10 ημερων,αριστη κατασταση,με αποδειξη αγορας.
πωλειτα γιατι το linux,δεν το παλευω...
τιμη 220 ευρω
Xtrend ET5000 Technical Specifications
Front panel:
Display 3 LEDS RED, GREEN, YELLOW
Smart card slot 2
USB 2.0 1
Key Power, Channel up/down, Volume up/down
Rear panel:
Power Switch 1
Sat-IF input/output 1x F-type socket
Video output(analogue) 3 x RCA socket (YPbPr)/1 x RCA
Video/audio output (digital) 1x HDMI
Audio output (analogue) 2x RCA
Audio output (digital) Standard optical (SPDIF)
USB 2.0 2x
Ethernet 10/100 Mbit
RS232 1x
Inside:
Processor BCM7413
Boot flash 4MB
Image flash 128MB
Memory 256DDR
Power:
Main voltage 950-250/50-60 V/Hz
Power consumption
(Max./typ. operation/stand-by) 65/35/1 W
RF:
RF range 950-2,150 MHz
Modulation, FEC, de-multiplexer DVB-S/DVB-S2 standard
Video Video resolution CCIR 601 (720 x 576 lines), 576p, 720p, 1080i
Video decoding MPEG-2, MPEG-4 compatible
Input data rate 2-45 MSymb/s
S/N > 53 dB
Decoding:
Decoding AC3, AC3+, MPEG-4 (AAC-HE), MPEG-1, Layer 1, 2 and 3 optional DTS, WMA
Sampling rate 32/4.1/48 kHz
S/N > 65 dB
LNB:
LNB supply(horiz./vert.) 14/18; Max. 400 V/mA
Control signal 22kHz ; ToneBurst ; DiSEqCTM1.0/1.1/1.2
General:
Dimensions (W x H x D) 300 x 60 x 220
Weight (without HDD) App. 2.0kg
τιμη 220 ευρω
Front panel:
Smart card slot 2
USB 2.0 1
Rear panel:
Power Switch 1
USB 2.0 2x
RS232 1x
Inside:
Processor BCM7413
Boot flash 4MB
Image flash 128MB
Memory 256DDR
Power:
Power consumption
RF:
S/N > 53 dB
Decoding:
S/N > 65 dB
LNB:
General:
