Νεος Marantz VP-11S2
ΑΝΔΡΕΑΣ Κ.
Ιδρυτής
Marantz’s new VP-11S2 high-definition DLP front projector features Texas Instrument’s DC4 chip, which boasts increased brightness and significantly higher contrast than the current DLP chip sets; and HDMI 1.3 inputs with Deep Color capability.
The projector also includes the Gennum GF9351 chip, a programmable video processor that can perform calculations on the order of 500 million floating point operations per second. Featuring both standard and long-throw lens options, and can be retrofitted for use with Marantz’s optional anamorphic lens systems.
“The VP-11S2 is truly the next generation in DLP projectors: a cinema quality display device that rivals professional grade projectors,” commented Marcel Mukerjee, National Sales Director at Marantz <?xml:namespace prefix = st1 /><st1:country-region w:st="on"><st1:place w:st="on">Canada</st1:place></st1:country-region>.
Boasting a die-cast aluminum chassis, the VP-11S2 also provides HD component video, S-video, composite video and analog RGB connections; and has a vertical lens shift that allows it to be placed well above the top of the screen. The projector also offers remote in/out connections, RS-232C serial control ports, and two DC trigger connections that can trigger two independent operations. This, explains Marantz, allows the projector to reconfigure a dual-aspect ratio projection screen whenever the aspect ratio of the program source changes from 16:9 to 4:3, for example.
The on-screen menu system aids in set-up, and provides calibration facilities like colour temperature and gamma adjustments. Optics are provided by Konica-Minolta, with customized colour filters are optimized to match the spectral characteristics of the 200 Watt DC SuperHighPressure lamp assembly. The colour wheel itself spins at 10,800 RPM. A specially designed Quiet Fluid Dynamic Bearing motor supplies virtually silent operation.
http://marketnews.ca/news_detail.asp?nid=3336
Ουφ, δηλαδη ειναι καλυτερος απο τον προηγουμενο?
Δεν θελω να τον δω, δεν θελω να τον δω!:prof:
...Μεγα λαθος. τα ματακια τα εχουμε για να βλεπουμε.
Το θεμα ειναι αν εχουμε μυαλο...και δεν αγγιζουμε!!
jimacid
