Νέο Phono stage από Audio Research
PH5 Stereo Phono Preamplifier
The PH5 starts with a new package. The full-width 19" front panel's layout is similar to the SP16, with an LED display on the left side and four soft-touch buttons on the right. The buttons control Power, Mute, Mono, and Loading. For the first time in a PH-series phono stage you can adjust cartridge loading to 47K, 1000, 500, 200, or 100 ohms at the touch of a button. And, better yet, the four front panel controls are duplicated on the remote control included with the PH5. Now you can even adjust loading from the comfort of your favorite chair!
The rear panel includes one pair of SE inputs, one pair of SE outputs, a ground post, and a detachable A.C. power cord. Like other recent additions to our lineup, handles are optional at extra cost.
The PH5 is a hybrid (as was the PH3), utilizing a new high-gain, 5-JFET per channel, non-inverting input stage with constant-current stabilization and no overall feedback. New RIAA circuits are patterned after the Reference Phono, with passive high frequency and active low frequency equalization resulting in an improved margin of stability under the most demanding conditions. The non-inverting gain and output stages utilize four 6922 twin triodes. There are high-stability power supplies with four separate regulators for all tube heaters, plate supply and microprocessor logic. And, as you have come to expect from Audio Research, the bandwidth of the PH5 is 0.7Hz to 400kHz (-3dB). Total gain has been increased to 57.5dB, more than sufficient for low output moving coil cartridges when partnered with an appropriate line-stage.
Είχα την ευκαιρία να ακούσω το πρώτο που ήρθε στην Ελλάδα. Χωρίς να έχει γράψει πολλές ώρες στο κοντέρ (κάπου 3 με 4 το πολύ), έδειξε πολύ καλά στοιχεία και σαν να μου φάνηκε λίγο πιο ζωντανό από το παλαιό μου PH3.
Gianni Tab
