Νεος ELECTROCOMPANIET ECI 80D H εταιρία δηλώνει ηδη την κυκλοφορία του,οι τιμές που βλέπω Γερμανία παιζουν απο 2100 μεχρι 2400. Ελπίζω να τον δουμε στην έκθεση σε τιμή ευρωπαική........ PREAMPLIFIER: |
Input impedance: 75 kOhms |
Noise floor:< -130dB |
THD+N: < 0.002% |
Frequency response (-3dB): 1 – 150 kHz |
Volume adjustment range: - 110dB to +15 dB |
OUTPUT AMPLIFIER: |
THD+N: < 0.005% |
Output power (into 8 Ohms): 2 x 80W |
Output power (into 4 Ohms): 2 x 150W |
Damping factor (8 Ohms load): > 300 |
Frequency response (-3dB): 1 – 150kHz |
SNR (input shorted, ref 1W into 8 ohms, A-weighted): 102 dB |
Gain: 25 dB |
Protection: DC, overload, temperature |
RIAA PHONO: |
Pickup support: Moving Magnet |
Gain: 40 dB @ 1kHz |
Input impedance: 47 kOhms || 100pF |
RIAA correction accuracy: +/-0.1dB, 25-20kHz |
Subsonic filter: -3 dB @ 14 Hz |
THD: < 0.001% |
SNR: 83 dB (A-weighted) |
Overload margin: 30dB @ 1kHz |
HEADPHONE AMPLIFIER: |
THD+N: < 0.001% |
Load impedance single output in use: > 16 Ohms |
Load impedance both outputs in use: > 32 Ohms |
Max output power (into 16 Ohms load): 0.4W |
Max output voltage swing: +/-8V peak |
Output impedance: 10 Ohms |
Protection: DC, overload |
DIGITAL & STREAMING: |
Optical input: PCM: 44.1kHz/16bit up to 192kHz/24bit |
Coaxial input: PCM: 44.1kHz/16bit up to 192kHz/24bit |
Bluetooth support: BT5.0, A2DP, SBC, AAC, aptX-HD |
CONNECTIVITY: |
Digital inputs: 2 coaxial, 3 optical |
Analog inputs: 2 RCA |
Analog preamplifier output: 1 RCA |
Service port: 1 USB |
12V trigger: 1 input, 1 output |
Phono MM: 1 RCA |
Headphone outputs: 3.5mm jack + 6.35mm jack |
Speaker outputs: 1 pair binding posts |
WEIGHT & DIMENSIONS: |
Weight: 8 kg – 17.6 lbs |
Width: 470 mm – 18.5 inches |
Depth: 262 mm – 10.3 inches |
Height: 90 mm – 3.5 inches |
VOLTAGE & POWER CONSUMPTION: |
Mains input voltage: 100-240VAC, 50/60Hz, 3A |
Idle (no load or signal): 30 W |
Standby: < 0.5 W |
OFF (main switch OFF): 0 W |
ECI 80D Integrated Amplifier
The Electrocompaniet ECI 80D is our brand new integrated amplifier. The new ECI 80D offers 2 x 80 Watts into 8 Ohms, using an in-house developed Class A/B Amplifier.We have equipped it with a built-in RIAA pre-amplifier for your LP player (MM cartridge support), 2-way Bluetooth HD for both...
80,2 KB Προβολές: 0
