Νεα μινι HD καμερα απο την Sony
Sony Introduces the World's Smallest and Lightest HDV 1080i Camcorder With Easy-to-Use Operation and Advanced Features
Changing the notion that high-definition video recording is for "advanced videographers only" Sony today announced the HDR-HC3 HDV 1080i Handycam® camcorder.
Compared to its predecessor, this new, high-def camcorder is 26 percent more compact, packed with easy-to-use features, and more affordable.
"People are more savvy about high-definition television, have experienced its visual impact, and now they want the same `wow factor' for their own home movies," said Linda Vuolo, director for camcorder products at Sony Electronics. "Sony has made great strides in creating the consumer HDV market over the past two years and now we are expanding it even further."
Perfect Integration Into Your Living Room
The camcorder will snuggle up comfortably next to your high-def TV with its HDMI™ output. Now the de facto standard in the consumer electronics industry for transferring high-def content, HDMI offers simple, one-cord connection to display devices so you can just plug and play instead of struggling with multiple cables.
Your own home movies recorded with the HDR-HC3 will stand up proudly next to your pre-recorded high-definition video. The new camcorder delivers superb high-definition picture quality and lighting detail on both video and digital still images.
Advanced Technology Brings Advanced Features
The HDR-HC3 model features a professional-quality Carl Zeiss® Vario-Sonnar® T* lens and Sony's new ClearVid CMOS Sensor™ technology. This imager is engineered to boost picture resolution and clarity to deliver vivid colors and precise image detail. Combined with Sony's Enhanced Imaging Processor™, it provides new and fun-to-use functions.
The camcorder shoots four-megapixel still images, stored on an optional Memory Stick PRO Duo™ media card, for easy transfer between compatible devices.
It has a dual record function that allows you to shoot video and simultaneously capture 2.3 megapixel stills (16:9) in high definition mode and 1.7-megapixel stills (4:3) in standard definition mode. You can also record slow motion video using the model's smooth slow record function, which plays back three seconds of video in 12 seconds -- ideal for analyzing your golf swing or tennis back-hand.
High Def Made Easy
This new model incorporates a number of convenient, easy-to-use features that are ideal for first-time camcorder users and those new to high-def recording.
"Our latest model is a perfect solution for families who are currently using mini-DV camcorders and want to step up to high definition," said Vuolo.
It has a user-assignable dial that can be set to the most regularly-used options for greater ease of recording. It includes Sony's distinctive Easy Handycam button that, when pressed, locks out advanced features on the camcorder, leaving only the buttons essential for recording on the menu.
For quick framing and easy image sharing, the camcorder has a 2.7-inch touch panel SwivelScreen™ LCD featuring Sony's new Clear Photo LCD plus™ technology. The LCD produces bright images with high-contrast that are easy to view in virtually any environment and at any angle.
Other helpful features include Super SteadyShot® image stabilization, a built-in microphone for excellent audio quality, an intelligent built-in flash for well-exposed still images, and a supplied InfoLithium® P battery for up to 90 minutes of continuous recording.
The HDR-HC3 Handycam camcorder will be available in April for about $1700. Optional accessories will include a full line of accessories, including lights, lenses, microphones, InfoLithium® batteries, chargers and cables.
Even the home video enthusiasts are impressed with the range of recording capabilities offered by the HDR-HC3 Handycam® camcorder. With HD and SD Recording Modes, you can make the move to HD while retaining compatibility with standard definition equipment. The HC3 sets the industry standard in resolution quality with its ClearVid CMOS Image Sensor™, capturing precise detail and superior color reproduction. Dual Record Mode lets you capture 2.3 Megapixel stills while shooting high definition video. And Smooth Slow Recording captures fast movement with precise detail for slow motion playback. Now you can record what you want however you want it. The HC3 is everything you’ve come to expect from the world's smallest and lightest consumer camcorder (as of February 1, 2006).
• 2.1 Megapixel (Gross) ClearVid CMOS Sensor™
1/3" ClearVid CMOS Sensor provides stunning detail and clarity with exceptional video (up to 1080 lines of resolution - HD Mode or up to 530 lines of horizontal resolution - SD Mode) and still image performance (4.0 Megapixel). Unlike traditional CCD Imagers, CMOS Sensors require less power, providing better battery performance.
• HDV Recording Format
From the innovators in camcorder technology, Sony’s HDR-HC3 camcorder is the industry's smallest and lightest HDV1080i consumer level camcorder and player (as of February 1, 2006). Now you can record all your memories in true high definition video.
• 2.7" Wide (16:9) Hybrid Touch Panel Clear Photo plus LCD Display (211K Pixels)
The 2.7" Wide (16:9) LCD screen provides excellent viewing clarity with improved resolution. The 211K pixel LCD screen rotates up to 270 degrees for multiple viewing angles providing sharp, detailed images for monitoring or playback, and the widescreen format makes shooting in 16:9 mode and composing shots even easier.
• Smooth Slow Recording
By increasing the record rate from 60 fields per second (fps) to 240 fps for 3 seconds allowing you to capture 3 seconds of fast motion and play the video back in 12 seconds. This is great for analyzing a golf swing or a viewing a bird in flight.
• Dual Record
While recording video in High Definition you have the ability to capture a 2.3 Megapixel still image directly to Memory Stick Duo™ media.
• Switchable HDV/DV Format Recording
The HDR-HC3 is capable of recording and playing back both High Definition (HD) and Standard Definition (SD) video recorded on a standard MiniDV cassette.
• Real-Time HD Codec Engine
Sony developed a Real Time MPEG Encode/Decode system with reduced energy consumption and compact size to fit inside a personal camcorder. This engine provides efficient MPEG2 compression, and recording and playback of clear HD images at the same bit rate of the DV format, so that High Definition video can be recorded on the same MiniDV cassettes as are used for SD recording.
• Assignable Dial
Built into the lens body of the camera, the assignable dial can be used not only for focus or exposure, but may also be customized by the user to control Auto Exposure (AE) Shift, Exposure, Focus and White Balance (WB) Shift. In playback mode it allows you to control the volume.
• Cinematic Mode
Perfect for creating your own movie masterpieces, the HDR-HC3 Cinematic mode lends 24 frame film-like effects to your recordings.
• Built-in Intelligent Flash
For added clarity and detail when taking pictures in low-light situations, the built-in flash improves pictures and reduces shadows.
• 10X Optical / 80XDigital Zoom
The optical zoom helps to bring the action close up from far away. In addition, the Digital Zoom Interpolation means that extreme digital zooming is clearer, with less distortion than previous types of digital zoom.
• Professional Quality Carl Zeiss® Vario-Sonnar® T* Lens
Carl Zeiss lenses have an advanced optical multi-layer coating that offers less glare and flare with increased contrast. This results in vivid image brilliance, true-to-life color saturation and perfect renditions of subtle tones. The additional T* coating on the lens further reduces unwanted glare and flare.
• Super SteadyShot® Image Stabilization System
Picture stabilization system that uses motion sensors to detect and compensate for camera "shake" without compromising picture quality like some other digital stabilization systems.
• i.LINK® Interface (IEEE1394)1
A high speed bi-directional digital video/audio communication between two compatible devices equipped with an IEEE1394 interface, including camcorders, digital VCRs, and PCs.
• Tele Macro Function
Useful for shooting close up shots, but without having the camcorder casting a shadow on the subject. Images shot in the Tele Macro Mode will have the subject properly focused with the background unfocussed so that the subject stands out.
• Active Interface Shoe
Provides a location directly on the camcorder on which to add optional accessories while providing power and two-way communication to those accessories.
Specifications
• General:
Imaging Device: 1/3" 2100K Gross Pixels
ClearVID™ CMOS Sensor
Pixel Gross: 2100K
Recording Media: MiniDV Cassette, Memory
Stick Duo™ Media, Memory Stick PRO Duo™ Media
Recording and Playback Times: SP: 60 min.
Video Actual: 1990K
Still Actual: 1990K
• Convenience:
USB Streaming: N/A
SteadyShot® Image Stabilization: Yes ( Super; Electronic)
Accessory Shoe: Yes, Active Interface Shoe
White Balance: Auto/Outdoor/Indoor/One Push
Memory Stick PRO™ Media Compatibility:
Tested to support up to 2GB media capacity; does not support high speed transfer function;does not support Access Control security function.
Still Image Mode(s): JPEG
Minimum Illumination: 5 Lux (0 Lux with Super NightShot® Infrared System)
Low Light Capability: Super NightShot®
Movie Mode(s): N/A
• Inputs and Outputs:
LANC Terminal: Yes (Stereo Mini)
Analog Audio/Video Input(s): N/A
Analog Audio/Video Output(s): Yes (Multi A/V)
Digital Audio/Video Input(s): Yes (via i.LINK®)
Digital Audio/Video Output(s): Yes (via
i.LINK®)
USB Port(s): Yes (1.1 compliant)
i.LINK® Interface: Yes
Component Video (Y/Pb/Pr) Output(s): Yes
Headphone Jack: N/A
Microphone Input: N/A
Remote Jack: N/A
S-Video Input(s): N/A
• Hardware:
LCD: 2.7" (211K Pixels) Wide (16:9) Touch Panel
SwivelScreen™ Clear Photo plus LCD Display
Lens Type: Carl Zeiss® Vario-Sonnar® T*
Viewfinder: Color, 123K Pixels
Docking Station: N/A
Microphone: Yes (Built-in)
• Optics:
35mm Equivalent: 41.3-485mm (16:9 Camera Mode), 50.5-594mm (4:3 Camera Mode), 40.4-404mm (16:9 Memory Mode), 37-370mm (4:3 Memory Mode)
Aperture: f1.8-2.9
Exposure: Touch Panel (24 steps)
Filter Diameter: 30mm
Focal Distance: 5.1-51mm; 370mm; Telemacro
Focus: Full Range Auto/Manual (Touch Panel)
Progressive Shutter Mode: N/A
Shutter Speed: Auto, 1/240 - 1/500 (AE Mode)
Optical Zoom: 10X
Digital Zoom: 80X
Resolution: 2MP
• Power:
Power Consumption: 4.1W/4.4W - HDV; 3.9W/4.2W - DV (VF/LCD)
Battery Type: InfoLithium® with AccuPower™ Meter System (NP-FP60)
• Battery Life1:
Continuous Record Time: VF/LCD/LCD Backlit Off/VF + LCD - 105/95/105/95 min
Continuous Playback Time: LCD On/Off - 135/145 min
• Service and Warranty Information:
Limited Warranty: 1 Year Parts; 90 Days Labor
• Software:
Supplied Software: N/A
• Video:
Analog-to-Digital Converter: N/A Format(s) Supported: HDV 1080i and MiniDV
• Weights & Dimensions:
Weight: 1 lb. 3 oz. (560g) with Tape and Battery
Measurements: 3 1/4" x 3 1/8" x 5 1/2" (82 x 78 x 139mm)
• Supplied Accessories:
Power Adaptor/ In Camera Charger (AC-L15)
InfoLithium® Rechargeable Battery (NP-FM50)
Wireless Remote Commander® Remote Control (RMT-831)
Lens Hood
Lens Cap
A/V Cable
Component Video Cable
Shoulder Strap
Memory Stick Duo™ Media - 16MB
USB Cable
• Optional Accessories:
Gunzoom Microphone (ECM-HGZ1)
Hard Carrying Case (LCH-HCE)
High Grade Tele Conversion Lens (VCL-HG2037Y)
High Grade Wide Angle Lens (VCL-HG0737Y)
Polarize and Clear Coat Filter (VF-37CPKS)
Quick Charger for Super Quick Batteries (ACSQ950D)
Rechargeable InfoLithium® Battery Pack (NPQM71/91D)
Remote Control Tripod (VCT-870RM)
Starter Kit (ACC-FM50S)
Soft Carrying Case (LCS-VA3)
Travel Charger (BC-TRM)
Stereo Microphone (ECM-HST1)
Tripod (VCT-FXA)
Video Light (HVL-HL1)
• Color:
Black
γεια σας επειδη ενδιαφερομαι για αγορα camera HD αξιζει να περιμενω αυτη η να παρω την HC1?
εκτος απο το βαρος και την τιμη που διαφερουν, ποια νομιζεται οτι ειναι καλυτερη
ευχαριστω
Περνώντας χτες το απόγευμα από το εμπορικό κέντρο The Mall μπήκα στον Κωτσόβολο να ρίξω μια ματιά και σε μια μεριά είχαν live λειτουργία μιας HC1 και μιας SD κάμερας.Με ένα κουμπί επέλεγες ποια από τις δυο ήθελες να δεις και το αποτέλεσμα το παρακολουθούσες σε μια 17άρα wide που υπήρχε.
Ένα μόνο έχω να πω : Η HC1 αξίζει και το τελευταίο λεπτό που ζητά.Η ανάλυση και τα χρώματα που προσφέρει είναι αλλού.Μετά από αυτό το demo δεν έχεις όρεξη να χρησιμοποιήσεις την sd κάμερα ούτε σαν web camera!
Γαμ@ τα λεφτά μου ..... δεν μπορείτε να διαννοηθείτε πόσο ψήνομαι να πάω τώρα να την αγοράσω ........
Όσοι "τα χουν" και ψάχνουν για κάμερα τρέχοντας ..... δεν το συζητάμε καν.
Καλημερα και χρονια πολλά,
Πως μεταφερεται το υλικό από την κασέτα σε ενα CD ή DVD?
Και με τι αποδοση, απώλειες κτλ?
Και τί PC χρειάζεται να έχει κανείς?
Γνωρίζει κανείς?
V
VIDEOMIX
Εγώ με τον mac (της APPLE), έχω μηδενική απώλεια στην μεταφορά υλικού. Εκεί το επεξεργάζωμαι και το μονταρισμένο υλικό το ξαναστέλνω σε dv. Στην συνέχεια το γράφω και σε DVD με εξωτερική συσκευή. (εχω το PANASONIC DMRE-20)
Εαν όμως θέλω μενού στο DVD, θα πρέπει το όλο project να το φτιάξω στο PC (MAC) Σε αυτή την περίπτωση η ποιότητα θα επιρρεαστεί απο την διάρκεια της ταινίας. Του υλικού μας.
Πάνω απο 40 λεπτά, βλέπω απώλεια στην ποιότητα. :?
Συνδέεις την κάμερα με το PC με Firewire και κατεβάζεις το video μέσα στο ειδικό software (πολλά στην αγορά, για σοβαρές χρήσεις δες το Adobe Premiere για PC). Το επεξεργάζεσαι χωρίς να του αλλάζεις format (μένεις σε DV δηλαδή), και όταν είσαι έτοιμος το μετατρέπεις σε MPEG (με απώλειες) και το γράφεις σε VCD ή DVD κλπ.
Παιδάκια την παρέλαβα χθες το απόγευμα και οι πρώτες εντυπώσεις είναι πολύ θετικές. Το μέγεθος είναι αρκετά μικρό ώστε να είναι βολικό, η κατασκευή δείχνει ποιοτική. Έχει και ένα φοβερό κουμπί που το ονομάζει “Easy” όπου εξαφανίζονται οι μυριάδες επιλογές στα μενού και ρυθμίζονται όλα αυτόματα. Έξοδοι composite, component και hdmi (που ακόμα δεν μπορώ να αξιοποιήσω αφού δεν έχω συσκευή απεικόνισης με τέτοια είσοδο). Σε μερικά γρήγορα τεστάκια που έκανα χθες το απόγευμα το video που γράφει είναι εντυπωσιακά ευκρινές σε σχέση με τις κλασικές miniDV (έγινε δοκιμή συγκριτικά με canon miniDV του μπατζανάκη και προβολή στον «αρχαίο» SONY 11 που έχω με την HC3 ρυθμισμένη να βγάζει 576i μια και ο αρχαίος δεν καταλαβαίνει από 1080i ) . Όταν την εξερευνήσω αρκετά θα σας παραθέσω τις οριστικές εντυπώσεις μου.
Με γειά! :)
Το μόνο που με χαλάει από τη συγκεκριμένη κάμερα, είναι το ότι αφαίρεσαν τα manual ρυθμιστικά της προκατόχου της και το δαχτυλίδι για το focus. Κατά τα άλλα το μηχάνημα φυσάει! :)
ελα το ιδιο πραγμα ειχαν και στο μεντια μαρκτ και ηταν ΤΡΕΛΛΗ ΑΠΑΤΗ!... πηρα μια καμερα απο διπλα (απλη και οχι HD) και τραβιξα το αεροπλανακι και εβγαζε καλυτερη εικονα (και ας ειχε και το τζαμι στη μεση) απο την απλη καμερα εσωτερικα...
εχουν κανει κατι και προσθετουν θορυβο τρελλο!!! οχι οτι δεν εχει παραπανω αναλυση και ποιοτητα εικονας... αλλα μη δειχνουν και μ@λακιες!...
Μια ζωη απατεωνες εκει στη σονυ... ΟΤΑΝ αλλαξουν... ισως τους προτειμησω... προς το παρον η πανασονικ τους σκιζει στις miniDV και η JVC στις HDD καμερες... μια απο τις δυο θα διαλεγα...
Καλημερα σε ολους.
Πηρα και γω πρινα απο κανα 2 βδομαδες την καμερα αυτη (η πρωτη που απεκτησα ποτε).
Εχω ενα σκασμο αποριες τις οποιες πιθανοτατα θα σας ειναι και πολυ βαρετες.
Ωστοσο θα εκτιμουσα αν μπορειται να μου πειτε καποια συγκεκριμενα πραγματα μιας και ετοιμαζομαι για το πολυ αναμενομενο γαμηλιο ταξιδακι :D
1. Πρεπει να χρησιμοποιω κλασικη κασετα ή πρεπει HD (και που την βρισκω)
2. Μολις απεκτησα το adobe premiere pro 2.0. Τι γινεται απο δω και περα
3. Αν με το παραπανω προγραμμα (αν δεν γονατισει το laptop) περασω το υλικο σε DVD, θα το βλεπω στην TV σε HD (TV pioneer fde 436)
4. Αν γεμισω μια κασετα με πχ 60 λεπτα, "χωραει" σε ενα DVD, (Σε HD), μαλλον οχι αυτο μπορω να το καταλαβω απο κατι μου αναθερθηκε παραπανω σχετικα με blu ray.
Aυτα θα ηθελα προς το παρων, και σας ευχατιστω για τον χρονο και χωρο που μου δινετε.
Φιλικα
Ντινος
Ντίνο,
Αν και δεν έχω HD κάμερα, θα σω πω ότι ξέρω.
- Νομίζω ότι καi η απλή DV κασέτα κάνει για HD.
- Αν και χρησιμοποιώ Vegas (παλιότερα το Premiere), μπορείς να κάνεις capture σε avi ή wmv
  για να κρατήσεις την ποιότητα του HD. Πρέπει να ψάξεις εκεί που έχει τις παράμετρους το premiere.
- Θα το βλέπεις στην TV σε HD ανάλυση, αν συνδέσεις με καλώδιο HDMI ή DVI και πιθανόν με component.
Ελπίζω να σε βοήθησα. Πάντως να ξέρεις ότι ακόμα δεν υπάρχει η δυνατότητα να κάνουμε τα HD σαν τα DVD (μενού, τίτλοι κ.λ.π.). Άρα ή θα τα κάνεις όπως είπα σε avi ή wmv, κρατώντας την ποιότητα HD, ή απλά μπορείς να τα κάνεις σε DVD (ξεκινώντας από capture σε 720 χ 576) αλλά χάνοντας την ποιότητα του HD.
Κωνσταντινε σε ευχαριστω για την απαντηση σου.
Νομιζω οτι με βοηθησες αρκετα. (οχι και παρα πολυ, μην το παρεις πανω σου :D)
Πως μπορω αραγε να βεβαιωθει οτι οι απλες κασετες κανουν και για HD. ?
Αν ρωτήσεις σε κάποιο μαγαζί που πουλάει Sony; ή στο www.sony.gr.
Αλλά δες και το manual εκεί που γράφει το φορμά εγγραφής της κάμερας.
Η συγκεκριμένη κάμερα έχει την δυνατότητα να γράφει είτε σε format standard DV ή σε HDV σε κανονικές κασέτες miniDV (είναι προτιμότερο να αγοράζεις καλές κασέτες για να μην υπάρχουν προβλήματα dropouts).
Η εξαγωγή του video γίνεται είτε κατ’ ευθείαν σε επιτραπέζιο DVD recorder έαν έχει ψηφιακή είσοδο firewire (ilink) είτε σε PC μέσω της ίδιας εξόδου.
Στην πρώτη περίπτωση με την επιλογή Burn DVD από την κάμερα αυτομάτως υποβιβάζει το σήμα στο επίπεδο standard DV (576i) ώστε το δισκάκι που θα φτιάξεις να είναι συμβατό και με το recorder αλλά και οποιοδήποτε DVD μπορεί να παίξει εγγεγραμμένα από χρήστη δισκάκια.
Στην περίπτωση του PC έχεις πλέον την δυνατότητα να επιλέξεις το επίπεδο του σήματος που θα βγεί (576i / 1080i) αρκεί να το υποστηρίζει το software που θα κάνει το capturing.
Είναι λογικό να τραβάς πάντα σε HDV ώστε να έχεις και την καλύτερη δυνατή ποιότητα και μέχρι να εμφανισθούν τα αντίστοιχα HiDef recorders – players να το μετατρέπεις σε DV format.
Πολλές πληροφορίες από χρήστες υπάρχουν εδώ
http://www.sonyhdvinfo.com/
Ελπίζω να βοήθησα
Δημήτρης
intergrale
