ΟΛΟΚΑΙΝΟΥΡΓΙΟΣ HDMI 4K BT Wi-Fi SPOTIFY RX-V481 ραδιοενισχυτης ενισχυτης YAMAHA USB 5x145watts
τιμη 300 ευρω.
Ο ενισχυτής είναι ολοκαίνουργιος!!! Τον παίρνετε σε τιμή μεταχειρισμένου.
Ανα καναλι : 145 W (6 ohms, 10% THD)
Χειρίζεται μέσω κινητού και έχει τα πάντα! Apple Lossless , FLAC , Spotify, gobuz, BT , USB STICK, WEB RADIO, 4K 60 HDMI, Lan wifi, υποστηρίζει.
Αγορά 600€. Δεν χρησιμοποιήθηκε ποτέ.
ΞΕΩΡΙΣΤΟ EQUALIZER ΑΝΑ ΚΑΝΑΛΙ
Damping factor: 100
ΑΡΙΣΤΕΣ ΚΡΙΤΙΚΕΣ!!!
https://www.cnet.com/reviews/yamaha-rx-v481-review/
https://www.crutchfield.com/S-Zp7ZF9PNNkH/p_022RXV481/Yamaha-RX-V481.html
ΛΕΠΤΟΜΕΡΙΕΣ
https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-v481_u/index.html#product-tabs
This 5.1-channel 4K Ultra HD network AV receiver offers built-in Wi-Fi®, Bluetooth® and AirPlay® wireless connectivity, and supports playback of high-resolution audio files. The free MusicCast Controller app makes it easy to access your music library and streaming music services. Add audio in up to 9 additional rooms with MusicCast wireless speakers or other MusicCast devices. Πλήρη χαρακτηριστικά: Compatible with Yamaha’s MusicCast, enjoying music through the home becomes a reality. The RX-V481 also supports HDMI® with support for 4K60p (4:4:4), HDCP2.2, HDR and BT.2020 for top level video performance and provides Speaker Zone B output. MusicCast for audio enjoyment in every room 5-channel powerful surround sound --- 80 W per channel (8 ohms, 20 Hz-20 kHz, 0.09 % THD, 2 ch driven) --- 115 W per channel (6 ohms, 1 kHz, 0.9 % THD, 1 ch driven) --- 145 W per channel (6 ohms, 1 kHz, 10% THD, 1ch driven) Wi-Fi Built-in and Wireless Direct Compatible for Easy Network Bluetooth® for wireless music streaming and Compressed Music Enhancer for Bluetooth AirPlay®, Spotify®*, Pandora®*, JUKE* music streaming service and AV Controller app *Music service availability varies by region. DSD 2.8MHz / 5.6MHz, FLAC / WAV / AIFF 192kHz / 24bit, Apple Lossless 96kHz / 24-bit playback Gapless playback compatibility allows play without interruption HDMI® (4 in / 1 out) 4K Ultra HD Full Support with 4K60p (4:4:4), HDCP2.2 (4 in / 1 out), HDR Video and BT.2020 pass-through Front panel USB Digital Connection for USB thumbdrives YPAO™ sound optimisation for automatic speaker setup Dialogue Lift ensures that dialogue comes from the centre of the screen Dialogue Level Adjustment for proper sound balance with dialogue and vocals Assignable amplifiers for bi-amp connection and Speaker Zone B Function Multi-language colour OSD capable of displaying cover art ECO mode operation for about 20% less power consumption AV ReceiverAmplifier SectionChannelRated Output Power (1kHz, 1ch driven)Rated Output Power (20Hz-20kHz, 2ch driven)Maximum Effective Output Power (1kHz, 1ch driven) (JEITA)Dynamic Power per Channel (8/6/4/2 ohms)Surround Sound ProcessingCINEMA DSPDSP ProgramsDialog Level AdjustmentVirtual Presence SpeakerDialogue LiftSILENT CINEMA / Virtual CINEMA DSPDolby TrueHDDolby Digital PlusDTS-HD Master AudioAudio FeaturesCompressed Music EnhancerYPAO sound optimizationAdaptive DRC (Dynamic Range Control)Initial Volume & Maximum Volume SettingBi-amp capabilityAudio Delay192kHz/24-bit DACs for all channelsVideo Features4K Ultra HD Pass-throughHDMI 3D passthroughHDMI Audio Return ChannelDeep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-SyncConnectivityHDMI Input/OutputHDMI CECUSB InputNetwork PortWi-FiAirPlayBluetoothFront AV InputDigital Audio Input/Output: OpticalDigital Audio Input/Output: CoaxialAnalog Audio Input/OutputComposite Video Input/OutputPreoutHeadphone OutputTuner SectionFM/AM TunerUser InterfaceOn-screen displaySCENEApp ControlRemote Control UnitZone ControlZone B OutputGeneralStandby Power Consumption (IR only)Auto Power StandbyECO modeDimensions (W x H x D)Weight MusicCast RX-V481 MusicCast RX-V481 AV Receiver Amplifier Section Channel 5.1 Rated Output Power (1kHz, 1ch driven) 115 W (6 ohms, 0.9% THD) Rated Output Power (20Hz-20kHz, 2ch driven) 80 W (8 ohms, 0.09% THD) Maximum Effective Output Power (1kHz, 1ch driven) (JEITA) 145 W (6 ohms, 10% THD) Dynamic Power per Channel (8/6/4/2 ohms) - / 110 / 130 / 160 W Surround Sound Processing CINEMA DSP Yes (3D) DSP Programs 17 Dialog Level Adjustment Yes Virtual Presence Speaker Yes Dialogue Lift Yes SILENT CINEMA / Virtual CINEMA DSP Yes (Virtual CINEMA FRONT) Dolby TrueHD Yes Dolby Digital Plus Yes DTS-HD Master Audio Yes Audio Features Compressed Music Enhancer Yes (incl. enhancer for Bluetooth) YPAO sound optimization Yes Adaptive DRC (Dynamic Range Control) Yes Initial Volume & Maximum Volume Setting Yes Bi-amp capability Yes Audio Delay Yes (0-500 ms) 192kHz/24-bit DACs for all channels Yes (Burr-Brown) Video Features 4K Ultra HD Pass-through Yes (4K 60p 4:4:4) HDMI 3D passthrough Yes HDMI Audio Return Channel Yes Deep Color/x.v.Color/24Hz Refresh Rate /Auto Lip-Sync Yes Connectivity HDMI Input/Output 4 / 1 (HDCP2.2, HDR and BT.2020 compatible) HDMI CEC Yes USB Input USB Memory, Portable Audio Player Network Port Yes Wi-Fi Yes (with Wireless Direct) AirPlay Yes Bluetooth Yes (SBC / AAC) Front AV Input USB / Mini Jack Digital Audio Input/Output: Optical 1 / 0 Digital Audio Input/Output: Coaxial 2 / 0 Analog Audio Input/Output 4 (front 1) / 0 Composite Video Input/Output 4 / 1 Preout Subwoofer Headphone Output 1 Tuner Section FM/AM Tuner Yes User Interface On-screen display Yes (colour OSD) SCENE SCENE (4 sets) App Control Yes (iPhone / iPad / Android phone / tablet) Remote Control Unit Yes Zone Control Zone B Output Yes General Standby Power Consumption (IR only) ≤0.1W Auto Power Standby Yes ECO mode Yes Dimensions (W x H x D) 435 x 161 x 327 mm (with antenna: 435 x 225.5 x 327 mm); 17-1/8” x 6-3/8” x 12-7/8” (with antenna: 17-1/8” x 8-7/8" x 12-7/8”) Weight 8.1 kg; 17.9 lbs.
  • loggeo
giannis9494
