Οpera Αudio Consonance Cyber 800 amplifiers
Κώστας Φ.
Retail: $3990
The amplifier is a push-pull Class AB mono power amplifier with two pairs shunt-wounded EL34 output power tubes per channel. It uses little global feedback. Signal goes first to the 6922 dual triode acted as input stage, then to the 6922 dual triodes acted as double drive stage. The 5687 drive the EL34 output tubes which are transformer-coupled to the load (In this case, the speaker.).
Specification:
  • Power: 78 watt x 2, RMS 1kHz ( Ultra-linear )
  • Total Harmonic Distortion: less than 1%( 50watt, 1kHz )
  • Frequency Response: ( -3dB points at 50 watt ) 6Hz-100kHz
  • Input Sensitivity: 700mV
  • Input Impedance: 100k ohms
  • Output Impedance: 4, 8 ohms. ( User selectable )
  • Signal/Noise: 90dB
  • Consumption: 90watt x 2
  • Overall Negative Feedback: Little
  • Tubes: EL34/6CA7 x 8, 5687x 2, 6922 x4
"In conclusion
The Consonance Opera's are a terrific deal and look and sound much like the expensive audio jewelry you see at the best salons. Audiophiles should work for top sound and a bit of tube rolling and cable matching brings out the best from the Opera's. Wonderful metal work and facilities compliment exceptional sound from such a modestly priced pair of monoblocks. The mids and highs are elegant and detailed with the kind of sound you can take home to mother. The bass is good enough to satisfy and entertain unless you have only had a diet of solid-state sound your entire life. More powerful sounding than you would expect from 75-watts per channel indicating excellent design and R&D. I liked the Opera's and enjoyed many hours of beautiful, sweet music with them. I predict that you will, too."
-- Robert H. Levi
"Uh... yeah! These are truly stellar and at a hair under $4k ... well they are a real steal. I am in the process of writing a formal take on these, but again let me say that while they do have shortcomings (heck they are $4k!!) when compared to my $10k 200-watt Class A Claytons, what they lack is rather moot. They play music and sound very, very, very good." -- Dave Clark
Full Review: positive-feedback.com
mrkgeo
