Νέα Genelec
m1ts0s
News poster
During the last eight years, Genelec has created a line of highly successful Smart Active Monitoring (SAM™) products designed to adapt automatically and accurately to the acoustic environment. Today, 12. September 2014, on Stand 8.D61 at IBC 2014, Genelec is proud to release a new generation of SAM systems by introducing two new compact two-way monitors, the 8320 and 8330, and a new subwoofer, the 7350, along with an entirely new and highly intuitive Genelec Loudspeaker Manager software, GLM™ 2.0, complemented with a new measurement microphone and network adapter unit.
“IBC is the perfect launch platform for our new compact SAM systems,” comments Lars-Olof Janflod, Marketing and PR Director at Genelec. “Visitors will discover how much further developments we have put in this new generation of SAM systems to offer intelligent auto- calibrating systems that are easy and friendly to use. Reaching a much wider range of production facilities and business applications, these new high resolution audio monitoring systems naturally extend our SAM range to smaller sizes while offering performance never seen or heard before in the audio monitoring business.”
The 8320 and 8330 monitors feature Genelec’s Minimum Diffraction Enclosure (MDE™), made of recycled die-cast aluminium as well as the advanced Directivity Control Waveguide (DCW™) technology. While the 8320 and 8330 monitors and the 7350 subwoofer are small in stature, they are outstanding in performance and are part of the highly integrated software and hardware solutions developed by Genelec R&D team. With their floating point digital signal processing engines and Genelec-designed Class D amplifiers, these SAM systems will make you appreciate the forward thinking that makes Genelec the leading benchmark in audio monitoring for broadcast, post-production, and music facilities.
Genelec’s SAM technology is an indispensable tool when dealing with the challenging reality of small room acoustics. SAM technology automatically optimises and aligns each monitor and subwoofer for relative levels, time of flight, subwoofer crossover phase as well as individual room response compensations. So, even if the monitors or the production projects move between rooms, you can expect that SAM technology will achieve the highest consistency in monitoring by always providing a neutral sound stage imaging with low distortion.
http://www.genelec.com/documents/datasheets/Genelec_SAM_brochure_2014_web.pdf
τα 3δρομα 8260 χαλβαδιαζα...αλλα ειναι "ψηλα" και δε θελω να δημιουργησω εξτρα debt για να τα παρω και να κανω τη χαρη στο συστημα...
εχει κανεις genelec?...αποψεις?
γενικα απο review που διαβαζω, λενε οτι ο ηχος τους, αν και σχετικα flat, ειναι πιο "forward"...αυτο τωρα τι πραγματικα σημαινει και αν αποτελει αλλο ενα "επιθετο" των reviewers, στη προσπαθεια τους να δωσουν μια διαφορετικοτητα μεταξυ των "σχολων ηχου" της καθε εταιριας, θα σας γελασω...
γιατι τοσο ακριβο το 3δρομο?...λογο dsp?...κανεις την ιδια ή και καλυτερη δουλεια (eq), και μ ενα dirac, ωστε να γλιτωσεις τα εξτρα φραγκα ή ειναι "κουρδισμενο" σα πακετο το 8260, ετσι ωστε μοναδες και dsp να συνεργαζονται βελτιστα?...αν αυτο υπαρχει
εχω τα 8030a εδω κ αρκετα χρονια.. το ηχειο για τα χρηματα του ειναι μπομπα.. στερεοφωνικη εικονα με εντονο λαμπρο χαρακτηρα που δεν την φανταζεσαι για το μεγεθος τους κ κατασκευη στιβαροτατη-φουλ μεταλλικο σαν γρανιτης.. προσφατα τα συνδυασα με το αναλογο σαμπγουφερ 7050b.. θελει λιγο ρυθμιση για να ισορροπησει με τα ηχεια αλλα κατεβαινει ιδιαιτερα χαμηλα 25hz δινοντας πληρη στερεοφωνικη εικονα... αν τα συνδυασεις κ με λαμπατο προ για να γλυκανεις τον d ενισχυτη που εχουν δεν θα πιστευεις τα αυτια σου... απο εντασεις δεν ειναι για παρτυ αλλα ευκολα θα ενοχλησεις γειτονες.. για οικιακη χρηση ειναι αρκουντως ικανοποιητικα αν αναλογιστεις το μεγεθος τους... παντως δεν πρεπει να ξεχνας οτι ειναι nearfield μονιτορ δεν ειναι μουσικο ηχειο δεν ειναι φτιαγμενο για να κολακευει αλλα για να αναλυει.. προσωπικα για την μουσικη που ακουω δεν θα ηθελα μουσικο ηχειο... οπως κ να χει μιλαμε για μια εταιρεια που ειναι απο τις ανωτερες στο συγκεκριμενο τομεα.. για το 8260 δεν γνωριζω αλλα τα χαρακτηριστικα του ειναι για σεμιναριο..
Καλησπέρα στο φόρυμ, έχω αγοράσει τα Alesis Elevate 5 (http://www.skroutz.gr/s/4267423/Alesis-Elevate-5.html?keyphrase=alesis+elevate+5) και θα ήθελα πληροφορίες από όποιον ξέρει, για το πώς πρέπει να τοποθετηθούν (μεταξύ τους απόσταση, ύψος βάσεων, κλίση προς τα μέσα, κ.λ.π.).Ευχαριστώ.
Καλησπέρα στο φόρυμ, έχω αγοράσει τα Alesis Elevate 5 (http://www.skroutz.gr/s/4267423/Alesis-Elevate-5.html?keyphrase=alesis elevate 5) και θα ήθελα πληροφορίες από όποιον ξέρει, για το πώς πρέπει να τοποθετηθούν (μεταξύ τους απόσταση, ύψος βάσεων, κλίση προς τα μέσα, κ.λ.π.).Ευχαριστώ.
καλημερα φιλε κ καλοακουστα τα καινουργια σου ηχεια.. το βασικοτερο ειναι το τουιτερ να βρισκεται στο υψος των αυτιων σου.. φανταζομαι οτι τα θες για desktop εφαρμογη.. απεφυγε τοποθετηση κοντα σε γωνιες κ τοποθετησε τα οσο πιο κοντα στον τοιχο γινεται μια κ απο οσο ειδα δεν εχουν οπη ανακλασης πισω… γενικα εχε κατα νου να σχηματιζεις τριγωνο ισοπλευρο ή ισοσκελες με τα ηχεια σου… κατι που πρεπει να δεις ακομη ειναι να μονωσεις την επιφανεια που εφαπτονται με το γραφειο σου τα ηχεια.. μια φτηνη λυση ειναι το ασφαλτοπανο.. φυσικα και θα τους δωσεις μια κλιση ωστε να "κοιτουν" προς τη θεση ακροασεως σου...
loudobic
AVSite Member
Εξαιρετικά τα Genelec, είχα διάφορα μοντέλα κατα καιρούς στο γραφείο με το PC, απίστευτη εικόνα και βάθος, ποιότητα κατασκευεις, καποια στιγμή σκέφτηκα να παρω τα μεγάλα + sub για τον κύριο χώρο ακρόασης, αλλα δεν το τόλμησα.
καταρχάς, να ζητήσω συγγνώμη από τους διαχειριστές, γιατί πόσταρα σε λάθος τόπικ, εγώ ήθελα να ποστάρω εδώ: http://www.avsite.gr/forum/threads/ενεργα-monitor.135314/page-19
Κατά δεύτερον, ευχαριστώ τον bop_b_3akohe για τις συμβουλές, απλά θα ήθελα πιό συγκεκριμένα νούμερα. Τα ηχεία τα έχω σε βάσεις 65cm, αλλά τα τουίτερ βρίσκονται 10cm πιό χαμηλά απο τα αυτιά μου. Στο γραφείο δεν χωράνε, είναι μικρό. Είναι 10cm από τον πίσω τοίχο, και ακούγονται πολύ καλά, αλλά στερεοφωνική εικόνα δεν έχω καθόλου.Κλίση έχουν μεταξύ τος 20 μοίρες, το καλώδιο που τα ενώνει μεταξύ τους είναι κοντό και δεν μου επιτρέπει να τα γυρίσω περισσότερο. Θα αλλαχτεί βεβαίως, αλλά περιμένω και καμμιά πρόταση για βάσεις για αυτά τα ηχεία. Ευχαριστώ
Θάνος Γαλάνης
