Να φτηνος DLP ! BenQ W100
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Θυμαστε την συζητηση που καναμε σχετικα με φτηνους DLP κατω απο 1000€?
Ε λοιπον να ενας!
Ο W100 κυκλοφορει στο τελος Απριλιου , με αναλυση 854χ480
φωτεινοτητα 1300 ansi και αντιθεση 2500:1
Και η τιμη αυτου?
899 ευρουδακια! :wink:
Ναι έτσι φαίνεται από τις προδιαγραφές του και έχει και τρόχό 7 περιοχών!
BenQ W100 LCD Projector Home Entertainment 1100 ANSI lumens 854x480 widescreen.
The BenQ W100 is a fantastic entry level homecinema projector. If you are new to home cinema and want a great experience with your first projector, the W100 has a lot to offer for the money! It is also a simple, easy to use machine that is designed for those who don't want to mess with tweaks and calibrations.
The W100 features a number of precalibrated settings including gaming, which is the lowest in video contrast but by far the brightest, so you can hook up the games console and enjoy a big, bright image without having to sit in the dark.
Native 16:9 Wide Screen
• Low Noise Level (25dB) under Economic mode,
• 7 Segment Color Wheel,
• Digital/Analog Dual Input DVI-I,
• 1100 ANSI LUMENS,
• 2500:1 High Contrast Ratio,
• HDTV Compatible (480p, 576p, 720p, 1080i),
• 2 Sets of Component Video,
• 10 Sets of Preset Modes,
• 3000 hrs Lamp Life (Economic mode).
Specification Value
Dimensions (W × D × H) 260 × 84.5 × 220 mm
Projection System DLPTM technology by Texas Instruments®
Panel 0.53" 480P DDR DMD™ ×12
Native Resolution 854 × 480 (16:9)
Brightness 1100 ANSI lumens
Contrast Ratio 2500:1
Aspect Ratio Native 4:3, 16:9 selectable.
Color Full 16.7 million color palette
Lens F=2.6 to 2.77, f=20.4 to 23.5 m
Zoom Ratio Manual Zoom, 1.15:1
Image Size (Diagonal) 35" to 160"
Throw Ratio 53"@2m (53"@6.6 feet)
Throw Distance Min: 1.35; Max: 11.32 m
Lamp 200W, 2000/3000 hours (Normal/Economic mode)
Computer Compatibility VGA(640 × 350) to SXGA(1280 × 1024)
HDTV Compatibility 480p, 576p, 720p, 1080i
Video Compatibility NTSC, PAL, SECAM
Horizontal Frequency 31~82 kHz
Vertical Scan Rate 48~85 Hz
Projection Position Front/rear, table/ceiling
Input Terminals PC Analog RGB: DVI-I ×1, Digital RGB: DVI-I ×1 (HDCP) Video Component Video 1: RCA ×3, Component Video 2: RCA ×3, S-Video: Mini DIN 4 pin ×1, Composite Video: RCA ×1, Audio PC audio: Stereo mini jack ×1.
Output Terminal 2 Watt Speaker ×1
Control Terminal Serial connector: RS232 9 pin MINI DIN
Weight 2.7 kg (6 lbs)
Power Supply 100 to 240 VAC, 50 to 60 Hz
Power Consumption Max 285W
Audible Noise 29/25 dB (Normal/Whisper mode)
On-Screen Display languages English / French / German / Italian / Spanish / Russian / Traditional Chinese / Simplified Chinese / Japanese / Korean / Swedish / Dutch / Turkish / Czech/ Portuguese / Thai / Polish7Pjs%2B
Application Modes PC Input Brightest, Presentation, sRGB/ Photo, Gaming.
A/V Input Home theather, cinema, gaming, photo, Family room
A/V Input Home theater, cinema, gaming, photo, Family room
Functions Digital keystone, Source detection, Digital image adjustment, 9 sets of application, Freeze Deluxe Soft Carry Case, Progressive scan HDTV compatible.
Accessories (Standard) User’s Manual, Battery, Remote Control, S-Video cable, PWR Cord HDTV cable.
Accessories (Optional) Spare lamp kit, Ceiling mounting device, Remote Control
Ελπίζω να έχουν βελτιώσει το 2Χ του 5120 ώστε να μην υπάρχουν γκρίνιες για RBE. Πάντως είναι αλήθεια ότι βγαίνει σε σωστή τιμή και καταδικάζει τον ΙΝ72 σε αφανισμό. Αν έχουν βελτιώσει και την ποιότητα κατασκευής τους, θα έχουμε νέο best seller.
αν τιμη αγορας εχει ~700ευρω... εχει καλως!
γιατι καπου τοσα αξιζει να δωσει κανεις για αναλυση μιας αλλης εποχης...
Απο τη στιγμή που ο τροχός είναι 7 περιοχών(
υποθέτω RGBRGBW) τότε μιλάμε για ταχύτητα 4χ!
Μελίδης Μιχάλης
Πρόεδρος ΕΒΒΕ
Με τόσο μικρό ζουμ πως να τον βολέψεις. Δεν μπορούσε να ήταν τουλάχιστον 1.30 που κι αυτό είναι λίγο.
Το 1.15 είναι σαν να μην έχει.
ΚΑΛΑ νεα!
το νεο μωρο της benq μπηκε στις λιστες των γερμανικων ιντερνετ καταστηματων και κυμαινετε απο 750 ως 850ευρω!
αναμενετε την πρωτη εβδομαδα Μαιου οπου και λειαν συντομως θα πεσει κι αλλο λογω ανταγωνισμου!
Μαλλον η benq διαβαζει τα ποστ μου και καταλαβε οτι με τετοια αναλυση ΜΟΝΟ στα μισα λεφτα των LCD ισως πουλησει κανενα κομματι...
Η infocus τι κανει???
Ρε παιδιά αυτό το 1.x zoom πώς μεταφράζεται σε διαστάσεις; Δηλαδή zoom 1.15 καλή ώρα τι σημαίνει για τις ίντσες/απόσταση; Στα πόσα μέτρα βγάζει πχ. 100''; Γενικά πώς υπολογίζεις απ' το zoom ratio σε κάποια μέτρα πόσες ίντες βγάζει (min και max); Ή δε χρησιμεύει γι' αυτό και απλά σημαίνει ότι, αν απ' τα 3 μέτρα βγάζει με κλειστό zoom 100'' π.χ. τότε με τέρμα ανοιχτό θα βγάζει 100''x1.15=115'' (μάλλον το δεύτερο, ε;);
agnooumenos
