Σε άριστη κατάσταση με τηλεχειριστήριο και user manual... τιμή 150 ευρώ.
Specifications
Power output: 95 watts per channel into 8Ω (stereo)
Frequency response: 10Hz to 65kHz
Total harmonic distortion: 0.03%
Damping factor: 150
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 85dB (MM), 88dB (line)
Channel separation: 70dB (line)
Dimensions: 439 x 159 x 375mm
Weight: 12.3kg
Specifications
Damping factor: 150
Weight: 12.3kg
