Νέο firmware για NMT's
Κυκλοφόρησε το νέο firmware για το Popcornhour A-100.
Αυτό σημαίνει ότι σε λίγες μέρες κυκλοφορεί και για τα υπόλοιπα (Α-110 , Egreat κτλ).
Οι αλλαγές είναι:
1. Requires NMT apps 00-17-090115-15-POP-402
2. Browser / System
- Improvement on font engine character rendering (30% speed up)
- faster navigation on local drives
- Use numeric key to input item number to jump to the page where item is located
- Improved fileplayer speed
- Hebrew translation added
- Fixed HDMI display output blackout issue for auto EDID
- Discrete RC (Logitech) scancode fix
- Updated network share and webservices language packs.
- Removed EXT2 option for NMT installation
- Note: due to long term reliability issue with EXT2 on device that is frequently turned off abruptly
- Additional symbols can be input from "1" key
- HTTP download manager (only works with links with special "download" attributes.
- File player hide Recycle Bin folder
- Fixed 'TV MODE' + '3' key handling bug
- Fixed recovery kernel no red screen displayed
- Browser image caching fix, should fix some YAMJ crashes or no image issue.
- Fixed HDD spin-up during standby
- Fixed slow loading of HTML pages
3. Web Services
- New UI
- customizable icon feature with browse image utility (need NMT apps)
- bug fixes on customizable service icon with browse feature.
- Web Services page modification
- Fixed a "save/remove service" bug
- Now able to customise JPG/BMP icon
- Fixed slow IR response while playback Internet Radio
- Immediate response to STOP during Internet video streaming
- Fine-tune Web Service UI
4. Network
- Improved SMB server startup time
- Improved browsing time for SMB client
- Atheros USB WiFi stability fixes
- Fixed SMB client hostname resolution picked up wrong IP address from the IP list
- Fixed file copy failed from HDD to SMB/NFS with names containing whitespace
- Fixed UPnP AV server playall issue broken in previous release
- Fixed Samba server halts after device name change
- Torrent client is now by default Transmission (btpd removed)
- Fixed torrent schedule page not working
- Fixed occasionally newly created SMB/NFS shares doesn't show up in media source list
- Atheros USB WiFi added support for TP-Link v2 stick
- Fixed persistent private IP when DHCP server unavailable (e.g. cross-cable connection etc)
5. Playback
- Bookmark/resume for single playback
- 10 bookmarks available now
- Press stop to bookmark the last video playback
- Press enter / play with focus on bookmarked clip to resume
- Press "0" to start from beginning of clip
- Auto framerate synchronisation
- Framerate sync function in ISO playback, only for 50,60Hz modes (PAL/NTSC)
- switch to NTSC(60Hz) when selected mode not applicable.(previously, it will follow TV mode selected)
- Use 59.94 for NTSC when matching content detected.
- Fixed incorrect data shown on infobar.
- Fixed after ISO playback, screen goes blank when framerate sync kicks in
- Improved info display
- Disable incorrect video MPEG1/2 VBR display.
- Fixed incorrect framerate info for video playback (*.mov, *.mp4).
- Fixed video bitrate calculation error (less 1 packet every second)
- Modified infobar UI (height, spacing and text displayed)
- Fixed info bar losing text after paused
- Improved accuracy of mpeg1/2 bitrate information
- Photo app
- Fixed JPEG (PNG / TIFF transcode) from myiHome server cannot be displayed
- Fade-In Fade-out effect added for photo transition
- Enable large jpeg rotation. (downscale before rotate)
- Fixed faded color for jpeg at 360-deg rotation
- TV Type setting for DVD playback
- the TV type setting is now working for DVD video playback (4:3 and 16:9 only, 16:10 will treat as 16:9)
- DVD Menu
- new popup menu if MENU key on PCH remote controller is pressed
- user can select to jump to ROOT, TITLE, CHAPTER.... etc from the menu
- Modified progressive zoom and pan in ISO/IFO playback
- Removed up/down keys as prev/next track/td>
- VCD *.DAT playback fixed using soft demux
- Fixed "repeat" keypress in myiHome when playback audio caused picture playback to halt
- Improved handling of MKV H.264 profile and vlevel.
- Fixed cannot stream MPEG from UPnP AV server, liveTV
- Fixed .pls file unable to start when playback locally (HDD/SMB/NFS)
- Fixed TS with stream6 as teletext playback cause out of memory
- Fixed MKV H264 L4.1 pixelated video issue
6. Subtitle
- Fixed Hebrew SRT subtitle containing invalid character
- Fixed subtitle parsing with BOM (UTF8 support only)
- Thai subtitle support
- Fixed wrong character rendered in Thai subtitle
- Changed default subtitle font size to 28 and Y offset to 10
- Exception handling in SSA subtitle parsing
- Slight adjustment of subtitle position
Περισσότερες πληροφορίες εδώ.
bmavroeidis
