Πακετο DVD Denon 3910 & DVDO VP30
Πωλειται ο επεξεργαστης εικονας (scaler) DVDO VP30.
Λεπτομερειες μπορειτε να δειτε απο εδω. Tιμη 600€.
Μερικα χαρακτηριστικα του:
Input Aspect Ratio Controls
* Presets: 4:3 full frame, 4:3 letterbox, Panorama (non-linear stretch), 16:9 full frame or user defined aspect ratio (10)
* Flexible Horizontal and Vertical Zooming (up to 2x) & Panning Controls
* Overscan Adjustment per input
Output Aspect Ratio Controls
* Presets: 4:3, 16:9, 2.35:1, or custom aspect ratio
* Separate Display/Screen Adjustments
* Underscan Adjustment to address Overscan inherent in a display
Picture Controls
* Fully programmable controls with non-volatile memories
* Each input has an individual memory for each processed format
* Brightness, Contrast, Saturation, Hue, Sharpness, and Fine Y/C Delay (sub-pixel)
Operation
* Intuitive On Screen Display
* Easy to read 2 line, 20 character Backlit Front Panel Display
* Front Panel Controls
* IR Remote Control (discrete codes available)
* Automation via RS232 port
Output Controls
* Output Resolution
* Sync Type
* Colorspace (RGB or YPbPr/YCbCr)
* Frame Rate (Locked/Unlocked)
* Gamma
* Display Profiles (10)
35 Built-in test patterns
Software Upgradeable via Serial Port
Miscellaneous
Predefined Video Output Resolutions
Digital Television Standards
480p, 576p, 720p, 1080i, 1080p-50/60
PC Standards
VGA, SVGA, XGA, SXGA
Plasma Resolutions
852x480, 1024x768, 1024x1024, 1280x768, 1360x768 (2), 1365x768, 1366x768 (2), 1920x1080
DLP Resolutions
1280x720, 1024x576, 848x600, 1920x1080
LCOS Resolutions
1400x1050, 1365x1024, 1400x788, 1920x1080
CRT Resolutions
1280x960, 1440x960, 1440x1152
User Customizable Output Resolution from VGA (6400x480) to 1080p (1920x1080)
Απάντηση: Scaler DVDO VP30
Μαζι με τον επεξεργαστη θα δωσω δωρο βασεις ηχειων της Audio magic (αξιας 200€), φιλτρο ρευματος tsakiridis και καλωδια (dvi, hdmi, component,ic) που μου εχουν μεινει (δεν ειναι της πλακας ultralink, real cable κτλ).
Η τιμη παντα στα 500€
Δεκτη ανταλλαγη με dreambox 800αρη. Λοιπες προτασεις συζητησιμες
Νεα τιμη 480€. Δεκτη ανταλλαγη με dreambox 800 ή bluray αναλογης αξιας.
πακετο DVDO VP30 + dvd denon 3910
Πακετο και μονο το dvdo vp 30 μαζι με το dvd denon 3910 Universal Player (Premium Silber) Για οσους ξερουν το 3910 ηταν γνωστο για την πολυ καλη εικόνα και τον πολυ καλο ήχο,ειδικά σε Dvd-Audio & SACD !
Τιμη για το πακετο και μονο 600€. Η τιμη αυτη ειναι και η οριστικη για το πακετο γιατι παρακατω δεν αξιζει να τα δωσω (σαν πακετο ειναι ηδη πολυ χαμηλη).
  • loggeo
giannis9494
