Νεο κορυφαιο CHARIO , SERENDIPITY
LUXMAN
Serendipity
Only a few concepts are necessary to understand the rationale behind the Serendipity design. We tried to give the listener a better illusion of being there in three steps:
1. Pulling out existing ambience information from standard recordings;
2. Presenting them to the ears in a different manner never tried before;
3. Reducing to the minimum the influence of listening room boundaries.
It seems compulsory to disperse the information over a wider area to let our brain localize the resulting multi-direction distribution of the ambience signals. This in-turn leads to the smearing of the direct sound compromising the front sound stage. Academy Serendipity is based on the assumption that a vertical array of sources with different frequency bandwidth, different gain and different group delay can act as a Distributed Source, generating at the listener’s ears some Cross-Talk signals useful to enlarge the side perspective while keeping the correct Localization Cues. To achieve this the Academy Serendipity design manages the frequency distribution of acoustic energy from Floor & Ceiling, the first reflections, by means of the proprietary WMT TM Alignment configuration and the geometry of the Vertical Reversed Driver Array.
Low Frequency Load NRS 2Π sr Vented Isobaric Compound
Vent Geometry Bi-dimentional Hyper-Exponential Hourglass Type
Configuration 5 way Reversed Vertical Alignment Floor-Standing
Drivers
1 Tweeter 32 mm SILVERSOFT TM dome NeFeB motor
1 Midrange 130 mm ROHACELL® Poly-Ring NeFeB motor
1 Woofer 130 mm ROHACELL® Full-Apex TM NeFeB motor
1 Woofer 170 mm ROHACELL® Full-Apex TM NeFeB motor
2 Sub 320mm Natural Fibres – 2 Waves Surround HF motor
Sensitivity 93 dB SPL normalized to 1m with 2.83Vrms de-correlated L/R pink noise within IEC 268-13 compliant listening room
Low Frequency Cut Off 23Hz @ -3dB referred to C4 WETS
Overlapping Points 240/500/1250/1850 Hz (see PDF)
Rated Impedance Modulus 4Ω (min 3.0) Argument ±36°
Size 1610x400x580 mm (HxWxD)
Weight 100kg
Cabinet Solid walnut or cherry and HDF. The structure is made up of cabinets: the lower, containing two woofers and the upper, containing two woofers, one midrange and one tweeter. The two wooden structures are separated by means of four cylindrical proprietary-engineered elastomer puffers which act as vibration de-couplers dissipating mechanical energy by orthogonal elongation.
Speakers Orientation The speakers should be tilted inward facing the listener.
Listening Distance Optimum speaker-listener distance is within 3.5 – 4.0m
Listening Layout A carpeted floor in front of the speakers is recommended.
Side and Back walls Should stay 1m away from the speaker front baffle at least.
Suggested Amplifier Normal ampingRated for 400 W/4 max Average Power.Bi-ampingRated for 200 W/4 max Average Power.
Notes
  1. All quantities in SI Units
  2. Average Power computed as V2rms/R
  3. Overlapping Points is a proprietary implementation for un-conventional Xover
  4. Specs subject to change without notice
αν δεν ειχε αυτη την εμφανιση και αυτη την τιμη θα ειχε καλυτερη τυχη
κριμα αριστα ηχεια τιμη -εμφανιση= out
LUXMAN
Περι τα 20.000 ευρω λιανικη . Φυσικα η street price θα ειναι πιο κατω .
Αυριο θα ξερω την επισημη λιανικη του αντιπροσωπου ( STUDIO 82 , 2109569084)
ΤΣΑΑΑΑΑΜΠΑ, ΠΑΙΔΙΑΑΑΑΑΑ!!!
Τρέξτε, όποιος προλάβειειειειειειειειειει!!!!!:crazy_1:
LUXMAN
ΛΙΑΝΙΚΗ 19.900 ευρω .......τιμη με εκπτωση περιπου 16.000 ευρω και ισως και πιο κατω
Πιστεύω ότι και πάλι είναι πάρα πολλά. Και πείτε μου κάτι ρε παιδιά : τι παπάτζες είναι αυτές με τις τιμές? Έτσι όπως το διαβάζω φαίνεται πολύ ψεύτικη η "λιανική" τιμή. Με το "καλημέρα" 20% έκπτωση? Και "ίσως και πιο κάτω" τι σημαίνει? Παίζουν ρόλο τα μούτρα του (τυχόν) ενδιαφερόμενου?
Ε, ρε τι παιχνίδια "παίζονται" γύρω από την τσέπη μαααααας:mad_2::mad_2::mad_2:
LUXMAN
Εεεε εσυ δεν τρωγεσαι με τιποτα !!:mad_3: :mad_3:
Λοιπον με η χωρις καλημερα εσυ θα τα πληρωσεις 19.900 !!:happy_5: :happy_5:
......και ναι .....αναλογα με τα "μουτρα" του τυχον ενδιαφερομενου αλλαζει και η τιμη . Οπως αλλαζει και η εξυπηρετηση σε μια δημοσια υπηρεσια η σ ενα service αν πας με ξυνη μουρη . :happy_4:
LUXMAN
Έχω ηχεία Chario και φυσικά είμαι απόλυτα ευχαριστημένος!!!
Θα κάνουμε καμία δοκιμή και με αυτά;
Ποια ειναι αυτα Χρηστο ;;;
Δηλωνω και εγω ευτυχης κατοχος εδω και ενα μηνα των ACADEMY 3 .
Charge: Push-pull reflex , Double résonnateur. Fréquence à -3 dB: 25 Hz. Fréquence de coupure: 250/1.000/1.300/1.900 Hz. Rendement: 91 dB. Impédance nominale: 4 Ohms. Amplificateur conseillé: 50 ÷ 200 Watts RMS (8 Ohms). Dimensions: 139 x 33 x 50 cm (HLP). Poids: 80 Kg. Finition: bois massif
LUXMAN
I do not hear you ...... :crazy_10:
opanamas
