Κι άλλο Universal Remote.........
You'd think that all you need from a universal remote control is the ability to be able to control all your various silver boxes in the house with one single device. Not so, apparently, it's a whole lot more complicated than that, as RTI has pointed out. Its T2+ Universal System Conroller will set you back a hefty £446 - and that's without all the numerous add-ons that will turn it into a high-end professional control system.
The T2+ comes with a USB port 256KB of memory and a rechargebale lithium-polymer battery. It's part touch screen, part normal buttons and it can control pretty much everything in you house - from audio systems and projectors, to blinds and lights. There's an LCD display that shows custom buttons, text, graphics and scrolling lists and the controller can either be supplied pre-programmed or you can programme it yourself using the Windows-based Theatre Touch Designer Software.
Read
Details of the add-ons follow
(from press release)
RP-6 Remote Control Processor (£446): provides advanced control and automation of any size home cinema system. Unlike simple IR-to-RF converters, the RP-6 stores all of the system’s commands where they should be – within a central controller at the equipment rack.
SPS-1 Video Sync Power Sensor (£58): monitors the on and off status of most video components and provides power status information to RTI control systems, without the need of additional power supply.
CM-232 Serial Communication Module (£58): provides RS-232 interface to almost any RS-232 enabled device. It attaches to an RTI control system on one end and a DB-9 serial port connector to the other.
VPS-1 Voltage Power Sensor (£58): monitors the on and off status of most electronic components. It connects to the output ports of the RTI control system and provides it with power status information.
Περισσότερα στο http://www.comm-tec.co.uk/supplier/rti/t2.htm
χμ..άραγε κάνει δουλειά.?
Κάνει, κάνει.........
Και ελέγχει και όλες τις συσκευές!!
(με ένα τηλεχειρ. αντικαθιστάς τουλάχιστον 4 ή 5!! Θα είναι ευτυχισμένη η γυναίκα σου, που θα γλυτώσει όλα τα πλαστικά μακρυνάρια πάνω στο τραπεζάκι του σαλονιού!!)
Το σημαντικοτερο ειναι οτι....
Θα τελειωνουν γρηγορα τα πολεμοφοδια (που θα σου πεταει)
Σωστόοοοοος..............
Σημαντικότατος λόγος και τον ξέχασα!!
(είμαι πολύ φρέσκος - "ψάρακας" θα έλεγα- στον γάμο και δεν έχει προλάβει ακόμα να μου πετάξει κάτι!!!
Λες........ :roll: :roll: :roll: :roll:
Hyparxist
