Μικρα μυστικα για το k750i
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Τα βρηκα στο esato.com και σας τα παραθετω:
1 = Opens menu with "picture size" ready to select
4 = Toggles Macro mode (for close up photos)
7 = Toggels Night mode
* = Toggles Light (I also find this is the fastest way to use the light as a torch in the dark)
0 = While in video mode toggles length of recording.
Mute camera sounds; Before opening the lense cover hold # to toggle between silent mode easially.
Change brightness = < or >
Secret Menus / Codes
Service menu = >*<<*<*
Lock status = <**<
IMEI number = *#06#
Access contacts on sim card = Any nubmer then # (e.g. 9# to go to 9th entry on sim card.)
Free Downloads / Software
Sony Ericsson Developer Tools (customise/design your own themes or remote control application) http://developer.sonyericsson.com/
Ringtones/images etc... http://www.sonyericsson.com/f[....]c=en&s=10242_brands_files_
Also search on eMule or BitTorrent (for downloading freeware only of course)
Light up clock in standby mode
Press the volume button
Mute a phone call without rejecting it
Hidden Smileys
Don't Drain The Battery
With Lithium batteries there is no advantage to draining the battery. The battery will infact last longer with partial rather than full discharges. There is no battery memory effect with a lithium battery - you can charge the battery whenever you like without fear of reducing its charge capacity, and you do not need to drain a lithium battery completely before recharging it.
Find out more about Lithium batteries here: http://www.batteryuniversity.com/
In response to lots of questions about the battery, I've explained things in greater detail on page 4 of this thread.
Select Text (anyone know if you can copy/paste)
Hold either volume button and press < or >
Remote Control
I only just discovered what the remote control application is capable of, so I think this is worth a mention for those of you that might have thought nothing of it... I've used the SE developer tools to customize a remote for winamp, easier to use than windows notepad! I've also made a shortcut pointing to C:/WINDOWS/system32/shutdown.exe -s -t 5 -c "K750i Bluetooth remote command" which is a network command to shut down the computer after 5 seconds. If you put the shortcut in the start menu somewhere, you can assign a shortcut key to execute it e.g. CTRL+ALT+0. Which in turn you can program your remote to use on one of it's buttons.
intergrale
