Σπύρος Μπλάτσιος
Διακεκριμένο μέλος
Tν νέα έκδοση του γνωτού βραχίονα Artemiz ανακοίνωσε η Roksan. Τα χαρακτηριστικά του είναι τα ακόλουθα:
Για περισσότερες πληροφορίες http://www.roksan.co.uk/art_tonearm.htmlSpecifications
* Effective Length: 240.00mm
* Overhang: 17.50mm
* Head-shell offset angle: 22.9 degree
* Mounting hole diameter: 22.00mm
* Arm board thickness: 4.50mm – 26.00mm
* Recommended arm board material: Acetal or MDF
* Recommended Cartridge Tracking Force 1.3 – 3.0 g
* VTA adjustment Yes
via Arm pillar mounting adjustment
* Recommended cartridge weights: 5-10 g (with standard counterweight)
* Effective Mass: 9 g
* Head-shell/Arm tube One Piece Aluminium Alloy
* Arm tube fixing Titanium coupling ring/stainless retaining screw
* Bearing Assembly Unique ‘Pyramidal’ Roksan design silent running
x12 Tungsten Carbide Bearing Balls
x4 Hardened Steel Bearing balls
* Counter Weight Assembly Unique Roksan ‘Intelligent’ type
* First break resonance 1.4kHz
