Ο απόλυτος βραχίονας;
[reliops=TRITIUM AIR BEARING ULTIMATE TONE ARM TONEARM TRIPHAZER TURNTABLE DEMO][youtube]ldg3gez0Bys[/youtube][/reliops]
Απάντηση: Ο απόλυτος βραχίονας; (εν δράσει)
Τρέμει κανένας...Air Tangent;:612:
[reliops=TERMINATOR 3 AIR BEARING TONEARM ON-THE-FLY VTA ADJUSTMENT DEMO][youtube]_ktD4Rw2a70[/youtube][/reliops]
Απάντηση: Ο απόλυτος βραχίονας; (Tritium)
TONE ARM ASSEMBLY:
The lightest, strongest, least resonant and most accurate tracking pickup arm ever made.
Tone arm moves effortlessly in horizontal and vertical directions with compressed air and is damped by viscous fluid.
It is COMPLETELY FRICTIONLESS!
PLATTER ASSEMBLY:
Precision designed to damp out disruptive energy!
Platter has a layer each of Aluminum and Brass with a Copper top platter mat.
2 separate layers of ISO-DAMP for perfect playback!
Suspended on a Brass/Bronze ball bearing and nylon thrust pad for smooth operation.
Rotor is designed with a .017" slope to remove record warps and virtually eliminate all subsonic wow.
PLINTH (BASE) ASSEMBLY:
2-piece base comprised of Copper and Brass plates.
Layer of ISO-DAMP compound between the layers to dampen and absorb incoming and outgoing vibrations to very low levels.
Plinth rests on 4 adjustable brass leveling legs.
MOTOR:
Pulley is precision machined for accurate 33 & 45 RPM playback.
The High Torque Aluminum motor with a brass base.
Mounted on a Brass base with Pure Copper top and a layer of ISO DAMP.
Includes 4 adjustable feet.
Alnico 48 pole, 115 VAC, .6 amps, 600 rpm, 1/150 HP.
AIR PUMP:
Air Pump is a Medo linear piston pump.
Unit is very quiet and can be placed up to 100 feet from the listening area.
Includes 100 feet of air tubing and a surge tank with a 2 gallon capacity.
EXTRAS:
Polished Brass and Copper Record Weight with a nylon insert for quiet spindle touchdown.
Phono Output Connector Box is a machined aluminum billet with gold RCA connectors and a ground connector.
Power Switch is a heavy threaded aluminum cylinder.
Heavy duty power cable.
High torque belt drive.
Tritium logo is attached to the plinth.
skaloumbakas
4Haris
Εχεις "προσγειωθεί" αρκετά...
Νοιώθω κατενθουσιασμένος! :126::136:
Κι εγώ που πίστευα ότι οι βραχίονες παράλληλης μετατόπισης είναι λίαν...απογειωτικοί:612:
[reliops=Terminator-Verus][youtube]2eU2Nz01eyo[/youtube][/reliops]
[reliops=The Terminator & Shure Ultra][youtube]-haRkmwPhg8[/youtube][/reliops]
[reliops=The Terminator & Shure Ultra][youtube]0ki8eggpZ3c[/youtube][/reliops]
Να κι ένας Vintage linear:
[reliops=JS Electrostatics air-bearing tangential tonearm][youtube]xe-MdD_IjRI[/youtube][/reliops]
Ο γνωστός και μη εξαιρετέος Air tangent:
http://www.dnaudio.com/Tan.htm
http://www.airtangent.net/main.html
Γίνεται να λείψει η Clearaudio από το πάρτυ;
http://www.musicalsurroundings.com/clearaudio/linear.html
http://www.enjoythemusic.com/Magazine/factory/clearaudio/
Ο τελευταίος Goldmund Τ-8 επάνω στον ακριβότερο βινυλιακό περιστροφέα του κόσμου:
http://www.audiojunkies.com/blog/952/goldmund-t8-tonearm
http://www.audiojunkies.com/blog/390/goldmunds-point-of-reference
Κι ένας πιό προσγειωμένος Τ-5 που δεν παύει όμως να θέτει τ'αγαπημένα μουσικά κομμάτια σε τροχιά κάθε φορά εδώ και χρόνια:135::
http://www.vinylengine.com/library/goldmund/t5.shtml
koskef
