Ένα πολύ ενδιαφέρον άρθρο εδώ,για το εν λόγω φαινόμενο.
Σταχυολογόντας:
Σταχυολογόντας:
Although all display technologies have their own unique strengths and steadily improve over time, users' memories of their initial weaknesses and limitations can plague them forever. The best examples of this effect are plasma displays, with their so-called "burn-in" problem (which is actually uneven aging), something that was technically overcome many years ago but which lingers like an 800-pound gorilla that still threatens to kill this excellent technology. Plasma manufacturers bear much of the blame because they have chosen to avoid this issue in their marketing rather than confronting this widely held perception.
LCDs have their own gorilla: limited response time, which causes motion blur. As with plasmas and burn-in, this was a significant problem many years ago, and it too is no longer an issue now. But unlike plasma manufacturers, makers of LCDs have turned this into a brilliant marketing strategy, offering increasingly sophisticated and enhanced motion processing and ever higher 120- and 240-Hz screen refresh rates to repeatedly oversell a solution to a problem that is no longer a problem.
Findings Highlights
- <LI itxtvisited="1">Response time not a useful spec for indicating picture blur. <LI itxtvisited="1">Motion enhancement technologies can actually degrade image quality.
- Motion blur may be detectable in moving still images but not in even fast-moving video.
LCD Response Time and Motion Blur
Motion blur is a well-known issue with LCDs. It arises because the liquid crystal, the active element within an LCD, is unable to change its orientation and transmission rapidly enough when the picture changes from one frame to the next. Because the standard video rate is 60 frames per second (fps), a pixel is expected to be able to fully update its light transmission opacity within 16.7 ms (one-60th of a second). If it takes any longer than that, the image will show some degree of lag, which appears as a trailing smear or blur whenever there is motion. It also affects the visibility of the leading portions of moving objects.
LCD motion blur is generally evaluated with an industry-standard specification called response time. Unfortunately, it's not a particularly good indicator for real picture blur because it measures the time a pixel needs to go from black to peak-intensity white and then back again.
Figure 1 shows 11 HDTVs in the DisplayMate Technologies Demo Lab. Included are eight LCDs, two plasmas, and one Sony Professional HD Trinitron Studio Monitor, a CRT we used as the reference standard. This was an in-depth scientific study that included precise calibrations, comprehensive spectroradiometer measurements, and a large number of jury panelists that viewed test patterns, test photos, and high-quality HD video.
