Θα χρειαστώ την βοήθεια των ειδικών... Πρόκειται (μάλλον) να αντιπροσοπεύσω στην Ελλάδα μια καινούργια μάρκα προβολέων, οπότε και έχω στα χέρια μου ένα μοντέλο της χαμηηλής κατηγορίας. Θα παραθέσω τα χαρακτηριστικά να μου πείτε την γνώμη σας..
:arrow: Display Technology:0.55" DMD, DDP 2000
:arrow: Resolution:SVGA 800 x 600 (Native), 1024x768 (Compressed)
:arrow: Projection Distance:1.5-7m
:arrow: Screen size (diagonal):0.93-5.16m
:arrow: Contrast Ratio:2000:1
:arrow: Brightness: 1800 ANSI Lumens
:arrow: Throw Ratio (D/W): 1.16 : 1
:arrow: Lamp: 200W (VIP Type)
:arrow: Aspect Ratio: 4:3 & 16:9
:arrow: Lens: Carl Zeiss with Manual Zoom(1:1.16) and Focus F2.6
:arrow: Data Compatibility: IBM PC or Compatible (VGA, SVGA, XGA) and Macintosh
:arrow: Video Compatibility: NTSC/NTSC 4.43, PAL, SECAM
Composite & S-Video;
HDTV: 480i, 480p, 720p, 1080i
:arrow: Digital Keystone Correction: Vertical+/- 15μοίρες
:arrow: Input/Output:
RGB Input: DVI x 1
S-Video in Mini: DIN 4-pin x 1
Composite Video: RCA jack x1
Audio in: Mini jack x 1
Component Video: Through DVI-I Input
Rs232 Input: PS/2 Mini DIN x 1
USB Input: Type B receptacle x1
:arrow: Security:Kensington MicroSaver Security System
:arrow: Weight:2.0 Kgs
:arrow: Dimension(LxWxH):280mm x 205mm x 97mm
:arrow: Noise:<34 dB
:arrow: Remote Control Features: Power on/off, Menu, OSD navigation, Freeze on-screen
picutre, Keystone adjustoment, Auto key to optimize image
Performance, Mute to control built-in speaker, Volume control,Detect input source
:arrow: Standard Accessories: Power cord, Remote Control, carrying case, lens cap, DVI-RGB
cable, S-Video, QSG, Manual in Disk, Composite video cable
RCA audio cable
:arrow: Optional Accessories: Lamp replacement module, Component video Cable
:arrow: Special Features:Eco Mode, Customized Flash Logo
:arrow: Safety Certification :FCC-B, UL, C-UL, CE/TUV.CB, CCC
RGB Input: DVI x 1
RCA audio cable
