Λάμπα Και Πάλι
JJ 543 TUBE AMPLIFIER
!!! NEW !!!
JJ 543
Technical Specifications
Circuit.........................................................................Push-pull , UL29%, AB-45mA, symetr. Catode Feedback
Power output.........................................................................................................2x 35 W/4 ohm
Inputs................................................................................................................4 x Line RCA
Input sensibility: Line 1-3...........................................................................................0,775V/ 35 W
Line 4...................................................................................................................2,0V/ 35 W
Input Impedance.....................................................................................................15000 ohm/ IEC
THD.................................................................................................................1% / 30W / 1KHz
Hum & Noise [S/N]................................................................................................85 dB/20 Hz-20 kHz
Channel separation........................................................................................................68dB/1kHz
Frequency Range..........................................................................................18 Hz-22 kHz/ -1dB / 35 W
AC Required..............................................................................................[100,120] 230 VAC@50/60 Hz
Power Consumption.......................................................................................................max.: 180 W
Tube Complement............................................................................................4x JJ 6L6GC, 4x JJ ECC81
Finish [standard]: Cover......................................................................................... Black pulverlack
Front Panel..........................................................................................Anodized Silver [Black, Gold ]
Dimensions [incl. Output Connectors]............................................................446x115x430 mm [ 15.5x4.5x17 inch]
Net weight.......................................................................................................23 kg [51 pounds]
Transport weight..................................................................................................28 kg [62 pounds]
DimAster
