Κλειδώστε τα "παντιλίκια" του γιού σας..........
Eπειδή ΔΕΝ μπορείτε να συνοδεύετε συνεχώς τον γιο σας στις βόλτες του με το αγαπημένο σας αυτοκίνητο
αυτή είναι Η λύση...................
CarChip
A Black Box For Your Car
The CarChip package consists of a tiny "black box" data logger (about the size of two 9-volt batteries stacked together), a CD with software for analyzing the data, and a connecting cable and power adapter. The data logger plugs into the OBDII connector in your car, and continuously collects and stores data from the car's computer control systems. Later, you use the cable and power adapter to download the information to your PC.
Ideal For...
Parents with Teen Drivers
Fleet Managers
Do-It-Yourselfers
Professional Mechanics
Cost-Conscious Consumers
Time-Pressured Commuters
Environmentally-Aware Drivers
Features:
Store up to 75 hours of trip details. If you drive, on average, two hours a day, that's over a month's worth of driving data!
Time and date for each trip
Distance traveled
Speed at which you drove (recorded every five seconds)
Number of times you either braked hard or accelerated quickly.
View all of this information graphically on your computer screen, giving you a moment-by-moment picture of how you -- or perhaps your employees or the teenagers in your household -- are driving.
View the check engine light's diagnostic trouble code, get "freeze-frame" sensor readings telling you the status of various engine parameters at the time the problem occurred, and reset the light.
30-day Satisfaction Guarantee
One Year Warranty
Includes:
Includes the CarChip data logger
Software on CD
Download cable and power adapter
The software requires Windows 95 or above, at least 5MB free hard disk space, and one free serial port.
How It Works:
The CarChip plugs into the OBDII connector in your car, and continuously collects and stores data from the car's computer control systems. Later, you use the cable and power adapter to download the information to your PC.
Easy Plug-and-Go Installation:
Locate your car's OBDII connector. It's found in the passenger compartment of all cars sold today, model-year 1996 or later, no more than three feet from the driver's seat.
Plug the data logger in. A gentle push is all it takes.
Start driving. That's all there is to it! The data logger will start collecting data as soon as you start driving.
Install the software, connect the CarChip and download the data to your PC.
Find the OBDII Connector in Your Car
Not sure where the OBDII connector is in your car? Check the interactive database maintained by the National OBD Clearing House at Weber State University. Will not work on Diesel cars or trucks.
[scroll]Κόστος: 140$[/scroll]
Το προηγούμενο ήταν το βασικό μοντέλο για καταγραφή δεδομένων 75 ωρών.
Υπάρχει και το μεγαλύτερο μοντέλο για 300 ώρες..............
Και περισσότερες παραμέτρους παρακολούθησης του αυτοκινήτου (και του νεαρού οδηγού......βεβαίως-βεβαίως........)
CarChip E/X
The CarChip E/X package consists of a tiny "black box" data logger (about the size of two 9-volt batteries stacked together), a CD with software for analyzing the data, and a connecting cable and power adapter. The data logger plugs into the OBDII connector in your car, and continuously collects and stores data from the car's computer control systems. Later, you use the cable and power adapter to download the information to your PC
Ideal For...
Fleet Managers
Do-It-Yourselfers
Features:
Store up to 300 hours of trip details.
Distance traveled
Up to 4 out of 23 possible engine parameters, recorded every 5 to 60 seconds. Choose from:
RPM
Battery Voltage
Throttle Position
Timing Advance
Engine Load
Coolant Temperature
Fuel Pressure
Air Flow Rate
Fuel System Status
Intake Air Temperature
Short-term Fuel Trim
Intake Manifold Pressure
Long-term Fuel Trim
Oxygen Sensor Output Voltage
Accident log (the last critical 20 seconds of speed).
One Year Warranty
Includes:
Software on CD
H τοποθέτηση είναι ίδια και η τιμή λίγο πιο μεγάλη (αλλά αξίζει την διαφορά σαφέστατα)
[scroll]Κόστος: 180$ [/scroll]
Α καλά....
Big Brother και στο αμάξι.... :shock:
Σε λίγο βλέπω να τα πουλάνε με ενσωματωμένο τσιπάκι και σε κάθε Service θα πληρώνεις και τις κλήσεις :evil:
Το καλό είναι ότι όλο και κάποιο σπαστήρι θα βγεί για να το ταΐζεις fake στοιχεία 8)
Ξεχνάνε ότι τα παιδιά σήμερα είναι πιο hi-tek :wink:
Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Ρε μην αρχίζει και μας βάζει και η τροχαία αναγκαστικά τέτοια και μετά κλάφτα Χαράλαμπε!!!
θα πουλήσω το αμάξι και θα πάρω πατίνι!!!
Ναι Σπύρο......
Αλλά με το πατίνι έτσι κι αλλιώς ΔΕΝ θα τρέχεις!!! :mrgreen: :mrgreen:
Θα έρθει πολύ σύντομα η μέρα που θα μας υποχρεώσουν να βάλουμε "μαύρο κουτί" στο αυτοκίνητό μας!!!
(κοιτάξτε πιο πάνω.........κάνει καταγραφή όλων τον δεδομένων του ατυχήματος το ακριβό!!! Τα τελευταία 20 δευτερόλεπτα!!) :roll: :( :( :( :(
Το ζήτημα είναι να ΜΗΝ βγάλουν καμιά κρυφή κάμερα για το εσωτερικό του αυτοκινήτου (με night vision........ :wink: ) και τον σκληρό δίσκο με το "υλικό" το ελέγχει η σύζυγος!!!!
Εκεί να δείτε......γέλια!
(αν βγει κάτι τέτοιο........οι δικηγόροι θα το έχουν προωθήσει..... :roll: :roll: :wink: ..)
Είναι ευαίσθητα δεδομένα.....αποκλείεται.
Εδώ και οι κάμερες των λεωφορειολωρίδων στην Αθήνα δεν....πρέπει να δείχνουν ποιος είναι μέσα.
Τα δικά σου "ευαίσθητα" θα είναι τα μόνα που θα κινδυνεύουν!!!
(τσίγκινο εσώρουχο από δω και πέρα Μιχάλη!!!Που προστατεύει και από τις κλωτσιές!!!) :lol: :lol: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Γιατί νομίζεις το Tucson έχει φιμέ τζάμια..? Από πίσω τις βγάσει τις φωτογραφίες...αχαχχα
ztv
