.
Sounds like you’re pro-noise. Are there any you don’t like?
Blaring heavy metal, loud bars, cell phones in the middle of my classroom. I don’t care for film music either.
But, of course, noise can help you figure out if you’re stuck in a false reality à la The Matrix.
Well, yes. You can tell a run-of-the-mill simulated environment by the aliasing effects. The spoked hubcaps of a car would look like they were going backward for a while because they’re rotating faster than twice the frequency of the sampling rate, causing stroboscopic distortion. This type of noise appears because the owners of that matrix haven’t taken enough samples to emulate the world around you.
Could we use a similar method to sniff out that most annoying junk signal, spam?
Better spam filters will always be coming out, based on nonlinear and genetic algorithms. With spam filters and digital audio and high-definition TV, our signal-to-noise ratios are getting remarkably better. It’s odd, then, that our society just keeps getting noisier.
Is there a connection between noise and class?
The poor areas of cities are the loudest. I don’t know if there’s a correlation – there are too many parameters. But it’s true that the houses aren’t built as well, and there’s more open machinery. On the other hand, drive through Beverly Hills and count the leaf blowers. Poor people rake their own leaves.
I noticed there aren’t any commas in your book. Is this your way of cutting back on punctuation noise?
Commas are a kind of channel noise. You’re not getting to the verb fast enough. Why make us wait? The comma is on its way out. Use small words. The perfect illustration is a swear phrase: Go to hell! Screw you!
South California rulez!!! :D
κι όμως υπάρχει μια λογική εξήγηση σε αυτό με βάση την βεωρία της ψυχοακουστικής.
Οταν υπάρχει κάποιος χαμηλός θόρυβος στον περιβάλλοντα χώρο, ο εγκέφαλος του ανθρώπου συγκεντρώνεται περισσότερο στο κύριο ακουστικό ερέθισμα και αφαιρεί τελείως τον θόρυβο.
Παρουσία θορύβου, ο εγέφαλος του ανθρώπου καταβάλει αυτόματα κάποια παραπάνω προσπάθεια για να ακούσει καλύτερα έναν ομιλητή ή μια άλλη κύρια πηγή ήχου. Συγκεντρώνεται δηλαδή καλύτερα. Η ακρόαση ενός ομιλητή σε μια αίθουσα με μηδέν θόρυβο περιβάλλοντος μας κοιμίζει.
mgm
